I'm learning Micropython, (actually Circuit Python) so forgive the elementary questions.
Will this Micropython be able to use existing Circuit Python libraries? This opens up a lot of possibilities with an existing code base.
My initial impression of Micropython on the P2 was it appeared to be a very expensive way to run the platform, that is until I realized that you were replacing the necessity of a programming platform like a PC. Then it makes sense!
I'm curious about those boards I saw in the video from 3 months ago. Will these be available from Parallax or a partner?
RJ
Those boards are from @Tubular and I've also wondered if they'd be completed.
As for Circuit Python, TeamOz will answer that question. I believe the effort was to stay close to the hardware and original MicroPython code base produced by Damien.
I suspect running CircuitPython is possible, there's more similarities than differences, we just haven't tried it yet. Do you have a particular library you wanted us to try?
As for the P2DIP40 boards, yes these will be made available, they're about to be deployed in their first serious application and if all goes well we'll run a batch of 180
Neopixel (neopixel.mpy) for those ws2811 strings as provided in the P2 holiday kits
I would definitely be interested when you have them for sale.
Just giving this a small bump to see what the current state of Micropython for the propeller is.
Curious if it will be able to support downloadable libraries?
@ersmith Been a while, but I'm attempting to compile this, without much luck. Not so surprising maybe...
Are there instructions for compiling the P2 version?
Is it just running make in the riscv-p2 folder?
I've tried in Windows, Mac, and Ubuntu and can't get anywhere...
One thing is that compiler complains about a lot of QSTR strings that aren't defined anywhere...
RJ
HI Retrojeff
RJ
RJ
Or, if possible to provide a release with VGA basepin set to 8, maybe I could skip all this...
Actually, guess I'd need to change uSD pins too...
