Problem with SincN filtering in smartpins — Parallax Forums
evanhevanh Posts: 16,492
edited 2021-05-10 04:09 in Propeller 2
Chip,
With smartpin modes %11000 (P_ADC) or %11001 (P_ADC_EXT), problem occurs using WXPIN %01_xxxx (Sinc2 filtering) or %10_xxxx (Sinc3 filtering). I've discovered glitches in the decimation data from RDPIN when one of theses modes is active. It becomes more apparent with longer decimation periods but I think it is present at all times. It appears as sporadic extra bits. They tend to be at particular bit positions for a given setup. I've noted only high order bits so far, but can't rule them out at any position. The weirdest part is their occurrences are repeatable, like its somehow timing related. With Sinc2, 1024, and lower, bits (clocks) per decimation seems okay. Which is three octaves lower than your docs say should work. And I couldn't get any number of bits per decimation to be clean with Sinc3.
I've gone over and over my code to find any of my own bugs. I've even tested/verified my own understanding of the ADC hardware and SincN processing by using WXPIN %11_0101 (32 bit captures of the raw bitstream). Everything checks out so far. In fact I can reliably process right up to the limits of 32-bit registers with my own Sinc3 filtering. Namely, Sinc3 at 1024 bits per decimation sample works out fine.
EDIT: Here's my working code. It requires Fastspin and my wrapper code, so you'll probably want to write your own.
EDIT2: Small code adjustment
Update: As per below, it needs handled in software ... But is not a problem with the smartpin hardware. It is just what happens when summing mismatched integer widths with rollover. The solution is to either post-trim off the high bits in the larger integer or pre-scale the smaller integer up to the larger.
«13
    edited 2020-11-09 22:36
    Evanh, would it be possible to use the code in the P2 silicon documentation to test these modes?
    EDIT: I fixed the error in the programs below, where there were eight zeros in a row, where there should have been seven.
    SINC2 Filtering Mode (%01)
    This mode performs SINC2 filtering, which requires some software interaction in order to realize ADC samples.
    To begin SINC2 filtering:
           WRPIN   ##%100011_0000000_00_11000_0,#adcpin   'configure ADC+filter pin(s)
           WXPIN   #%01_0111,#adcpin                      'SINC2 filtering at 128 clocks
           DIRH    #adcpin                                'enable smart pin(s)
    Pin interaction must occur after each sample period, so it may be good to set up an event to detect the pin's IN going high:
           SETSE1  #%001<<6 + adcpin                      'SE1 triggers on pin high
    .loop  WAITSE1                                        'wait for sample period done
           RDPIN   x,#adcpin                              'get SINC2 accumulator
           SUB     x,diff                                 'compute sample
           ADD     diff,x                                 'update diff value
           SHR     x,#6                                   'justify 8-bit sample
           'use x here                                    'use sample somehow
           JMP     #.loop                                 'loop for next period
    x      RES     1                                      'sample value
    diff   RES     1                                      'diff value
    Note that it is necessary to shift the computed sample right by some number of bits to leave the ENOBs intact. For SINC2 filtering, you must shift right by LOG2(samples per period)-1, which in this case is LOG2(128)-1 = 6.
    SINC3 Filtering Mode (%10)
    This mode performs SINC3 filtering, which requires some software interaction in order to realize ADC samples.
    To begin SINC3 filtering:
           WXPIN   #%10_0111,#adcpin                      'SINC3 filtering at 128 clocks
           RDPIN   x,#adcpin                              'get SINC3 accumulator
           SUB     x,diff1                                'compute sample
           ADD     diff1,x                                'update diff1 value
           SUB     x,diff2                                'compute sample
           ADD     diff2,x                                'update diff2 value
           SHR     x,#7                                   'justify 14-bit sample
    diff1  RES     1                                      'diff1 value
    diff2  RES     1                                      'diff2 value
  • evanhevanh Posts: 16,492
    I'd want to add at least some debug printing to that. I'll need to get up to speed on PNut again ... I'm off to work right now ...
    edited 2020-11-09 04:16
    I dropped your Sinc3 example into my wrapper code and added only the print - it has all the hallmarks. It's probably one of the worst cases I've seen yet. Here's a short piece it produced: (Includes the SHR #7)
    000a4000
    01fb4080
    000dff80
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01f48080
    0005bf00
    00084100
    01fb3f80
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    00174080
    01f1ff80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00054080
    01f3ff80
    000a4000
    01fa4000
    01fa4000
    000a4000
    000a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01f80080
    00113f80
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00060080
    01f33f80
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01f8c080
    00007f80
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    0006c080
    00027f80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    00098080
    01efbf80
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00078080
    0001bf80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4080
    000eff80
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00038080
    0005bf80
    01ea4000
    001a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01f64080
    0002ff80
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00044080
    01f4ff80
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01f70080
    00123f80
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00050080
    00043f80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    001a4000
    01e7c080
    00117f80
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    0005c080
    00037f80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00088080
    01f0bf80
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    00068080
    0002bf80
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    01f94080
    000fff80
    01fa4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    000a4000
    01f28080
    01f6bf80
    001a4000
    01ea4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01f54080
    0013ff80
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00134080
    01e5ff80
    000a4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00060080
    01f33f80
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01f40080
    00053f80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    0006c080
    01f27f80
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    0014c080
    01f47f80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00078080
    0001bf80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    000a4000
    01fa4000
    01f58080
    0003bf80
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01f84080
    01f0ff80
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01f18080
    0007bf80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01f44080
    01f4ff80
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01f24080
    0006ff80
    01fa4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    00050080
    00043f80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    000a4000
    01ea4000
    00130080
    01f63f80
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    0005c080
    00037f80
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    0003c080
    01f57f80
    01fa4000
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    000a4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    00068080
    0002bf80
    000a4000
    01ea4000
    000a4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    00148080
    01f4bf80
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fdc080
    00033f00
    01fac100
    0001ff80
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01f08080
    0008bf80
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fe8080
    01fabf80
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01f14080
    0017ff80
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000f4080
    01e9ff80
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01f20080
    00173f80
    01ea4000
    000a4000
    000a4000
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01ea4000
    001a4000
    01f00080
    00093f80
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01ea4000
    0012c080
    00067f80
    01ea4000
    001a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    01fa4000
    000a4000
    000a4000
    01f0c080
    00087f80
    01fa4000
    01fa4000
    000a4000
    000a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    00038080
    01f5bf80
    000a4000
    000a4000
    01ea4000
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    000cc080
    01ec7f80
    000a4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    01fa4000
    000a4000
    01fa4000
    Okay, I've now added a buffer so that the loop timing isn't hindered by the print routine:
    _main
           WRPIN   ##%100011_00000000_00_11000_0,#adcpin  'configure ADC+filter pin(s)
    	mov	bcdlen, #8
    	wrfast	#0, ##$2000
    	mov	count, #50
           RDPIN   pa,#adcpin                             'get SINC3 accumulator
           SUB     pa,diff1                               'compute sample
           ADD     diff1,pa                               'update diff1 value
           SUB     pa,diff2                               'compute sample
           ADD     diff2,pa                               'update diff2 value
    '       SHR     pa,#7                                 'justify 14-bit sample
    	wflong	pa
    	djnz	count, #.loop                         'loop for next period
    	rdfast	#0, ##$2000
    	mov	count, #50
    .loop2
    	rflong	pa
    	call	#itoh
    	call	#putnl
    	djnz	count, #.loop2
    	jmp	#$
    diff1  long	0
    diff2  long	0
    count	long	0
    Here's the new output. It's more regular but still stupid readings.
    Total smartpins = 64   1111111111111111111111111111111111111111111111111111111111111111
    Rev B silicon.  Sysclock 100.0000 MHz
    00057580
    001aca80
    00200000
    00200000
    00200000
    00200000
    00200000
    00200000
    00200000
    00200000
    00200000
    f8200000
    08200000
    00200000
    00200000
    00200000
    f8200000
    08200000
    00200000
    00200000
    f8200000
    08200000
    00200000
    f8200000
    08200000
    f8200000
    08200000
    00200000
    f8200000
    08200000
    f8200000
    08200000
    f8200000
    08200000
    f8200000
    08200000
    f8200000
    08200000
    f8200000
    00200000
    08200000
    f8200000
    00200000
    08200000
    f8200000
    00200000
    08200000
    f8200000
    00200000
    00200000
  • AribaAriba Posts: 2,693
    Here is a testcode that works.
    There are erroneous bits in the 2 highest bits of the result, which need to get masked out.
    Chips code has en error in the ADC configuration, the second field from left should only have 7 zeroes, not 8.
    '' ADC sinc3 Test  by Ariba
      _clkfreq  = 180_000_000
      ADCPIN = 0
    var
      long  sample
    pub main()
      coginit(16, @adccog, @sample)                        'start ADC loop in new cog
      repeat
        waitms(300)
        debug(udec(sample))                                'show adc values in buffer
    DAT
            org  0
    adccog  WRPIN   ##%100011_0000000_00_11000_0,#ADCPIN   'configure ADC+filter pin, gain 1
            WXPIN   #7+32,#ADCPIN                          'SINC3 filtering at 128 clocks
            DIRH    #ADCPIN                                'enable smart pin
            SETSE1  #%001<<6 + ADCPIN                      'SE1 triggers on pin high
    .loop   WAITSE1                                        'wait for sample period done  1.4 MHz!
            RDPIN   x,#ADCPIN                              'get SINC3 accumulator
            AND     x,##$3FFFF                             'remove erroneous high bits
            WRLONG  x,ptra                                 'use sample somehow
    Andy
    Thanks Ariba. I'd not even tried to go over any of that. It brings the output back to a more recognisable state now. It has the glitches still but now it also has meaningful values in the mix too. eg:
    0000ce1f
    000d1917
    0018432e
    0017ae08
    0016b904
    0015e3d6
    00152ad0
    0014832f
    0013f310
    001374c6
    0013075a
    0012af33
    00125a41
    00120e58
    f811cde7
    081195ba
    001167f7
    00113c4e
    00111333
    0010f6f2
    f810daed
    0810c0f1
    0010a9c7
    001095f0
    001084ef
    f8107821
    08106abd
    00106052
    001056cd
    f8104d41
    081045dd
    001041c4
    00103cdc
    f81036b6
    0810322a
    00102f29
    f81029c8
    081027e0
    001023c0
    f8101f70
    08101e45
    00101da9
    f8101eae
    08101ccf
    00101b5e
    f81018ee
    08101897
    f81015bf
    08101474
    0010172e
    edited 2020-11-09 07:58
    Ariba,
    How to pass hubRAM buffer address with your example? I'd want to print consecutive samples like I've done with mine.
    EDIT: Oh, I think all I have to do is change "sample" into an array of longwords.
    Just make 'sample' an array: sample[1024] for example.
    You get the address in PTRA when you start the cog with @sample as 3rd parameter in coginit, as I have done.
    Have you added the AND instruction into the sinc3 filter loop?
    Andy
    Ariba wrote: »
    It's up to 5 high bits for me. That I can see anyway.
    Wow, that's cool, DEBUG() works inside the pasm code too!
    So, is there a problem, still?
    It sounds like I have a documentation error, at least.
    I got rid of the extra 0's in the Google Doc example programs.
    edited 2020-11-10 03:52
    The smartpins are still producing glitches, that hasn't changed. Andy's idea of masking them seems to work because, for Sinc3, they appear to only be in the five most significant bits. As long as those high bits aren't needed then it can work with an AND instruction tacked on.
    You can't go higher than 18 bits resolution, so the highest 5 bits will never be used. But I also wonder where this erroneous bits came from.
    Andy
    Right, yeah, it's starting to fall into place for me now. So the smartpin's Sinc3 accumulators are 27 bits each. And Sinc3 means the maximum decimation period is 2^(27 / 3 = 9) or 512 bit-clocks.
    So, I guess there is some kind of 27-bit vs 32-bit roll-over mismatch at play here. And the simple fix is to mask out the most significant five bits of the resulting 32-bit sample.
    edited 2020-11-10 06:01
    And I presume Sinc2 is 26-bit accumulators, therefore that will need the most significant six bits masked out.
    EDIT: Corrected the size.
    edited 2020-11-10 05:11
    So, hardware is probably okay after all. I guess we never tested a mismatch in register sizes when simulating SincX.
    I did test "pruning" the lower bits, which produced increased granularity, but not the upper bits.
    EDIT: Ha, I'll try just that, shift the decimated data up by five bits before diff'ing ...
    EDIT2: Yep, works without the mask then. No surprise I guess. Six of one, half a dozen of the other.
    Well, that mapping could have been integrated in the smartpin. That would've been nice if we'd been paying attention at the time.
    There's always something that slips past. At least it's not a show-stopper. Just a minor quirk ;)
    edited 2020-11-10 16:18
    Intriguing ... further testing reveals Sinc2 seems to produce 27-bit wide decimations, same as Sinc3. Same masking works for both modes.
    This means the Sinc2 decimation period can be a little more than the upper listed 8192 bit-clocks. I calculate up to 2^(27/2 = 13.5) or 11585 bit-clocks. This can be set with a WYPIN ... which I did without trouble. :)
    Chip,
    How was the effective number of bits calculated?
    My issue with pins P0-P3 has gone away - https://forums.parallax.com/discussion/comment/1502628/#Comment_1502628
    I figure it was an artefact of this glitch. Not that I can remember exactly what code I used at the time.
  • So, apart from too many zeros in a row in the Sinc2 program (now fixed) there is nothing wrong with SincX?
    edited 2020-11-11 18:27
    The software also needs to mask or bit-shift (normalise) the sample/decimation data.
    Using snippet of Chip's example:
           RDPIN   x,#adcpin                              'get SINC2 accumulator (27-bit wide)
           SHL     x,#5                          'justify/normalise to most-significant-bit
           SHR     x,#11                                  'justify 8-bit sample
    Or:
           AND     x,##$7FF_FFFF                 'remove erroneous high bits
  • evanh wrote: »
    Or:
    Saving one long and two cycles:
    Or:
           ZEROX   x,#27                         'remove erroneous high bits
    Cool, I'd never learnt ZEROX. I'll keep that one in mind for similar situations.
    edited 2020-11-13 04:30
    Detail correction, it's ZEROX x,#26
    And I do still have issues with me beleaguered glob-top part. When heated, it is exhibiting loss of VIO on certain pin groups. The ADC bitstream changes to either all high or all low. The normal packaged prop2 is giving good results when heated so I know it's not the software.
    I don't think it is a solder joint problem, or at least not at the prop2 package. I've tried a number of times now to touch up those supply pins, and the nearby VDDs too. And it's not the LDO regulators either since the other group of four pins supplied by each of those LDOs doesn't have an issue.
    Pity, since I was hoping to compare the two parts when mapping out all the ADCs.
    EDIT: Here's a piece of a report showing pins P48-P55. All powered from the same LDO regulator. P48-P51 are flatlined, while P52-P55 are normal. The values across the report alternate between GIO and VIO input source for the ADC. Each pair across uses a different method of sampling.
      P48    262144    262144  33553056  33553056         0         0  33554432  33554432
      P49         0         0         0         0         0         0         0         0
      P50         0         0         0         0         0         0         0         0
      P51         0         0         0         0         0         0         0         0
      P52     41909    213960   5363048  27389198   5368593  27388633   5386802  27401617
      P53     45927    220955   5880889  28275544   5884516  28275423   5875670  28264824
      P54     48958    223988   6269300  28668312   6266466  28669109   6265835  28647257
      P55     42524    215505   5445405  27587886   5448878  27584620   5436067  27598580
  • jmgjmg Posts: 15,191
    evanh wrote: »
    Could the higher thermal expansion of the glob, have stressed an inner bond wire to the point it has lifted, to be touching only ?
    That would match your symptoms.
    edited 2020-11-13 04:36
    jmg wrote: »
    Yeah, that's how I'm thinking too. I cooked the whole board pretty bad a while back when desoldering one of the USB power switch chips. The solder under the prop2 reflowed, and the board has a brown tint now.
    edited 2020-11-13 19:12
    Temperature signal of ADC drift from the VIO input is about 0.4% of full scale. So, down 8 bits to start. First brush, it's not particularly linear either. The slope gets shallower at higher temperatures. EDIT: It's in the region of 200 uV per degree centigrade.
