Can I just get a simple PDF of the P2 data sheet?
frank freedman
in Propeller 2
Trying to find some sort of info on the P2 resembling a datasheet, and so far only find a google doc which wants a google login to see more than the preview. Is there anything outside of the google doc? Or can parallax simply create a downloadable PDF from the google doc?
FF
FF
Here's a link to a pdf of the Spin2 documentation.
I hope these links work. If they don't, I'll try something different.
If you view the document online, you can right click on the document in the browser and select print, change the printer to PDF and save to a file.
Everything used to be so much simpler
You can also see my original version of the unofficial datasheet (in my sig) though which I might update later today along with the other stuff and add a lot of extra stuff now that we know what it is.
And if you need a PDF with bookmarks save as docx instead, load it into Word and save as PDF. There's a switch "include bookmarks" somewhere deep inside the sub-menus of Word. If you don't find it I have to look it up in an older thread here in the forum...
These two can be downloaded directly as PDFs, even on an ancient PC like mine, by changing the above URLs as follows:
https://docs.google.com/document/d/1gn6oaT5Ib7CytvlZHacmrSbVBJsD9t_-kmvjd7nUR6o/export?format=pdf
https://docs.google.com/spreadsheets/d/1_vJk-Ad569UMwgXTKTdfJkHYHpc1rZwxB-DcIiAZNdk/export?format=pdf
