New P2 Silicon
cgracey
Here is a link to the documentation for the new silicon:
https://docs.google.com/document/d/1gn6oaT5Ib7CytvlZHacmrSbVBJsD9t_-kmvjd7nUR6o/edit?usp=sharing
Here is a link to the instruction sheet for the new silicon:
https://docs.google.com/spreadsheets/d/1_vJk-Ad569UMwgXTKTdfJkHYHpc1rZwxB-DcIiAZNdk/edit?usp=sharing
Here are some current measurements on the old vs. new silicon:
The new silicon takes about half the power.
Here's the code that was running in the P2's:
I don't know how fast the new silicon can run because it keeps up with the PLL as it max's out around 390MHz at room temperature. I hit it with freeze spray and the frequency climbed to 435MHz! I couldn't get it any colder than that.
MHz+cogs vs I@1.8V P2 v1 P2 v2 v2/v1 -------------------------------------------------- 20MHz PLL, 1 cog 66 mA 29 mA 44% 20MHz PLL, 2 cogs 69 32 46% 20MHz PLL, 4 cogs 76 37 49% 20MHz PLL, 8 cogs 89 49 55% 40MHz PLL, 1 cog 129 55 43% 40MHz PLL, 2 cogs 136 61 45% 40MHz PLL, 4 cogs 148 72 49% 40MHz PLL, 8 cogs 175 94 54% 80MHz PLL, 1 cog 253 106 42% 80MHz PLL, 2 cogs 266 118 44% 80MHz PLL, 4 cogs 290 141 49% 80MHz PLL, 8 cogs 344 186 54% 160MHz PLL, 1 cog 497 208 42% 160MHz PLL, 2 cogs 521 231 44% 160MHz PLL, 4 cogs 570 275 48% 160MHz PLL, 8 cogs 672 365 54% 320MHz PLL, 1 cog 962 407 42% 320MHz PLL, 2 cogs 1010 455 45% 320MHz PLL, 4 cogs 1104 541 49% 320MHz PLL, 8 cogs 1295 718 55%
' ' Set PLL ' dat org hubset ##%1_000000_0000001111_1111_01_00 'alter waitx ##20_000_000/100 hubset ##%1_000000_0000001111_1111_01_11 'alter ' ' Launch n+1 cogs ' .loop coginit n,#@pgm 'launch cogs 7..0 djnf n,#.loop 'last iteration relaunches cog 0 n long 7 'set to 0, 1, 3, or 7 ' ' Program that runs in each cog ' org pgm cogid x add x,#56 .loop drvnot x jmp #.loop x res 1
Looks like the clock gating was worth the effort
Better numbers mean some P2 applications could use simpler LDOs.
So looks promising for hitting 250MHz for HDMI ?
That's just testing a loop ?
How does Cordic and more complex parts MAX out ?
What about the 64b CNT, does that run to PLL_MAX too ?
How many P2-ES2 samples can you test ?
MP8833 (prelim) 1.5A Thermoelectric Cooler Controller
Yeah, it was just a switch that Wendy enabled in the synthesis tool. It actually caused a net reduction of logic, since there were many flops which mux'd their outputs back into their inputs to realize an "ENA" signal. Those circuits were more numerous than the clock gates, and they almost all went away.
Congrats! Well done Chip!
Hey Tubular, it's dry ice time again.
I'm thinking most, if not all, of the speed gain is due to the lower die temperature from less heating, ie: Lower wattage produces a shallower gradient.
I think so, too.
If you could get a clock generator to drive 400MHz+ into XI, you could find the limit. As it is, the logic is always faster than the PLL.
Looks encouraging Chip.
We got to 372MHz on V1 blob top with dry ice.
It didn't last without cooling though.
Warmed up to 85°C, worked to 190 MHz sysclock (380 MHz PLL).
Any idea of what the phase noise is like on the PLL?
Again, congrats Chip! We all appreciate your hard work and vision of the P2.
My memory is we needed to use the dry ice to get the thing up and running (ie boot 8 cogs). Once up and running, it was mostly happy to continue on its way
We were also testing using P2D2's, which would be a little bit more thermally constrained
There's not a great amount of headroom but point is the PLL is not the limiting factor when DIVP=1. And I'm pretty sure Chip has tweaked the PLL performance in the v2 chip for the PLL to go even faster there.
The increased speed and massive power reduction is going to open up some interesting uses
With this clock speed it’s a shame we can’t throttle some of the cogs to half the speed of others. I know, there would be other hardware ramifications, but you cannot stop me from dreaming.
Now what is that 90nm P3 going to run at
I think Parallax should take a note out of CPU Proc Manf's playbook and get some LN2/cooler thing experiment going.
Just a small amount of $$ might make a nice ripple in the HaD/Maker-verse...
Heck, if Chip doesn't have the time, maybe forward a golden sample to someone on here who has the interest/skills to do it for you?
BTW) 350MHz is about the "reliable" limitation of the TSMC 180nm process. Your mileage may vary. When I built a Gigabit Ethernet chip for National Semiconductor, we used the same TSMC 180nm process. To achieve speeds of 1 Gig there were four clocks running at 250MHz with each of them locked to one another through a specific phase delay.
Name 800x600p60
Aspect Ratio 4:3
Pixel Clock 40.000 MHz
TMDS Clock 400.000 MHz
Well, few people really, which is why you can get 4:3 and 5:4 monitors of average quality fairly cheap. Altough those often don't have DVI / HDMI anyways.
Would 1080i work though?
