Missing Link
in BASIC Stamp
Any idea where I can get the file in this missing link http://www.parallax.com/dl/docs/prod/stamps/FwreRev0806.zip?
I have various hardware versions of the BS2 from C through J1. I know each time there is a component change the board is revised. However, this was the first time I've ever heard of firmware changes. I was just curious and looking for the FwreRev0806.zip file mentioned in the message.
https://forums.parallax.com/discussion/92902/versions-revisions-of-stamps.
I don't think there has been a firmware change in 15+ years. Everything should run under PBASIC 2.5.4.
Could you provide a picture of J1? Thats one I never heard of unless it's a Javelin chip.
Do you recall if you bought that J1 direct from Parallax sales? Or instead via ebay or somesuch?
Incidentally, J will be the newer one.
Best thing is to email support@parallax.com for an answer to that question.
https://www.parallax.com/downloads/basic-stamp-editor-software-windows
Von what's the noise in your background? Oh its a screaming cat named Bob. (As in bobcat, and he's outside not in.)
Mascot and Yak away.
The screaming cat's keep well away from our yard
J1 (or any number after the letter) usually denotes an internal-use prototype.
J becomes the full production version.
If you bought the J1 direct from Parallax Sales then it's certain J1 was a larger batch that passed production quality standards. (ie. the engineers got it right first time!).
Otherwise they might have been provided as samples or goodies at expo events, or someone involved in the testing process got a bunch and decided to share them via side channels.
Either way, you've got a nice collection which should be pretty rare. And if they work, then fantastic !
The different cap is just a batch/supply issue- depending on the capacitor availability for that build batch it may have been black or yellow, but will be the same specification part.
You sure about that? In engineering it is normal that J would come first, then J1, J2, etc or JA, JB, JB1, JC, etc. Never heard of a J1 preceeding a J tho'
