Propeller 2 OS - it's alive! And CPM2.2 is running!
 Cluso99
Cluso99
                    It's alive"
And so is CPM2.2
forums.parallax.com/discussion/comment/1500868/#Comment_1500868
Only DIR, LS, HELP and VER working so far
And so is CPM2.2
P2-Monitor V1.55
P2-SDDriver x212
SD:>dir
BOOT05M0.EEP     BOOT10M0.EEP     BOOTCUST.EEP     BOOTP8X2.EEP     BOOTV112.ZIP
BOOT_RB1.EEP     OS      .BIN     OSV114SC.ZIP     OSV114SD.ZIP     P8X2_SCH.PDF
P8X2_T03.BIN     P8X2_T03.ZIP     P8X2_USB.JPG     PIN_005A.OBJ     RESET_SD.OBJ
RESET_~1.SPI     SYSTEM~1.        _BOOTROM.OBJ     _BOOT_P2.BLU     _BOOT_P2.BUX
_BOOT_P2.BUY     _BOOT_P2.GRN     _BOOT_P2.RED     _BOOT_SD.OBJ     _CLEAR  .CMD
_CMD    .CMD     _CMD_   .CMD     _CODEGEN.CMD     _COPY   .CMD     _DEL    .CMD
_DIFF   .CMD     _DIR    .CMD     _DIRCPM .CMD     _DNLOAD .CMD     _DUMPFIL.CMD
_DUMPHUB.CMD     _DUMPSOB.CMD     _DUMPTOK.CMD     _ECHO   .CMD     _EEPROM .CMD
_FREE   .CMD     _GETCPM .CMD     _GETFAT .CMD     _HELP   .CMD     _HELP   .TXT
_LEX    .CMD     _LF     .CMD     _LINK   .CMD     _LS     .CMD     _MAPCPM .CMD
_OS     .CMD     _P2_LED_.BIX     _P2_LED_.BIY     _PUTCPM .CMD     _PUTFAT .CMD
_REBOOT .CMD     _REN    .CMD     _RUN    .CMD     _TESTSD .CMD     _TYPE   .CMD
_USED   .CMD     _VER    .CMD
SD:>ver
*** Cluso's Propeller 2 Operating System v2.??a***
 Originally derived from KyeDOS...
     by Kwabena W. Agyeman & J. Moxham & Cluso99
     & acknowledgements to M. Park (Sphinx) etc
 ClockFreq 297000000Hz, ClockMode $014D28FB, Cog 0
 SD card on pins 60,61,59,58
 Serial  on pins 63,62, Mode 00, Baud 00115200, Cog 0
 Screen size: 080 x 025
 <LF> is ON
 Resident Cogs :     This Cog: 0
 Cogs available: -1234567(=7)
SD:>
If we always remain in SPI mode the SD card can hopefully be re-initialized over and over this way after each reset without needing removal.
Yes we do need to check out SD reboot
copy (not working - bug), reboot (not converted), run (not converted)
Note that I've removed the cpm routines for now.
Speed will need improving but that can come later.
.BIX for binary files (.BIN on P1) that can be loaded and run using the "RUN" command, and will overwrite the OS.
.CMX for the binary command files (.CMD on P1) for OS programs such as "DIR" etc. "RUN" is not required to run OS progams.
Currently on P2 they (.CMX files) are in the one binary until I work out how to load them. By residing in separate files the OS can easily be extended without recompiling the master OS file(s).
This command lists the files within a CPM disk file held on the SD card.
In the CPM emulation, disks are held as a contiguous file (one per cpm disk drive) under the FAT32 file system. Each cpm drive (ie FAT32 file) is 8MB although some of these were created to be 32MB to permit possible later expansion in cpm.
Compile OS2.spin with pnut
You will need to copy _HELP2.TXT to the SD card to get help.
Commands that require parameters have their own simple help by just entering the command without any additional parameters. eg COPY
.sp2 for spin source
.bix for binaries (_BOOT_P2.BIX and _BOOT_P2/BIY are used in the ROM) see note below
.cm2 for OS command binaries
Note: I saw Eric use .biz for an OS test he did.
We should choose just one of .BIX .BIY .BIZ BI2 now!
For P1 I use
.spn for Sphinx (P1 spin source files)
.sob for Sphinx (spin objects while compiling spin)
.tok for Sphinx (tokens while compiling spin)
.bin for binaries
.cmd for OS command binaries
.dsk for CPM Disks (will be the same for P2)
Sphinx is Michael Parks P1 spin compiler and OS that runs on a P1.
I have converted this to run on my P1 OS but it was never thoroughly tested
Postedit
Updated Sphinx extensions
this is a really cool project. I will try it out!
Wuerfel, what is VentilatorOS?
(Also, while you're here, have you seen the cool Retronitus-related things I've made?)
Yes, add any .RAM or whatever you need. Would be great to get a list we all can use
Unfortunately haven't had any P1 time to look and try your modified P1 OS. What you've done sounds great!
When I get a bit further with my P2 OS perhaps we can work to improve it. Currently there is no optimisation or much error checking. It's a very basic conversion of the spin but because I cannot get any info from Chip, I'm at a loss (without decoding pnut/spin) to get to the next stage. Meanwhile, I have plenty to go on with.
The only thing that I don't want touched (for now) is the SD PASM driver. There are a number of gotchas in there that MUST be obeyed or the SD card fails/locks. And there are a few things I want to add. But substitution of the driver is fine with me.
Currently the serial/monitor calls remain in the same position as the ROM calls, except for the cog register usage which has been mandated to move by Chip's pnut/spin2. The hub code positioning will change later.
I don't have a P1 setup to try out VentilatorOS at the moment since I switched focus to the P2. But it sounds like cool additions to what Cluso and others have done. Nice team effort!
I have actually seen YouTube clips of your Retronitus compositions, but it's hard to tell what's changed just by hearing!
I had somehow missed these! NICE WORK! Very enjoyable chip tunes.
Can it still play this example tune I made for my latest release?
It's (only walking the tree and locating files in the FAT Directory table) all pasm and running in its' own cog...
And it's finding the Z80 CPM files
Yes.
Wordstar already runs on my P1 RamBlade plus lots of the other CPM2.2 programs too, including msbasic. The RamBlade has 512KB SRAM and uSD and fits in a matchbox.
clusos.com/home/ramblade/
This is the forum link but lots of things got lost in the forum upgrades.
https://forums.parallax.com/discussion/116893/ramblade-prop-sram-microsd-addon-to-run-zicog-cpm-propdos-catalina-etc/p1
BTW heater wrote the Z80 emulation (ZiCog) for P1. My P2 Z80 emulation is based more along the lines Pullmoll did in his qz80 which is a more thorough Z80 implementation which includes many of the undocumented instructions.
My Z80 implementation is running and works up to reading the SD card. I have the SD card driver already working in a separate program, so it's only a matter of combining the two programs together now. I should have that done in the next day or so
Each .cm2 would load into cog $0. They are compiled separately although they are aware of the resident hubexec code. This allows extension commands/programs without the need to recompile all OS commands and programs.
So it’s similar to CPM and DOS.
Standalone programs can be launched that take over the whole P2 - eg CPM takes over the whole P1 although my intention was to have CPM run as an OS command.
