PCB sockets
Mickster
I am looking at creating a PCB that accepts plug-in modules but I want the PCB female receptacles to be flush with the PCB as opposed to the protruding female headers.
Is this something that is standard for PCB manufacturers and if so, what are they referred to as? I can't seem to find this.
https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/322-HCS6P2-100/A100586CT-ND/2233065
Very very interesting
Oh, perfect! Now I'm excited.
Many thanks, Jim.
The Parallax P2ES accessory boards use this technique, eg you can see it here most clearly (the other accessory boards do it too)
https://www.parallax.com/product/64004-es
Yeah, never seen those before.
So they have a couple of locators for alignment and are retained by the solder tabs(?) Neat!
Bottom side and top side. They are 2-row through hole headers but the PCB is drilled for 1-row in each case.
Awesome, these things cost nothing.
@Tubular, many thanks. I still have a use for the other single sockets as well.
https://s.click.aliexpress.com/e/_BPDEgx
Interesting connectors. Thanks for sharing the link and photos of the board you're borrowing from.
Oh in that case, I'll show you what I'm up to.
I have a new system that I developed over the past year but it's all on proto-boards. To put it out in the market, I need professional packaging.
I want to use the Tibbo format but not their MCU so in this case I am replacing it with the MM+ Explorer 64.
It wouldn't take much to modify it for a Flip module
You gotta love pass-thru headers. I have seen many on boards I have made over the years where stacking multiple boards into a small space becomes crucial. For wave soldering, the style we have used have removable plastic pegs in the holes that get popped out after soldering. They prevent the flow of soldering from entering the contact area during wave. If need be, I can track down the part numbers.
We think that we have found the exact same as shown in the pictures (attached).
@"WBA Consulting"
I know that I'm not the only one who is constantly dreaming up ideas for Prop based products but project boxes, to me, scream "hobby-jobby".
Applications are there, coding is just a matter of doing it but not everyone wants to reinvent the interfaces.
Gotta do a P1 version. Ideal MCU for this concept.
Tibbo seems happy to sell pieces-parts sans motherboard so what the hey.
Heck, the @Cluso99 co-pro is a perfect fit.
These shells are like a bridge shape so no problem to link two or more together to bring out more I/O
But if he wanted to go completely flush to the component side of the board, he could try this:
https://keyelco.com/category.cfm/Micro-Pins-Jacks/Micro-Jacks/p/459/id/466/c_id/806
Be expensive and maybe labor intensive.
Yup. Same type I posted in the second post.
They are regular header pins and the Tibbit shell has enough standoff that the socket solder protrusions don't present a problem.
@"frank freedman"
Regards 1-row, 2-row, I had the exact same thought; rigidity or availability.
I am thinking availability because the 1-row is soldered on both sides.
Single row:
https://uk.farnell.com/wurth-elektronik/61301015721/connector-rcpt-10pos-1row-2-54mm/dp/2827899?st=Bottom entry header
Double row:
https://uk.farnell.com/wurth-elektronik/613024216921/connector-rcpt-24pos-2row-2-54mm/dp/2827962?st=Bottom entry header
Thanks again, guys.
