Safe to tie two (or three) P2 I/O pins together?
For testing out various ADC/DAC modes, seems like it'd be convenient to just jumper two P2 I/O pins together.
Is this safe?
I'm pretty sure I've had P1 pins shorted together and not break them (probably more than once).
I'm tempted to try it, but also afraid
Will you fry the pins/chip if one pin is driving high and the other is driving low?
Is this safe?
I think that is what is getting removed from Rev.C...
You are safe. I do it all the time.
I have made a custom P2 board which brings not all P2 pins to headers, so I just connected a few header pins to two P2 pins to be able to run some code and look at the output with a parallel running cog in scope mode.
