Safe to tie two (or three) P2 I/O pins together? — Parallax Forums
RaymanRayman Posts: 16,219
edited 2020-01-23 17:26 in Propeller 2
For testing out various ADC/DAC modes, seems like it'd be convenient to just jumper two P2 I/O pins together.
Is this safe?
I'm pretty sure I've had P1 pins shorted together and not break them (probably more than once).
I'm tempted to try it, but also afraid :)
Will you fry the pins/chip if one pin is driving high and the other is driving low?
  • cgraceycgracey Posts: 14,297
    It's fine. If you cause them to drive against each other, it would cause some power dissipation, of course. If it's a bunch of DACs outputting the same value, no extra power will be dissipated. ADC pins can be ganged together, too, but be careful at the higher magnifications, because their offsets will be different, causing their readings to pull from their individual centers.
  • you could use the smart pin feature of reading writing pins next to it without any jumpers...
  • RaymanRayman Posts: 16,219
    I think that would only work for digital signals...
    Oh, wait... There was something about inputting analog from neighboring pin...
    I think that is what is getting removed from Rev.C...
  • As mentioned above, yes it will probably work just fine, BUT In efforts to promote safe design habits you should just buffer it with something that can adequately provide the current requirement you desire.
    I'm just looking to make one an output and the other an input. But, wanted to know I'm safe in case I make a mistake...
    Rayman wrote: »
    You are safe. I do it all the time.
  • AribaAriba Posts: 2,697
    Good to know.
    I have made a custom P2 board which brings not all P2 pins to headers, so I just connected a few header pins to two P2 pins to be able to run some code and look at the output with a parallel running cog in scope mode.
    IIRC the smartpins can read adjacent (digital?) pins 3-4 either side of the real pin (total of 7 plus its' own).
