MMA7660FC accelerometer is eol
Tracy Allen
in Propeller 1
This is the accelerometer that is on the Parallax #20300 Badge WX, and on earlier incarnations of the badge too. I built it into a couple of projects on a contract and now my customer needs to populate 150 more boards. Aiiii, The bane of procurement, it went EOL last May, and none of the standard suppliers have any left. I'm just wondering, do you, anybody out there, have a any left over on tape or tray?
It is a 3x3mm DFN, and the replacement suggested by NXP is the MMA8653FC, which is 2x2mm DFN with a completely different pinout. We have the pcb fabs, so no rework.
Strips of 10 to be a pita for the CM. I can try to ask the Amazon seller if they have a reel and can cut longer strips.
I still have about 20 of these, loose in a box, but that is even worse for the CM.
https://forums.parallax.com/discussion/158176/cheap-compass-sensors-a-cautionary-tale
I can almost bet you've already thought on that solution, but, anyway...
If, by any reason you can't be confident on any other option, have you thinked about doing a very skinny/tiny 3X3 mm breakout pcb (interposer-alike), with castellated vias at its edges, so you can sandwich it between the 2X2 mm MMA8653FC DFN and the original land pattern of the MMA7660FC DFN package, in two operations?
Yanomani, the idea of making little castellated pyramid of a 2mm DFN on top of a 3mm rider is quite amusing! I wonder how one would go about making such a thing. I did consider making a rider, but I think it would have been larger and wired up to a couple of i2c bus test points on the pcb. Luckily that won't be necessary!
