Principe for Discrete Fouriertransform using cordic
Reinhard
in Propeller 2
I am an absolute P2 beginner and learn by myself with concrete examples the p2asm language.
some of them I like to share.
simple demo for a 8point DFT
show only the princip to do it with cordic
remember DFT
N-1
X[k] = sum (x[n] * exp(-j * 360° * n*k/N)) 0 <= k <= N-1
n=0
testcase: x[n(0...7)]= 100 0 0 0 0 0 0 0
expected: X[k(0...7)]= 100 100 100 100 100 100 100 100
proof: ok
metric: test with spinsim and analyse logfile
dat
orgh 200
samples res 8*2
org 0
mov ptra,##$200 'this is a testsignal (impuls)
wrword #100,ptra++ '8 samples a 16 bit
wrword #0,ptra++ 'normaly this input is from an adc
wrword #0,ptra++ 'impuls, because this has an
wrword #0,ptra++ 'known dft response (FT)
wrword #0,ptra++ 'make it easier to test w/o hardware
wrword #0,ptra++ 'if pulse | . . . . . . .
wrword #0,ptra++ 'the FT is | | | | | | | |
wrword #0,ptra++ 'the DC component is not calculated
'in this example
'because it is the simple sum
'of the input samples
mov s,#0 'at begin the shift operator is zero
mov k,#7 'calculate 7 frequency components
'btw. 3 was enough for real app
'4,5,6,7 are mirror or negative freq.
nop 'the DC component is not calculated
LP mov ptra,##$200 'point to first sample
mov arg,#0 'the twiddle factor starts at 0 degree
mov arg2,#0 'needed for temporary calculations
mov n,#8 '8 samples
mov sum_real,#0
mov sum_imag,#0
l1 rdword xn,ptra++ 'get next sample
qrotate xn,arg 'calculate x[n] * exp(-j * arg)
getqx x 'get real part
getqy y 'get imaginary part
add sum_real,x 'sum real
add sum_imag,y 'sum imaginary
add arg2,##$2000_0000 'increment the phase 45° 360/8
mov arg,arg2 '(8 point dft)
shl arg,s 'adjust the speed of rotation
djnz n,#l1 'all samples done ?
'(sum_real,sum_imag) can here go for
'further processing
'i.e. out to dac or serial or ...
'... build abs/arg with qvector
add s,#1 'increment the speed of rotation
djnz k,#LP 'all frequency components done?
nop
nop
sum_real res 1
sum_imag res 1
arg res 1
arg2 res 1
xn res 1
x res 1
y res 1
n res 1
s res 1
k res 1
Eventually, that can be recoded to feed the CORDIC every 8 clocks with scaled sine/cosine commands.
Yes, next I 'll try to interleave the cordic feed for performance.
But first I fixed a bug in my code and expand it to 256point DFT.
