HELP!!!!! p2 new board "Invalid hardware version 71 found on com 9" — Parallax Forums
I have been trying to get the new board running. Using peanut results in this error.
  • I tried to change com port to 12 but no joy.
    edited 2019-11-16 20:07
    What version PNUT are you using? You need v33k.:
    https://drive.google.com/file/d/1dOe3JPTZvcKvdE9SDOUSdMqM7BJ8Ixqk/view
  • @cgracey
    I am getting this error. Attempted to change com ports and that did not work. I cannot find this error on the internet. I just started to work with this board
    today. What is wrong.
    I found this on the internet:
    Error Message: The system cannot find the specified device
    Solution:
    1. Ensure that the right modem has been selected
    2. If it does not respond, try to reinstall it
    3. You can also try to reinstall NCP/DUN/RAS
    Error #71
    or this???
    Error #71
    Error Message: No more connections are allowed
    Solution:
    1. Someone else might have connected under your account
    2. If you have been ghosted on the server, your Internet Service Provider can bump the ghost program off
    I get a green led at the usb. Then the leds blink. Using spin2gui to load a program pins 60 and 61 leds blink. The serial terminal blinks out.
    Compared it to to rev A board, and all works.
  • @Publison
    Thanks I will try that.
  • SeairthSeairth Posts: 2,474
    edited 2019-11-16 20:52
    The message is telling you that it found a rev G (ASCII 71) chip, which is the latest revision. Publison is suggesting that you are using an older version of pnut that doesn't know about the latest revision. Are you using the version he referenced above?
    (edit: btw, since it's reporting that value back, it means you are definitely talking to the chip. so it's likely just a software/hardware version mismatch.)
  • @Publison
    That did it. Thanks. Did not see anything in the documentation regarding ver 33.
    @cgracey
    Publison fixed the problem.
    Thanks again to @Publison
