HELP!!!!! p2 new board "Invalid hardware version 71 found on com 9"
pilot0315
in Propeller 2
I have been trying to get the new board running. Using peanut results in this error.
https://drive.google.com/file/d/1dOe3JPTZvcKvdE9SDOUSdMqM7BJ8Ixqk/view
I am getting this error. Attempted to change com ports and that did not work. I cannot find this error on the internet. I just started to work with this board
today. What is wrong.
I found this on the internet:
Error Message: The system cannot find the specified device
Solution:
1. Ensure that the right modem has been selected
2. If it does not respond, try to reinstall it
3. You can also try to reinstall NCP/DUN/RAS
Error #71
or this???
Error #71
Error Message: No more connections are allowed
Solution:
1. Someone else might have connected under your account
2. If you have been ghosted on the server, your Internet Service Provider can bump the ghost program off
I get a green led at the usb. Then the leds blink. Using spin2gui to load a program pins 60 and 61 leds blink. The serial terminal blinks out.
Compared it to to rev A board, and all works.
Thanks I will try that.
(edit: btw, since it's reporting that value back, it means you are definitely talking to the chip. so it's likely just a software/hardware version mismatch.)
That did it. Thanks. Did not see anything in the documentation regarding ver 33.
@cgracey
Publison fixed the problem.
Thanks again to @Publison
