How to use the mic on PropBOE
in Propeller 1
I have an interesting project involving frequency detection and isolation(audible).
I need a driver of spin/pasm type. I also need info.
If you mean producing a real time Fourier transform display on VGA using the P1 (or even P2) I think you will find that it does not have the number crunching horsepower to accomplish the task. Even using the FFT would most likely be more than it can do.
That might be possible if you use filters to separate the frequencies and ADC's to measure the power of each band. That requires a lot of filter and ADC circuitry for 50 channels though. Typical high end HiFi units use fewer bands with different band widths for each range.
EDIT - I wonder if there is a reasonably priced DSP available to do this.
Yes, something like that would work, however since many adc's come in 8 channel versions using a multiple of 8 channels might be a good idea. Perhaps a modular design using a small board with 8 filters and an 8 channel adc. That way you could add additional boards to increase the number of channels and use a dedicated cog for each board if required.
I have blank tht proto boards in my drawer, about 30x17 holes, 2.54mm spacing. Just need to source some adcs and some filters!
