"Robby the Robot and Altaira from the Classic Movie - Forbidden Planet (1956)" - Basic Stamp Control
 mtrappett
mtrappett
I used a Parallax Basic Stamp, fiber-optics and LEDs to provide the illumination for Robby. The Basic Stamp I programmed to control the sequencing of all the lights.
Forbidden Planet I think was such an awesome movie, especially considering the year it was filmed. Robby the Robot is the quintessential robot of all time together with others such as R2D2, and so on. I watched this when I was a kid, and it inspired me to build this model. The Basic Stamp provided a wonderful means of controlling everything on the robot!
Hope you like it! :-)
Welcome to the Forums! Awesome project!
Thank you!
Thank you, and I am pleased you like it!! I made a quick video of it.
WOW! I'm a fan!
Look at youtube for user DUST, he is collecting nice SCIFY short films
here some nice example
Very good localroger. Now how quickly can you leave for New Chicago? The prize is one week there.
Did you by chance look up my reference in "The West End Horror" as written by Nicholas Meyer (but writing as Doctor Watson)? Sherlock explains that the costumes for the productions of the Tempest were very expensive, and thus the scenery did get rather wet and those costumes were too expensive to replace every time. Incidentally in the scene, the victim is pointing to a scene in Romeo and Juliet where Mercutio calls out "A plague on both your houses!" before he dies? Its there where my reference takes place.
And this message is being sponsored by the New Chicago offices of the local planetary government.
Can you do me a favor and explain your excellent circuit there? And is that the battery box with the switch on it? If that's the case then it is upside down, the switch is on the top, and the battery box screw is on the bottom.
What steps did you take to reach that conclusion? And did you by chance read the book that I was thinking of? (I deleted my original response before sending it.)
I know what you mean! I loved Forbidden Planet... actually still do. I think it is a time-less classic, and yes, I agree that it is the definition of Sci-Fi. I think they got it all exactly right. It also has a creepy kind of feel to it with the excellent electronic music that in my view adds to it so much. I think the monster from the ID was also really well done thanks to some work from the Walt Disney Studios.
Thanks again for your nice comments
Sure, no problem. I programmed the Basic Stamp to generate outputs to drive the LEDs. The program basically sequences the LEDs according to the timing I noted down from Robby in the movie. The Stamp's outputs are unable to drive multiple LEDs without causing possible damage. I took a look at the specs at the time and it appears that one LED is the maximum that it can handle safely. I used a opto-isolator chip that in effect amplifies the output current enough to drive several LEDs at once. You are correct, the plastic case holds the battery and yes, that is the main switch that powers it all on. I built a simple base to house all the electronics from cardboard and painted it to match the plastic base from the kit. Hope that helps a bit?
I found Forbidden Planet the best method around to properly tell the story of the Tempest for our time.
Um, erco, what prompted both cats to be watching you? (Plus the twin girls.)
