Propeller Mini — Parallax Forums
Propeller Mini
I have an application where I only have 5 volts available to the Propeller Mini. I do not need the 5 volts from the 'on board 5v regulator'. Do you think I could remove/bypass the on board 5v regulator and use my supply's 5 volt output connected to the on board 3.3v regulator to power the processor?
