Propeller Mini
in Propeller 1
I have an application where I only have 5 volts available to the Propeller Mini. I do not need the 5 volts from the 'on board 5v regulator'. Do you think I could remove/bypass the on board 5v regulator and use my supply's 5 volt output connected to the on board 3.3v regulator to power the processor?
One of the referenced threads was renamed, so the links don't work. It's here:
https://forums.parallax.com/discussion/152334/neopixel-christmas-ornament-was-prop-mini-power-supply/
Have you checked the regulator datasheets as not all regulators can withstand voltages on their outputs above the voltage on their inputs. particularly some older regulators would fail.
