fastspin Geany
in Propeller 1
On my Win 10 Pro box, I setup Geany to work with fastspin.
For the moment it is a very crude Geany fastspin. The one good thing is that with Geany, when you use .bas file it sets up for a freeBasic session, so all you have to do is manually change the Geany build commands to work with fastspin. So far I have it using the Compile correctly, and I added a 'Load EEPROM' command, which works. And the Geany Execute command also works correctly.
It is still somewhat cumbersome because you have to manually change the Build commands if you want to change the port selection. Plus now I have to figure out how to add an intuitive Optimization selection.
Since Geany also is available on Linux, does anybody know what fastspin, proploader files I should use for the Linux version of Geany? All I have seen so far are fastspin.exe and proploader.exe files.
Ray
Ray
The harder part is to get fastspin working with Geany in the Linux version. It sort looks like you have to compile the fastspin and proploader code, in some kind of Linux C compiler. I will have to think about doing that.
Ray
git clone https://github.com/totalspectrum/spin2cpp
cd spin2cpp
make
on my Linux system. I found the 'fastspin' in the build folder, did a quick ./fastspin -b test1.bas. It did a compile of the test1.bas, so that part worked, I think.
I looked for 'proploader' in the build folder, but there wasn't one there. Now I need to figure out how to run the test1.binary on the Linux system.
When looking through the spin2cpp folder, I did see a 'propeller-load.exe' file in there, not sure why that would be there. I do have SimpleIDE installed on the Linux system, but it will not run .binary file, only .side files. Anybody have any suggestions how to resolve this issue.
Ray
Indeed, both are available, as well as proploader
propeller-load: http://david.zemon.name:8111/project.html?projectId=PropellerLoad&tab=projectOverview&guest=1
proploader: http://david.zemon.name:8111/project.html?projectId=PropLoader&tab=projectOverview&guest=1
Spin2cpp & FastSpin: http://david.zemon.name:8111/project.html?projectId=Spin2Cpp&tab=projectOverview&guest=1
List of all projects: http://david.zemon.name:8111?guest=1
Ray
I guess I could just do a bash script to do the fastspin compile/load, and also use just a Linux editor to create the file. I also loaded Visual Studio Code to the Linux box, but that looks quite complicated and I am not sure if it does any compiling of files. Or maybe I should create a small Python program with Tkinter, to automate the compile/load process. Maybe I will come across a Linux editor that can run the proposed Python program.
Ray
