How to use Smart Pin for ADC?
in Propeller 2
I am trying to understand how the Smart Pins work (and how to use them).
I want to use a smart pin (let's say a pin(s) P5 to P7) to measure the voltage from a simple potentiometer circuit.
I have the potentiometer wired to +3.3v and GND. The wiper will be connected to the Smart Pin.
1. Do I need anything else connected?
2. What would be the command to configure the Smart Pin? (in either Spin2/P2ASM or TAQOZ or fastspin basic.)
3. What would be the procedure to read the voltage?
4. I assume that I can't connect voltages greater than 3.3v (without using voltage dividers), is that correct.
5. Anything else I am missing?
I appreciate your help
Tom
Tom
2a. WRPIN ##%100_000_0000000_00_01111_0, #adcpin
2b. WYPIN #0, #adcpin
2c. WXPIN #0, #adcpin
2d. DIRH #adcpin
3a. RDPIN sample, #adcpin
3b. SUB sample, diff1
3c. ADD diff1, sample
4. You can go over/under the power rails by about 0.3 volts without the protection clamps distorting the signal.
5a. Details are in the main google doc that Chip maintains: https://forums.parallax.com/discussion/162298/prop2-fpga-files-updated-2-june-2018-final-version-32i/p1
Peter has posted a PDF of the current version: https://forums.parallax.com/discussion/comment/1461234/#Comment_1461234
And here's the details I put together about the real pad I/O config'ing: https://forums.parallax.com/discussion/comment/1452036/#Comment_1452036
5b. My example there doesn't use a sampling trigger, so it is a rolling value that you have to do the diff'ing on. If you setup a sampling trigger, with a non-zero WXPIN and monitoring of IN, then the hardware will do the diff'ing and give you the final sample.
EDIT: Typo on the mode
Thanks, I'll have to read this over a few times and read the links you posted with your comments as examples. I'm sure I'll have questions once I try this.
Tom
Mode %100_011_0000000_00_01111_0 will read the A input (ie the pin normally) - use that
Mode %100_001_0000000_00_01111_0 is Vio calibration
Mode %100_010_0000000_00_01111_0 will read the B input (ie the pin normally)
In P2ASM:
CON OSCMODE = $010c3f04 FREQ = 160_000_000 BAUD = 115200 ADC_MODE = %0000_0000_000_100011_0000000_00_01111_0 ADC_PIN = 48 ADC_CYCLES = 1600 OBJ ser: "SmartSerial.spin2" VAR long value PUB demo | i, a clkset(OSCMODE, freq) ser.start (63, 62, 0, BAUD) ser.str (string ("Hello ADC")) ser.tx (13) ser.tx (10) pausems (1000) adc_addr := @value cognew (@adc_read) repeat pausems (100) ser.dec (value) ser.tx (13) ser.tx (10) DAT org 0 adc_read wrpin ##ADC_MODE, #ADC_PIN wxpin ##ADC_CYCLES, #ADC_PIN wypin ##0, #ADC_PIN dirh ##ADC_PIN getct time addct1 time, ##ADC_CYCLES .loop waitct1 addct1 time, ##ADC_CYCLES rdpin val, #ADC_PIN wrlong val, adc_addr ' store output jmp #.loop adc_addr long 0 diff long 0 time res 1 val res 1
Thanks, seeing a full demo really helps me see what is going on.
Tom
I also found that I needed to do a calibration to find the min and max values corresponding to 0 and 3.3v. Those are valmin and valmax in the code. The ones that are commented out are the ones for ADC_CYCLES = 1600.
Is that expected?
How did you select 1600?
Does increasing the cycles increase the bits accuracy of the value?
Thanks again,
Tom
CON OSCMODE = $010c3f04 FREQ = 160_000_000 BAUD = 2000000 ADC_MODE = %0000_0000_000_100011_0000000_00_01111_0 ADC_PIN = 22 ADC_CYCLES = 2047 ' 1600 'valmin = 270 'valmax = 1305 valmin = 351 valmax = 1670 OBJ ser: "SmartSerial.spin2" VAR long value PUB demo | i, a clkset(OSCMODE, freq) ser.start (63, 62, 0, BAUD) ser.str (string ("Hello ADC")) ser.tx (13) ser.tx (10) pausems (1000) adc_addr := @value cognew (@adc_read) repeat pausems (100) ser.dec (value) ser.tx (13) ser.tx (10) ser.dec (0 #>(value - valmin) * 330 / (valmax - valmin)<# 330) ser.tx (13) ser.tx (10) ser.tx (13) ser.tx (10) DAT org 0 adc_read wrpin ##ADC_MODE, #ADC_PIN wxpin ##ADC_CYCLES, #ADC_PIN wypin ##0, #ADC_PIN dirh ##ADC_PIN getct time addct1 time, ##ADC_CYCLES .loop waitct1 addct1 time, ##ADC_CYCLES rdpin val, #ADC_PIN wrlong val, adc_addr ' store output jmp #.loop adc_addr long 0 diff long 0 time res 1 val res 1
Yes, it's a trade-off between resolution and speed. The longer the sample period is the more bits are collected and, like doing a bigger average, the more precise the result is.
particular reason
Your measurement loop should periodically run the calibrate step on every ADC pin.
There is enough variation that using another channel to calibrate is less useful.
Broadly, yes, but above some point, 1/f noise means longer sample times do not give much noise benefit.
You might choose a sample size/rate that helps reduce unwanted coupled noise from mains or a SMPS.
wrpin ##ADC_MODE, #ADC_PIN where ADC_MODE = %0000_0000_000_100011_0000000_00_01111_0
Parallax Propeller 2 Documentation v32 dated 2018-09-01from the P2-ES product page explains the 32 bit D field for the wrpin instruction.I don't understand the "P" bits described in the document compared with the
100011_0000000
in the command above. The documentation only describes P12:P10 equal to %101, but I couldn't see anything for P12:P10 = %100.I also don't understand how field MMMMM = %01111 is an adc mode. I see that it increases when A is high for a period of time, and that is how a Sigma Delta ADC works, but I don't see how a Sigma Delta is configured. I would have thought that based on the description of the TT field that ADC would have been enabled through a DAC mode?
I would appreciate it if someone could explain how the D field of wrpin is set up (for example for ADC mode). What does each field mean? Is there newer documentation, or do I just lack understanding?
Thanks for your help
Tom
My best attempt at filling this in is here - https://forums.parallax.com/discussion/comment/1452036/#Comment_1452036
EDIT: And you'll find the ADC sigma-delta modulator config in that same %P...P details.
Tom
they are pretty much identically sensitive to crosstalk noise, so I am guessing the ADC has constant
current sensitivity but the input resistor is being switched in the different modes. So presumably the
input impedance gets lower with each step increase in sensitivity?
I couldn't find any documentation of the input impedances for the ADC modes, I'm wondering
what they are nominally, and what relative accuracy they have?
My other question I have is what happens if I change just the input pin selector in the pin mode whilst
setup for ADC conversion - does this interrupt the behaviour, or is this a valid way to implement analog
switching of the ADC within a sampling period (I'm thinking of down-conversion of a differential signal).
Regarding impedances, Chip did say the higher gains have lower internal impedance. But they don't appear to the input though. It's built with lots of transistors and capacitors. I'm not sure if there is any resistors. It was spoken of in that big filter topic when Chip went to town adding even more than intended.
Excellent - I did wonder if whether transmission gates were used (I should never have doubted Chip!)
Should be easy to measure, with a current meter to GND/VIO.
That gives the feedback resistor value, and shows pin-pin variations, and temperature variations.
The input resistors are a ratio down from that. Tempco from a resistor ratio will be somewhat better than the resistor alone.
because this is sigma-delta, I'd image that is live. Main issue would be if something else was reset by a write to the config ?
Chip posted a circuit some time ago IIRC.
I think that has resistors straight to the pin, and analog switches select different resistors and include the CAL resistors to VIO and GND (note not the same resistor is used),
Easy enough to check, with a meter and a signal generator with a larger series resistor, to find the Pin-bias point (50% VIO) and the effective pin-loading with gain.
I think the ADC will work best with lowest impedance external drive, and that reduces crosstalk too.
Yes, adjacent is Digital only, so if you need same-pin analog you will need an external switch.
Something like a HC4052 would also be good for carrier sync Rx of low levels, because it switches and filters outside of the P2 die.
PS: I'm hesitant to say the bitstream is the IN signal. Not because it isn't but because it has to pass through both the digital input selector and smartpin before presenting as IN to the cogs and streamers.
You can bring pin B across as an analog, but only 1x (no x3 x10 x30 x100 etc)
Whether thats useful for your mixer, I don't know
https://forums.parallax.com/discussion/download/124079/Prop2_ADC_functional.png
