float to string
in Propeller 1
I'm having a problem "intercepting" values from gps code i found on parallax site. The code works and puts the correct lat./lon. values in the serial terminal. I want to be able to use the same values for lat/lon that are displayed in the serial terminal to do calculations for other sections of code. The correct lat. is 42.32377. When i try to do float math with (fv) or debug.dec, i get 10 digit,4 digit, or just numbers other than the 42.32377. I've done a lot of reading and having a problem figuring it out.
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
OBJ
Debug : "FullDuplexSerialPlus"
GPS : "GPS_Float_Lite"
FS : "FloatString"
PUB Init | fv
'Start FullDuplexSerialPlus terminal
Debug.Start(31, 30, 0, 115200)
Debug.Str(String("Reading GPS..."))
WaitCnt(ClkFreq * 2 + Cnt)
'Start GPS object, GPS connected to P7
GPS.Init
Repeat
Debug.Str(String(16, 1))
FS.SetPrecision(7)
fv := GPS.Float_Latitude_Deg ' Get latitude
If fv <> floatNaN
Debug.Str(FS.FloatToString(fv)) '''''this line will print the correct latitude: 42.32377'''''''''''''''''
Else
Debug.Str(String("---"))
Debug.Str(String(","))
fv := GPS.Float_Longitude_Deg ' Get longitude
If fv <> floatNaN
Else
WaitCnt(ClkFreq / 2 + ClkFreq / 4 + Cnt)
DAT
floatNaN LONG $7FFF_FFFF 'Means Not a Number
PS, the last forum migration broke numerous links in my thread, so I will have to work on fixing those at some point. I guess I should download all of my text from the forums to preserve the content as well as all of my referenced threads....
