Google Earth GPS SD Card Logger - COMPLETE!
Hi All,
As my apparent obsession with GPS continues, I have created this Google Earth SD Card Logger for you all to play with. This will create GPS logs that are directly usable in Google earth with no additional processing. I have copied a test log KML file for those without SD card hardware and an image from Google Earth as well.
You will notice that the 3D plot sometimes disappears below the ground image. This is because of the accuracy of GPS altitude. Is it often 'off' by more than a meter. Since I was riding a bike around the block to collect data, an error of -1m could easily put the line underground. To see all data in GE, right click DATALOG at the left menu at the bottom, and select PROPERTIES, then play with the altitude settings.
Enjoy,
Paul
*** UPDATE - the .kml file is in the ZIP. the forums software won't let me post .kmls directly. ***
Post Edited (Paul_H) : 6/5/2008 5:10:32 AM GMT
Enjoy,
Paul
I Can't wait to compare the 2!!
Rick-
Hunger hurts, starvation works!
@csfan - Good catch - I hadn't tried this with my old etrex but the mode has tripped me up in the past.
Have Fun!
Paul
I remember a few years back now (which was way before google earth.), I reverse engineering the Microsoft Flight Sim 2002 VFR aerial photography add on packs, and figured out the filename structure, and the file contents [noparse];)[/noparse] and re-packed them even smaller, and put all of england and wales textures onto a 4GB ( largest CF at the time and cost a £200 about $400 ) and wrote a Pocket PC app for my compaq [noparse];)[/noparse] to display the textures in 2D and 3D and reading my navman gps data, and allowing me to have the first (that I know of, as even to this day, tomtom still doesn't have it) satnav with aerial photography. [noparse]:)[/noparse]
Seeing your pic reminded me of it [noparse]:)[/noparse] great fun isn't it.
Baggers.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
Graham
I have a version of same that runs on a Mac... but my EX... is a Windows only girl and I didn't have a clue what to do next.
Perfect.
When I ran the KML file on a Mac I get an error message: Fetch of networkling 0103231221 failed, etc. etc.
So... at least on a Mac you have to have Google Earth up and running first
... so cool.
Rich
Baggers,
Sorry to hear that you are not available. But I completely agree with you about Jeremy Clarkson.
...http://asadodo.blogspot.com/2006/09/jeremy-clarkson-1960-2006.html
I have written to Mr. Clarkson to recommend that once he has taken his rightful office that he tap you to help him re-shuffle the Bank of England. You are going to need a Prop-based economic simulation: Think of a Lada, with an ejection seat, hitting a wall at 100 knots.
Post Edited (rjo_) : 6/6/2008 1:55:02 AM GMT
Actually bought a propeller to try (after learning how to talk to it!) and build something very much like this.
I'd like to have a real time map overlay (the kml part of this) that would provide position along with sensor data (say temperature as a start).
As a step toward that - and a way to resolve the altitude issue, could you set the line color to the elevation in the kml, while plotting the line flat against the topography?
Why not build an add-on for your GPS to do XYZ accelerometers and yaw gyros? Put in some XYZ magnetic heading sensors and you can get much better accuracy
(using a kalman filter) than you ever would with a stand-alone GPS receiver (plus if you lost "3D" tracking from the sky - the kalman filter would bias towards the
inertial information from the accelerometers).
My 2 cents...
-Tim
P.S. if you frankenstien a digital camera to hook it up to the Propeller, you can have it take pictures at intervals, and with time stamps from the GPS you can either later add geotagging info to the pictures... -T
@Baggers - We must be too old - The "I remember when..." stories that I heard usually involved walking uphill both ways to school, and never involved reverse-engineering of anything! But your point is absolutely on point - This IS Fun!!
@Chris is correct about the options in the header.txt file. You can change these to look anyway you like the GE maps to be displayed. I went with simple and small for my use, but if you study up on KML, you can mod the headers to your preferences. I had considered embedding the KML in a DAT records which would greatly improve speed but not be easily adjustable in the field, or allow much onboard memory for anything else.
@Vampyre & Tim - You may like to see my main project site for my UAV at www.pnav.net. I already fly first person with a camera onboard from the pilot's perspective, and will have some of the automation put into the projects like an OSD/HUD overlay on the live feed, etc. I do like the suggestions.
thanks all!
Paul
Jim.
I think there is a bug here in Europe.
The klm file is +/- right for latitude but wrong for longitude
I life in Anwerp (Belgium) but with this code i am in the sea near uk !
>On the video I have 5110.0072 lat and 00426.9009 lon
>On a garmin gps N 51°09.998' and E 004°26.913
>On google Earth 51.166720 and 4.448401
On the same hardweare i use gps-float-lite demo an d have:
> 51.11678 and 4.448414
pice of klm code
>"<tessellate>1</tessellate>
<altitudeMode>absolute</altitudeMode>
<coordinates>-04.448431,51.166779,25.4 -04.448433,51.166787,25.8 -04.448439,51.166789,25.2 -04.448444,51.166786,24.7 -04.448433,51.166779,24.9
04.448426,51.166759,21.5 -04.448431,51.166762,21.2 -04.448438,51.166756,19.9 "
Any sugestion
Found:
On line 158 : SDwrite(string("+")) ' Correct sign for Europe hemisphere, manually for now
Post Edited (Ltech) : 5/23/2009 10:56:37 AM GMT
My Nikon D200 has a jack on it to connect to my remote control and Garmin 60CSX. I can program the camera to take pictures at intervals of up to 5 pictures per second and it will automatically tag the photos with the GPS cowardinatants, number of satellites used, and estimated accuracy.
Still that is about $1900 worth of equipment(not including lens). The prop could make much cheaper I am sure.
propmod_us are now in stock. propmod_1x1 arrive on 26th. Only $30
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
When I am at 38.775919, -121.358600
It logs "- 21.358600,38.775919,00032.8"
So it seems it is dropping the 1 from the 121 and the lat/lon are swapped???? When I load the KML file from my ride home from work, it says I was in the middle of the Red Sea. it was raining, but not that bad...
Any advice on where to start looking for fixes? I will be looking at what LTech found.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
That GPS app sounds like a realy awsome project, I will try it some time in the near future. For now it seems a bit above me. im still trying to figger out how to get the prop to read the parallax GPS in "smart mode"
its great to see ppl realy going full tilt on this stuff though. I hope that oneday I will come up with somthing as cool as this
DD := num.ToStr(atoi(gps.longitude,3),Num#DEC3) ' whole degrees - DEC# is the number of digits needed in the string SDwrite(string("-")) ' Correct sign for western hemisphere, manually for now if atoi(gps.longitude,3) > 99 ' Write whole characters to the file that's open. sdfat.pputc(byte[noparse][[/noparse]DD+0]) ' Write hundreds IF applicableIn digging into the atoi (format.spin) and ToStr (numbers.spin) callouts, it appears the first line in the code above will convert "-121" to "121" then dump the first digit leaving a space. So, even though "atoi(gps.longitude,3)" is "> 99", the next line of code writes a space to the SD card instead of a 1.
I think that's correct, but I will need to look at it some more. If I am right though, I don't know how to fix it.
Andrew Williams
WBA Consulting
Now it's time to start working on the code to have it verify it's location from stored data for the Reverse Geo-Cache Project
update:
NOTE: The attached code (final version 006) does not create a properly formatted KML file (see my next post).
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 12/17/2009 8:22:30 PM GMT
One thing I discovered is that the longitude should be first, not second like I thought was the bug. So the coordinate data should look like:
which is longitude, latitude, altitude, then a space (no spaces between data, only between coordinate chunks(technical term))
I also found out that the altitude is not required and when it is used, you cannot use the absolute mode of altitude formatting if you also have tesselate set to 1. So, I changed the altitude mode to "ClampToGround".
I'll be updating my program when I get a chance and post updated code with a propeller created KML file.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 12/17/2009 8:23:39 PM GMT
Andrew Williams
WBA Consulting
UPDATE: I have now confirmed it was my setup. It went away when I put the GPS module onto my PPDB. With nothing underneath it now but the breadboard, I get a solid GPS lock inside the house near the front window.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 12/19/2009 9:53:12 AM GMT
Wow - I'm glad to see the code is still getting used a year later
Paul
