New BASIC compiler for Prop1 and Prop2 - Page 11 — Parallax Forums
18911131420
  • Thanks for the debugging suggestions. I'll certainly keep those in mind going forward. My initial focus is on getting the language compilers for Spin, BASIC, and C done, and then adding more features after that.
    Speaking of which, it feels like the BASIC language is pretty much "done", except for adding libraries. Have I missed any features in BASIC that anyone would use?
  • RaymanRayman Posts: 15,241
    It looks like all the required source files have to be in the same folder.
    The Prop tool has a library folder that it also searches for source.
    Maybe this is fine as is. I guess in C++, I keep everything in one folder (except the build output goes into a different folder).
  • yetiyeti Posts: 819
    edited 2018-11-10 16:34
    Rayman wrote: »
    Look for FastSpin's "-I" or "-L" option.
    $ fastspin -O2 -L /opt/parallax.spin.src/spin mandelbrot-fixed16-vga-512x384x1.bas
    Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2018 Total Spectrum Software Inc.
    Version 3.9.10-beta-6f57b5b Compiled on: Nov 10 2018
    |-VGA_512x384_Bitmap.spin
    mandelbrot-fixed16-vga-512x384x1.pasm
    Done.
    Program size is 26640 bytes
    Perfect, thanks.
    edited 2018-11-10 23:17
    I think I just noticed fastspin just exit when code has a problem...
    I was comparing output from bad code between different compilers...
    Anyway, I put a "t" at the end of this code and fastspin just exits without any error messages:
    it does work from command line...
    Not sure what's going on... When I pipe the output to a file, I don't get the error in the output file...
    But, I do get error message on command line...
    C:\Users\Ray>cmd.exe  /C ""D:\Propeller\Code\SpinEdit\Debug\fastspin.exe" -L "C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Library"   "D:\Propeller\Code\SpinEdit\temp\Test1.spin" > "D:\Propeller\Code\SpinEdit\Debug\FastSpin.out""
    D:\Propeller\Code\SpinEdit\temp\Test1.spin(18) error: Unknown symbol T
  • Rayman wrote: »
    Well no, not in general. Normally it prints an error message. As you noticed later it does print an error message, but it's to the standard error output rather than the regular output.
    There are two different output streams in Windows: stdout (standard output) and stderr (standard error messages). The > redirection symbol only redirects stdout. To redirect stderr as well you have to use something like:
    C:\Users\Ray>cmd.exe  /C ""D:\Propeller\Code\SpinEdit\Debug\fastspin.exe" -L "C:\Program Files (x86)\Parallax Inc\Propeller Tool v1.3.2\Library"   "D:\Propeller\Code\SpinEdit\temp\Test1.spin" > "D:\Propeller\Code\SpinEdit\Debug\FastSpin.out"" 2>&1
    The "2>&1" says to redirect stderr (handle 2) the same was as stdout (handle 1). The same syntax is used in Linux and the Mac too.
    I see that openspin outputs everything to stdout. I guess I understand why, but having error messages go to stderr is more usual, and many other compilers (like gcc) do it that way.
    That works! thanks.
    OpenSpin and bstc and propellent don't act this way, but I'm glad it's an easy fix.
  • @ersmith,
    2>&1 this one is cool. I always redirected 2> into a second file. Never heard about &1.
    I think I just noticed that a quote character, when not the first character on a line, also indicates a comment. Is this right?
    It doesn't give an error, but not sure if it is just being ignored or not...
  • Rayman wrote: »
    A single quote character (') starts a comment, just like in Spin. It can be anywhere on the line, and goes to the end of the line.
    There is a way to do multi-line comments (they start with /' and ends with '/, kind of like C comments but with quote instead of *. I think this is kind of ugly, so I don't use them myself, but FreeBasic has them and I did want some way to do multi-line comments in BASIC.
    edited 2018-11-12 18:10
    Ok, thanks, that makes sense. The docs implied that, like REM, it had to be at the beginning of the line...
    Also, I think I am seeing that leading whitespace is always ignored.
    edited 2018-11-15 16:05
    What's a good name for this C that FastSpin compiles?
    FastC?
    We're calling the Basic FastBasic, right?
    edited 2018-11-15 16:39
    AFAIK @ersmith hasn't decided yet how adding BASIC and C will influence FastSpin's name.
  • Yeah, I haven't come up with a good name for the whole suite of programs. "fastspin" is obviously outdated now that it can handle BASIC and (part of) C. I guess "fastspin/fastbasic/fastc" are reasonable names, unless somebody can think of something better :).
  • ersmith wrote: »
    Well, "fastc" might actually be an inaccurate name if we end up getting GCC or LLVM for P2 as they will likely be faster. :smile:
  • ersmith wrote: »
    Prop Fast Suite?
    Propfast Suite?
    Propeller Fast Suite? (need to get permission from Parallax on the trademark).
  • David Betz wrote: »
    That will depend on the benchmark, I think :). For some things fastspin will produce better code than PropGCC. For other things PropGCC will be better.
  • ersmith wrote: »
    In that case, why not just forget GCC or LLVM and just go with fastspin/c? I suppose someone will want C++ though.
  • Well, I know one person who really uses C++ for his PropWare build system.
    On the Atari I used a language called ACTION. a mix between BASIC and 6502 Assembler. That would keep the speed meme.
    One could use the same trick as in @ersmith username, but erbasic, erc and erspin seems not so smart.
    But currently fastspin is the most complete compiler collection so ECC comes to my mind...
  • How about PLCSpin, PLCBasic, and PLCC? The prefix stands for "Propeller Language Collection". I suppose "PLC" has other meanings though.
  • How about "flexspin", "flexbasic", and "flexc"? The idea is that the compiler is pretty flexible, accepting PASM, Spin, BASIC, and C as input and producing P1 asm, P2 asm, or C/C++ as output. I'd call the overall collection "flex", but that's a widely used tool in Unix. Maybe "flexprop"?
    edited 2018-11-16 18:40
    FCC - Flexible Compiler Collection. ;-D
    Btw... an other very flexible compiler is (T)ACK ((The) Amsterdam Compiler Kit) and it is showing a not so common naming idea.
    Hmm... so why not...
    HCC - Halifax Compiler Collection.
    Ok... GCC now is surrounded... \o/
  • I've created a new release of spin2gui (1.2.3) and fastspin (3.9.10). I had expected big change by now, but those are still pending, so this is another bugfix/maintainance release from the Spin and BASIC sides (the C support does have a lot of new features, including typedef and a __builtin_printf function, but it's still very much a work in progress).
    I'll probably hold off on the name change until after the new C preprocessor and case-insensitive symbol support is in, and we can run some significant Propeller C programs.
  • Speaking of C support, any suggestions on how C code should import objects from other languages?
    In Spin we do:
    OBJ
      ser: "SimpleSerial.spin" ' a Spin object
      math: "math.bas" ' a BASIC object
      foo: "foo.c" ' a C object
    and in BASIC we do:
    dim ser as class using "SimpleSerial.spin" ' a Spin object
    dim math as class using "math.bas" ' a BASIC object
    dim foo as class using "foo.c" ' a C object
    C doesn't have an object mechanism, so this will (obviously) be an extension. Some options:
    - use a #pragma. This is compatible with the C standard, but possibly awkward
    - use a string after extern. I think this would be a compatible extension to C++
    - come up with a new keyword
    I kind of like the extern idea, like:
    extern "SimpleSerial.spin" ser;
    or even:
    struct extern "SimpleSerial.spin" ser;
    What do you think?
    What you are suggesting sounds reasonable, but I can't help wondering if there is a reason for not using "obj" or "object" as the key word for all three cases. It would at least be more consistent to do so.
    edited 2018-11-17 16:47
    [Weird, I did not mean to post]
    That looks fine.
    Maybe another way is do:
    #include "SimpleSerial.spin"
    //And then later
    SimpleSerial ser;  //create the object
  • ersmithersmith Posts: 6,166
    edited 2018-11-17 18:51
    @kwinn:
    I didn't use "obj" or "object" in all cases because that's not a reserved word in all the languages. We could define a new keyword like "_Obj" for C (it would have to start with an underscore to avoid conflicts with variables in existing programs), so that is an option. But overall I was trying to do this extension while keeping the "feel" of each language. Unfortunately they all have very different ways of declaring variables. If anything Spin is the odd man out, since it has a completely different way of declaring objects from other variables.
    @Rayman:
    Using "#include" is an interesting idea. At first glance it's intuitively obvious. Unfortunately it also has some problems -- normally "#include" means to literally insert the text of the file being included into this point in the file. We could change that for files whose name ends in .spin or .bas, but for .c files there would be a conflict -- are you including the .c as an object, or just putting the text in-line? There's existing code that does the latter already.
    I also worry that it could lead beginners into a common trap where they think of #include as doing more than it does. I've already seen that in questions about PropGCC, where they seem to think of #include as arranging for everything needed for linking, where in fact (in standard C at least) it's just a plain text substitution.
    edited 2018-11-17 19:03
    If it can't be done in a C standard way, then why not make it easy?
    The #include is obviously not compliant with anything, but have you ever seen a #include with a .spin extension?
    Actually, I think I changed my mind...
    I like your:
    better...
  • jmgjmg Posts: 15,193
    ersmith wrote: »
    or even:
    What do you think?
    Will this ultimately have a linker ? If so, any plan should be linker compatible ?
    With a linker, a header file can declare names, and then the linked .OBJ file can come from any language source at all.
