We can't check for C if we mandate that C is zero? right?
Did you look at the Google doc section that covers the LOCK bits? I can't remember what the deal is, exactly, but it's in that section. I believe it all makes sense.
nm, found it in the docs. Also needs to be updated in the TXT file.
(I was automatically generating disassembly code from the TXT file hence why I was focused on that doc specifically).
EEEE 1101011 C0L DDDDDDDDD 000000111 LOCKREL D/# {WC}
Ah, sorry. I will fix that.
EEEE 1101011 00L DDDDDDDDD 000110101 COGBRK D
Ignore the L or is D/# valid?
It should be D/#.
