Shop Learn P1 Docs P2 Docs Events
Iterative binomial filter in Spin — Parallax Forums
edited 2018-10-19 00:03 in Propeller 1
I'm working on a Propeller app that involves the smoothing of time-series data. One method that's often used for this is the very simplistic exponential averaging:
avgi = avgi-1 * p + data * (1 - p), where 0 < p < 1
The closer p is to 1, the more smoothing you get. In physical terms, this is equivalent to a simple RC filter and is a type of infinite impulse response (IIR) filter. This means that, theoretically, a datum an infinite time in the past still affects the current average. Of course, due to rounding and truncation in computer math, the effect is finite, but can be quite long.
Another type of filter is the boxcar smoother:
avg = (xi-n+1 + xi-n+2 + ... + xi-1 + xi) / n
This is a form a of a finite impulse response [FIR] filter, in that the influence of any particular datum lasts only n times in the data stream. It's not a very nice filter, because it has some nasty bumps at the high end of its frequency response.
A binomial filter is like a boxcar smoother, except that the past values are not all weighted the same. In fact, they're weighted by the numbers in one of the odd lines in Pascal's triangle, and divided by the sum, which is always a power of two:
1
1 1
1 2 1
1 3 3 1
1 4 6 4 1
1 5 10 10 5 1
1 6 15 20 15 6 1
The further down the triangle you go, the larger the coefficients become, to the point where overflow is a real problem when they're used to multiply the data points. So what I've done is to apply just the [1, 2, 1] filter to the data iteratively n times to get to the nth odd row of the triangle. And this just involves adding and shifting at each step.
To do this, the program uses a history array 3*n longs long. Each successive triad contains the history of the last three data points, where the data in triad i are the results of applying the [1, 2, 1] filter to triad i-1. I have sat down with pencil and paper to prove that doing this twice (n = 2) is equivalent to applying the [1, 4, 6, 4, 1] filter. So by extrapolation, I'm assured that successive odd rows fall out from further operations. The downside to doing it this way is the increased likelihood of truncation errors. But that's the price to be paid for no overflows.
Here's the program:
CON
  _clkmode      = xtal1 + pll16x
  _xinfreq      = 5_000_000
  MAXSTAGES     = 50
  UNDEF         = $8000_0000
VAR
  long history[MAXSTAGES * 3]
OBJ
  pst:  "Parallax Serial Terminal"
PUB start | seed, yy, zz, i, base, avg
  pst.start(9600)
  configure_smoothing(@history)
  repeat i from 0 to 511
    if (i > 128 and i < 384)
      base := 2000                               '+1000 pulse in the middle.
    else
      base := 1000
    yy := base + (?seed >> 25) + (i // 40) * 4   'Apply noise and sawtooth wave to signal.
    zz := smooth(@history, yy, 30)               'Do a 30-stage binomial smoothing.
    if (i)
      avg := (avg * 11 + yy) / 12                'Exponential smoothing for comparison.
    else
      avg := yy
    pst.dec(yy)
    pst.char(" ")
    pst.dec(zz)
    pst.char(" ")
    pst.dec(avg)
    pst.char(13)
'The following two subroutines set up and perform the binomial smoothing operation.
PUB configure_smoothing(hist_addr)
  long[hist_addr] := UNDEF                       'Constant used for undef, since Spin doesn't have one.
PUB smooth(hist_addr, value, n) | i
  n += n << 1                                    'Multiply n by 3.
  if (long[hist_addr] == UNDEF     )             'If first value, fill history with it.
    longfill(hist_addr, value, n)
    return value
  else
    longmove(hist_addr, hist_addr + 4, n - 1)    'Otherwise shift history left by one long.
    repeat i from 0 to n - 1 step 3              'Iterate the [1 2 1] filter.
      long[hist_addr][i + 2] := value            'Insert value as last in local history triad.
      value := (long[hist_addr][i] + (long[hist_addr][i + 1] << 1) + value + 3) >> 2 'New value := (value[i - 2] + 2 * value[i - 1] + value[i]) / 4
    return value
This uses a 30th order binomial filter, which, if done explicitly, would involve 59 coefficients. I plotted the data it output in Excel. Here's the graph:
The major takeaways are these:
1. Both the exponential and binomial filters do a good job of cleaning up short-term fluctuations in the data.
2. The binomial filter does a much better job following data trends that the exponential filter mushes up.
3. The binomial filter entails a delay equal to n. The reason for this is that the highest coefficient is in the middle, n-1 data samples in the past from the current one. Another way to look at it is that the binomial filter considers not only the current value and values in the past, but also values in the future to compute the smoothing.
  • Interesting - always on the lookout for a digital filter without multiplies for PASM use (!)
    Its a bit less computational load to use [1 1] as the basis, rather than [1 2 1], twice as many
    steps but only 2 x (move + add) rather than 3 x move + shift + add + add.
    The moves can be eliminated by ping-ponging between two copies, some Python to
    illustrate (this ought to translate to two unrolled PASM loops, one for each value of sense, meaning
    cost is mainly one add instruction per [1 1] stage.)
    N = 16
    state = np.zeros ([2, N], float)
    sense = 0
    def smooth (inp):
        global sense
        state [sense, 0] = inp
        for i in range (N-1):
            state [sense, i+1] = state [0, i] + state [1, i]
        out = state [0, N-1]+state [1, N-1]
        sense = 1 - sense  # swap columns
        return out / (1 << N)
  • ErNaErNa Posts: 1,718
    Hello Phil, what do you want to reach? Remove the noise and just have the sawtooth? Determine the frequency of the sawtooth? Do you need the result in realtime or is a time shift acceptable? Could you attach the raw data file?
    edited 2018-10-19 23:01
    My objective is just to remove the noise while preserving the short-term and long-term trends without smooshing them into oblivion. The filter I've presented meets that criterion for my app.
    Here's the raw data generated by the above program:
    1104
    1044
    1100
    1020
    1118
    1054
    1105
    1132
    1096
    1152
    1124
    1050
    1156
    1099
    1113
    1124
    1092
    1192
    1122
    1112
    1141
    1131
    1209
    1144
    1168
    1118
    1198
    1119
    1212
    1181
    1221
    1196
    1250
    1226
    1235
    1176
    1229
    1259
    1197
    1246
    1012
    1013
    1015
    1017
    1118
    1062
    1111
    1032
    1143
    1105
    1122
    1046
    1083
    1164
    1147
    1161
    1160
    1074
    1156
    1178
    1138
    1134
    1140
    1164
    1114
    1218
    1167
    1176
    1139
    1133
    1244
    1214
    1228
    1165
    1187
    1217
    1260
    1208
    1262
    1200
    1091
    1105
    1048
    1064
    1120
    1092
    1034
    1129
    1040
    1042
    1100
    1082
    1094
    1108
    1137
    1164
    1128
    1096
    1100
    1096
    1098
    1106
    1201
    1174
    1098
    1199
    1204
    1149
    1237
    1143
    1169
    1162
    1254
    1181
    1262
    1253
    1178
    1181
    1243
    1233
    1028
    1040
    1109
    1100
    1023
    1049
    1125
    1060
    1114
    2038
    2147
    2110
    2167
    2138
    2125
    2086
    2184
    2121
    2073
    2181
    2121
    2145
    2111
    2116
    2115
    2131
    2222
    2171
    2180
    2135
    2231
    2169
    2218
    2136
    2231
    2238
    2189
    2238
    2276
    2206
    2076
    2129
    2035
    2133
    2044
    2080
    2062
    2090
    2133
    2132
    2126
    2145
    2064
    2097
    2162
    2103
    2126
    2137
    2170
    2145
    2178
    2169
    2159
    2109
    2140
    2199
    2212
    2147
    2183
    2221
    2145
    2246
    2182
    2167
    2224
    2243
    2243
    2216
    2195
    2250
    2067
    2130
    2081
    2127
    2121
    2061
    2053
    2049
    2155
    2091
    2042
    2143
    2140
    2148
    2078
    2181
    2164
    2133
    2093
    2191
    2081
    2125
    2101
    2100
    2142
    2188
    2223
    2138
    2191
    2195
    2247
    2140
    2157
    2241
    2214
    2178
    2182
    2170
    2265
    2214
    2018
    2058
    2051
    2050
    2094
    2098
    2054
    2075
    2081
    2050
    2146
    2127
    2059
    2168
    2148
    2156
    2142
    2194
    2161
    2090
    2178
    2161
    2148
    2162
    2120
    2119
    2167
    2152
    2195
    2223
    2234
    2180
    2193
    2249
    2229
    2149
    2191
    2261
    2258
    2223
    2094
    2071
    2118
    2088
    2125
    2074
    2067
    2122
    2043
    2136
    2049
    2147
    2059
    2088
    2149
    2157
    2167
    2175
    2122
    2120
    2091
    2168
    2174
    2097
    2166
    2180
    2121
    2128
    2218
    2143
    2145
    2142
    2158
    2219
    2236
    2213
    2267
    2187
    2271
    2242
    2109
    2050
    2064
    2053
    2037
    2135
    2129
    2093
    2085
    2069
    2107
    2162
    2127
    2139
    2060
    2067
    2173
    2146
    2190
    2195
    2198
    2155
    2201
    2110
    2182
    2193
    2137
    2175
    2182
    2156
    2236
    2184
    2238
    2208
    2245
    2154
    2202
    2270
    2246
    2191
    2024
    2071
    2134
    2117
    2129
    2046
    2048
    2111
    2067
    2044
    2046
    2128
    2070
    2173
    2076
    2150
    2172
    2091
    2152
    2093
    2196
    2128
    2163
    2108
    1213
    1185
    1111
    1217
    1118
    1184
    1147
    1141
    1212
    1210
    1262
    1221
    1224
    1237
    1262
    1200
    1059
    1039
    1088
    1109
    1039
    1052
    1138
    1076
    1127
    1158
    1166
    1133
    1150
    1086
    1097
    1153
    1097
    1191
    1191
    1138
    1093
    1084
    1120
    1182
    1148
    1156
    1121
    1224
    1204
    1172
    1161
    1209
    1223
    1182
    1220
    1242
    1170
    1172
    1251
    1232
    1061
    1131
    1112
    1076
    1092
    1065
    1058
    1085
    1064
    1086
    1140
    1149
    1073
    1118
    1151
    1094
    1129
    1169
    1088
    1145
    1098
    1202
    1207
    1186
    1131
    1124
    1179
    1148
    1204
    1188
    1242
    1202
    1230
    1254
    1206
    1164
    1243
    1152
    1247
    1222
    1111
    1129
    1083
    1028
    1085
    1110
    1068
    1095
    1070
    1106
    1088
    1171
    1096
    1123
    1121
    1137
    1108
    1119
    1141
    1190
    1088
    1090
    1108
    1166
    1153
    1132
    1202
    1169
    1199
    1216
    1177
    1188
    This filter removes noise to a certain level, so the slopes are less steep. There is no phase shift visible, as the original signal is delayed, otherwise the phase shift would be 15 samples. As the middle part is easily detected as signal, to apply the filter, the signal is removed and later added again, that is the reason, why the step is still sharp.
    1144 x 372 - 17K
  • How did you do it? In my target app, I don't know what the signal is, so I can't remove it ahead of time. The data are a time-series, and I need to apply the filter in real time.
  • ErNa, that is some seriously impressive filtering. Please share at least a hint?
    Mike R.
  • You know, this smells like a "Golf Challenge" :-)
    Here is a 4th order delta filter ...
    The superimposed image at the bottom with the spike going down on the left and up on the right is the delta between Samples.
    The Sample starting at about 1000 is the original data.
    The proceeding samples represent each successive order of filtering. I purposefully offset the Y by 250 on each filter.
    The filter consists of a FIFO window of three samples, call them A1, A2, and A3. D1,D2,and D3 are Delta values. F1 is the Filtered output. Each pass of the filter, you lose the last two data samples.
    D1 = A1-A2
    D2 = A1-A3
    D3 = INT((D1+D2)/2)
    F1 = A1-D3
    1240 x 433 - 94K
    edited 2018-10-20 03:31
    Beau,
    So,
    D3 = (D1 + D2) / 2 = (A1 - A2 + A1 - A3) / 2 = A1 - (A2 + A3) / 2
    F1 = A1 - D3 = (A2 + A3) / 2
    This looks like the [1, 1] kernel, but peering into the future, rather than into the past, which explains the increasing negative delay with each pass. Right?
  • Beau SchwabeBeau Schwabe Posts: 6,526
    edited 2018-10-20 06:09
    Phil,
    Peering into the future is correct I guess, although technically you are still looking at the past since you lose the last two data points or they become part of the equation rather for each Delta order you implement. The idea is that you need at least 3 data points in a first in first out approach, so the output data for each order isn't valid until you have read at least 3 points, either way you lose the last two or first two depending on how you look at the incoming data stream. For the 4th order Delta you end up losing 8 data points.
    Here is the same data taken to an 8th order Delta filter. 16 data points are lost at the end so the 512 data set is now 496
    EDIT: losing 2 data points per order probably isn't correct. A Phase shift or delay would be more accurate. SO for each time you implement a filter stage, you introduce a delay of two samples per stage
    1290 x 515 - 127K
  • Unfortunately, I don;t have the luxury of knowing what future data values will be, and I need to come up with a filtered value based only upon past data values. However, I might be able to predict future data values based upon a regression analysis of past values and use those as if they were actual data. Hmmm ...
    edited 2018-10-20 07:27
    Argggghh !!!! .... It's all a matter of perspective. The Delta filter doesn't know any future values. I think what is throwing you off is that the data in the graph is left justified.
    Seems to be interesting matter and Beau just comes up with a very good solution. He's deep into the matter, ;-)
    When it comes to filter the data, the question always is, what do you expect to happen. This sample data seems artifical, as there is a pulse, a sawtooth and noise. If you look to the derivative, Beau created, it is obvious, there are spikes in a certain distance and at certain amplitude, so these can be predicted to and seen as a part of the signal. It is a good idea to not filter those spikes out. So one could say: calculate derivative, limit amplitude to a level 3 sigma, apply a filter and remove the filtered out components from the original signal, that should suppress the noise and keep the information.
    In this signal, the question is: what is the information. Is it every new sample or is the information only valid after a sawtooth completed? In the last case, the value is the average over one sawtooth and you have a time delay of 1/2 period anyway. In the other case, the history tells you, there is a systematical sawtooth and the new sample just tells you, if this sawtooth continues or ends. Such deviations can only be found, when the noise is less then the change of the signal.
    Whenever we sample a signal, we either accept, what we get, or we look back to the past to see if the signal didn't change faster then we experienced. Being more optimistic, we also can make a projection to the future and we check, if the signal fits to our prediction. Then we have to decide, what is the "truth". A binominal filter is to my understanding a folding of the signal with the gaussian standard deviation. So this can never reproduce a step without generating a finite slope and so phase delay.
    edited 2018-10-20 15:10
    I just don't see the effect of any derivatives in Beau's filter. It's just:
    F1 = (A2 + A3) / 2
    F2 = (A3 + A4) / 2, etc.
    And that's the same as Mark_T's technique for iterating the binomial filter, at least after any even number of iterations. (If you stop at an odd number, you don't get a true binomial filter.)
    Ideally, the filter I use, would look something like this:
    fi = f(a0*xi + a1*xi-1 + ... + an*xi-n)
    The binomial filter fits the bill. But, because the middle a terms are the largest ones, they contribute to a large phase delay. What I propose is to come up with a binomial filter whose left tail is applied to past values, the center term to the current value, and the right tail to "future" values extrapolated from past values, using a polynomial or other regression technique. That way, the phase delay is minimized.
    Phil, the problem you show is quit simply to solve: just state what the next value is to be and if you do this for a long time, the signal will follow, as the signal is dump like a bread. As we are older and know about the conservation of momentum and energy, we do not follow this advice of mine. We should argue more reasonable:
    What we actually do when applying a filter, we write one vector of lenght 1 with the n components being the filter coefficients and then we take the last n samples of the signal as a second vector and we calculate the scalar product to get "how much" of the filter vector is "in" the signal.
    Imagine the signal is constant but noisy. Then the scalar product to the middle of the binominal is just 50%. This will eliminate the noise and not introduce a phase shift, as the signal is constant, so phase shift doesn't apply. This will also work for any filter coefficients. The binomial just weights the values close to the center a little more, so if the signal is not constant, your result will be closer to the actual value of the last sample. If you could look into the future and see, that the signal is symmetrical to the past, then the next 50% of the signal will show the same value as the first 50%. But as we do not know, how the signal develops this is just lotterie.
    So you could do this experiment: take 50% of the binominal and calculate the current value. Next: take 70% of the binominal, so the peak is in the past, and calculate the current signal. Now imagine to go back in time to the max of 70 %, predict what will happen 20% later, actual the known current value and determine, if you prediction was right. Then, as you know the error you made, assume that you just now made the same error and correct it.
    That is just the basic principle how to make a learning system. But, always look that your predictions don't hurt conservation of momentum and energy. Or, to bring a less abstract example: if your employment rate raises constantly, there is a natural limit of 100 %. If someone tells you, that growth will continue for ever, he might be false.
    Sounds like a recipe for a nonlinear chaotic system to me... And you lose all the predictable
    properties of a time-invariant linear system.
  • Or put another way: Try an IIR filter first, both approaches are going to require lots of multiple-and-add I think.
    What is bad with guessing, what the future is, if we already guess what just happens and what was in the past. There are so many histories, that it needs scientist to establish a narrative ;-)
    In the future we will have P2 that is for sure, in the past, we had no P2, that's for sure to. And in between, we wait.....
    No!!! That's precisely what I'm trying to get away from. I'm totally committed to the FIR approach. I just need something without a huge phase lag that I can explain to my customer.
    edited 2018-10-21 09:05
    Phil, the point with your signal is, that the high frequency components that produce the sharp edges also generate the noise. Removing the noise flattens the signal and so there is a time shift. Search for a saw tooth and both shift it in amplitude and time to find the optimal correlation. I suppose, the signal is not high frequency, so computational effort should not be an issue
    edited 2018-10-22 19:00
    Made another try:
    Calculating the derivative, but D(i) = S(i) - S(i-2)
    The idea behind that is: obviously, the steps in the signal (red) extend over more than one sample and so highest frequency noise (alternating) is suppressed, while the signal steps are not. By differentiation, the constant part is lost, so this part has to be added separately when reintegrating.
    Integration now takes every difference, so the result has to be devided by 2 (green). To improve noise suppression, the derivative can also be averaged (in this case (d(i)+d(i-1)+d(i-2))/3 which shows the result in red.
    It looks that the key with filtering is to know, what you are looking for. So if you look to your neighbor and you see a mob, take care that your sight was not filtered by a mirror.
    1233 x 357 - 18K
    Then you have to put up with a small number of coefficients in the FIR - have you tried approximations to sinc()
    using small integer coefficients (mainly powers of two) - for instance:
    [1, 2, 1, 0, -2, -4, -2, 0, 4, 12, 16, 18, 16, 12, 4, 0, -2, -4, -2, 1, 2, 1]
    Which has a cutoff of about fs/8 and latency of 10 samples - derived by adhoc means. I don't know how to
    determine FIR coefficients for minimum phase, other than to simply truncate the future coefficients sooner.
  • I recently came across a description of cascaded integrator-comb filters, and this seems to be pertinent to this thread
    http://dspguru.com/files/cic.pdf and https://www.embedded.com/design/configurable-systems/4006446/Understanding-cascaded-integrator-comb-filters
    Outside of the use for decimation and interpolation, an integrator-comb filter is another way of looking at
    boxcar filtering as a combination of an integrator and a comb filter where the integrator pole cancels a single
    zero of the comb filter.
  • Tracy AllenTracy Allen Posts: 6,644
    edited 2018-11-04 18:51
    Here's a thread where Marty Lawsen applied a CIC filter to improve the resolution of the prop1 Sigma Delta:
    high-precision-propeller-sigma-delta-adc
    And here's a pdf link to that nice article by Richard Lyons:
    https://faculty-web.msoe.edu/prust/sdr/cic_filters.pdf
    edited 2018-11-05 04:32
    Tracy, thanks for posting the link! That's a very good paper, although my eyes start to glaze over when it talks about the Z-plane. :)
    One thing I've discovered the hard way is that so much in the filtering world is applicable to AC signals (e.g. audio, RF) only, neglecting the DC component. I thought maybe I could use my FIR filter generator to come up with a filter for the time-series data. But no. Even though the TFilter FIR filter design tool claims a gain of 1.0 for a low-pass filter, the gain at 0 Hz can be less than that, which means the filtered data will be skewed downwards. This is because the ripple in the passband may not intersect the Y-axis at 0 dB.
    The simplest way to guarantee DC unity gain is to make sure that all of the FIR filter coefficients sum to 1.0. If they are all positive, so much the better. This is not the case with many TFilter-generated filters, even though the AC gain is still 1.0.
    Currently, I'm looking at a combination of a causal FIR filter (i.e. one with minimum phase delay), followed by median filtering.
    Hi Phil, I feel with you, the z-plane to me also is not very intuitive. Mainly it's because of there is a theory, that reflects models that again not always reflect reality. But if you look to see DC as a very low frequency, it becomes clear, that any filter to remove those low frequencies will have a very long response time. DC only is detectable, if you know that any error is due to overlayed AC and so you can isolate only AC that is composed from many harmonics. That's why I asked: what is the signal you expect. From the example you gave, a step function and sawtooth seems to be the component of interest.
    edited 2018-11-05 15:52
    The sawtooth and step functions were just highly-adverse fake data to test various filtering strategies. The real data come from environmental sensors and are noisy but look nothing like the functions I posted.
    That is what I could imagine. The point with filtering is you always have to know what the signal looks like and how the transmission is structured.
    The most simple assumption is: noise is stochastic. In this case the filter of choise is the gaussion scaled sliding average. If noise is created by accident, then it shouldn't make any difference, which sampling points you take. But as there is a underlying signal, selecting the sampling points matters. So anyway you have to have a model of the signal generating mechanism.
  • I know what you mean about the z-domain. My son is taking a second degree, in electrical engineering (first one in music), and he is now in the throes of control systems and z transforms. I had a lot of that when I was in school but it is all very rusty--I can't give him much support. I remember there was a good ol' crank to turn for systems that involved time delays and feedback taps. The CIC-like and shaping filters are all about that.
    Chopping the signal works well, to bring the signal from DC up to a set higher frequency where it can be dealt with in an exquisite narrowband filter. Unfortunately a lot of those environmental signals can't be chopped in a way that doesn't include the interference.
  • Why would you use the FIR filter followed by the median filter? I'd think you want the other way around. The median filter tends to eliminate outliners.
