VGA from P2 silicon
Peter Jakacki
in Propeller 2
I just found an older VGA routine that was done for FPGA and made a couple of changes to get it running on silicon. Next thing I want to do is duplicate all this from TAQOZ.
'* VGA 640 x 480 x 8bpp-lut *
CON
intensity = 120 '0..128
fclk = 200_000_000.0
fpix = 25_000_000.0
fset = (fpix / fclk * 2.0) * float($4000_0000)
vsync = 4 'vsync pin (all FPGA boards now)
DAT org
' Setup
hubset ##%1_001011_0011000111_1111_11_00
waitx ##20_000_000/100 'wait ~10ms for crystal+PLL to stabilize
hubset ##%1_001011_0011000111_1111_11_11 'now switch to PLL running at 200MHz
rdfast #0,##$1000-$400 'load .bmp palette into lut
rep @.end,#$100
rflong y
shl y,#8
wrlut y,x
add x,#1
.end
rdfast ##640*480/64,##$1000 'set rdfast to wrap on bitmap
setxfrq ##round(fset) 'set transfer frequency to 25MHz
'the next 4 lines may be commented out to bypass level scaling
setcy ##intensity << 24 'r set colorspace for rgb
setci ##intensity << 16 'g
setcq ##intensity << 08 'b
setcmod #%01_0_000_0 'enable colorspace conversion
wrpin dacmode,#0 'enable dac modes in pins 0..3
wrpin dacmode,#1
wrpin dacmode,#2
wrpin dacmode,#3
drvh #0
drvh #1
drvh #2
drvh #3
' Field loop
field mov x,#33 'top blanks
call #blank
mov x,#480 'set visible lines
line call #hsync 'do horizontal sync
xcont m_rf,#0 'visible line
djnz x,#line 'another line?
mov x,#10 'bottom blanks
call #blank
drvnot #vsync 'sync on
mov x,#2 'sync blanks
call #blank
drvnot #vsync 'sync off
jmp #field 'loop
' Subroutines
blank call #hsync 'blank lines
xcont m_vi,#0
_ret_ djnz x,#blank
hsync xcont m_bs,#0 'horizontal sync
xcont m_sn,#1
_ret_ xcont m_bv,#0
' Initialized data
' %AAAA_BBBB_FFF_DACxxDDDDDDDD_TT_MMMMM_0
dacmode long %0000_0000_000_1010000000000_01_00000_0
m_bs long $CF000000+16 'before sync
m_sn long $CF000000+96 'sync
m_bv long $CF000000+48 'before visible
m_vi long $CF000000+640 'visible
m_rf long $7F000000+640 'visible rlong 8bpp lut
x res 1
y res 1
' Bitmap
orgh $1000 - $436 'justify pixels at $1000, pallete at $1000-$400
file "bitmap2.bmp" '640 x 480, 8pbb-lut
Does that need 200MHz SysCLK to work ?
What SysCLK can that drop down to, and still work ok ? 25MHz ?
All my P2 VGA stuff shows incorrect colors too on the real P2,
Modulator bug related I assume?
Does your "adaptor" have the RGB grounds connected as well ?
Pin %xxxx11 = Red
Pin %xxxx10 = Green
Pin %xxxx01 = Blue
Oh yeah, that's better. To tell the truth I didn't even look at the colors at all, I was just happy to see it running
btw - I can run the P2 at 25MHz and it still works
HDTV takes 3 pins: Y, Pb, Pr.
Composite takes 1 pin: YIQ.
I love that we have 2ns 75-ohm DACs on every pin.
I'm thinking about how the Goertzel can be used to resolve time-of-flight for signals. Goertzel, fast low-Z DACs, oversampling, and CORDIC, all together, should make really interesting measurements possible. It may be possible to achieve micrometer-scale resolution for light and electrical phenomena.
250 MHz opens up a lot of resolutions: http://tinyvga.com/vga-timing
Yes, 148.5MHz, to be exact.
With a 20MHz crystal, use the PLL to divide it by 40 to get 0.5MHz, then set the VCO multiplier to 297 and select undivided VCO output and you've got 148.5MHz.
I was signaling 1080p with 80 MHz clock on P2V:
https://forums.parallax.com/discussion/163719/how-to-do-1080p/p2
TVs didn't care, but some monitors didn't like it...
Thanks - great ! With P2's power aspects, lowest possible functional MHz will be important. Lucky it has that wide-range PLL
Certainly an interesting area. I revisited some time-of-flight work Bean did on P1 following a question in another thread.
There, Bean changes the Counter-PLL faster than it can lock, in order to modulate the timing samples across a linear range.
Multiple samples and some means to shift edges in a sub-ns manner looks to be useful for time-of-flight.
P1 has multiple PLLs and async pins, not sure how to emulate those in P2 ? - possibly a DAC and LPF+external comparator (logic 1G14 schmitt should do) ?
Or, a DAC could modulate the supply rail of a AHC14, or maybe a dual-supply translator like 74AVC1T45 ?
It can be more subtle than that. The Goertzel accumulates SIN and COS sums, based on the ADC readings (+/-1) on every clock, which can be converted to polar coordinates. The super resolution comes from the angle reading. Imagine you are outputting a 20MHz reference sine wave and inputting the same on another pin's ADC, after the signal has traveled a bit. The longer you measure the input, the bigger the accumulations get, and the more precise the final angle reading becomes. The phase resolution can be in the millionths of a revolution, down into the femtoseconds. This will take some experimentation to develop, but we have all the needed parts in the chip.
Be interesting to see what can be achieved with P2 silicon.
What is the step size error on the DACs ?
Seems with a modest DAC generated slew, 5ns SysCLKs can give maybe 390ps~100ps region time resolve, using external buffer threshold.
MOSFET drivers usually have schmitt buffers, so some sub-ns PWM could be possible in P2 ? (allows you to compete with the better TI/Microchip parts)
The DAC step size is 3.3V/256 = 12.9mV. Smart pin modes can toggle between two adjacent steps to push 16-bit resolution.
For fewer than 5 pins and assuming your VGA monitor supports it I take it that P2 internal HW has nothing stopping it being implemented using SyncOnGreen (3 pins) or RGBS (4 pins) as well? The S signal being some form of composite sync, potentially also DAC driven at 0.7V pp like RGB, or a raw TTL level form.
From when I looked at the P2 docs it seems like that should be perfectly doable but I'm currently laying out a board and only really want to wire 4 pins into VGA from the P2 if possible. I guess I should try to run a separate signal for the extra Vsync pin with a non-populated resistor just in case...
I think I read somewhere that most monitors accept composite sync fine, behaving like they internally XOR'd V,H lines before processing anyway.
This may really be more of a driver question rather than P2 HW. I guess I'm not familiar enough with any existing video drivers on P2 yet to have full confidence in what is possible there. May have to try to write one when I get a chip to play with.
Bit 0 of D/# inverts the HSYNC signal. So, you would flip that bit at the beginning and end of your VSYNC period, HSYNC would be inverted for that duration. I didn't know that VGA monitors let you get away with that. That's great!!!
That could be arranged. I need to travel to at least Syd and Adl this coming week.
Yeah this can be very handy to save 1 pin (or even 2 with RGB SyncOnGreen). I know my older Sony CRT monitors support sync like this, should really try the range of Dell/Samsung LCDs I have as well. I think they also are meant to work but best to try to be sure.
https://en.wikipedia.org/wiki/Component_video_sync
Thx, will let you know if I've got any time for one - still busy on this PCB design and component selection etc so a P2D2 right now might actually be a distraction and yet another context switch.
