P2 FPGA: why does VGA only work in COG 0? — Parallax Forums
I presume I'm doing something wrong here, but I can only get VGA output to work if I drive the VGA from COG 0 (this is on my DE2-115 with the v32i FPGA image). The DE2-115 does have 4 cogs, and I can run code in the other COGs, but if I try to run the VGA code in anything other than COG 0 the monitor doesn't detect the signal.
I've attached the code below: it's a simple modification of Chip's VGA_640_x_480_8bpp.spin2. I changed to 4 bits per pixel to free up some RAM and moved the frame buffer from $1000 to $8000. As posted below, with the VGA in COG 0 and a simple line drawing routine in COG 2, everything works and I see a fat line sweeping across the screen. If I change the line commented with FIXME so that the VGA runs in COG 1, the monitor doesn't sync.
Have I missed something in the docs regarding the streamer? Is it only implemented on COG 0 in the FPGA?
Thanks for any insights,
Eric
'*  VGA 640 x 480 x 4bpp-lut  *
CON
  intensity	= 80	'0..128
  fclk		= 80_000_000.0
  fpix		= 25_000_000.0
  fset		= (fpix / fclk * 2.0) * float($4000_0000)
  vsync		=	0	'vsync pin (all FPGA boards now)
DAT		org
' Setup
entry
                ' hubset  #$ff  ' done for us in startup code
		mov	x, #0
		mov	y, #0
		rep	@.end,#$100
		wrlut	y,x
		add	y,##$11111100
		add	x,#1
.end
		rdfast	##(640*480)/(2*64),screenptr	'set rdfast to wrap on bitmap
		setxfrq ##round(fset)		'set transfer frequency to 25MHz
		'the next 4 lines may be commented out to bypass level scaling
		setcy	##intensity << 24	'r	set colorspace for rgb
		setci	##intensity << 16	'g
		setcq	##intensity << 08	'b
		setcmod	#%01_0_000_0		'enable colorspace conversion
		wrpin	dacmode,#0		'enable dac modes in pins 0..3
		wrpin	dacmode,#1
		wrpin	dacmode,#2
		wrpin	dacmode,#3
' Field loop
field		mov	x,#33			'top blanks
		call	#blank
		mov     x,#480			'set visible lines
line		call	#hsync			'do horizontal sync
		xcont	m_rf,#0			'visible line
		djnz    x,#line           	'another line?
		mov	x,#10			'bottom blanks
		call	#blank
		drvnot	#vsync			'sync on
		mov	x,#2			'sync blanks
		call	#blank
		drvnot	#vsync			'sync off
                jmp     #field                  'loop
' Subroutines
blank		call	#hsync			'blank lines
		xcont	m_vi,#0
	_ret_	djnz	x,#blank
hsync		xcont	m_bs,#0			'horizontal sync
		xcont	m_sn,#1
	_ret_	xcont	m_bv,#0
' Initialized data
dacmode		long	%0000_0000_000_1010000000000_01_00000_0
m_bs		long	$CF000000+16		'before sync
m_sn		long	$CF000000+96		'sync
m_bv		long	$CF000000+48		'before visible
m_vi		long	$CF000000+640		'visible
m_rf		long	$6F000000+640		'visible rlong 4bpp lut
screenptr	long	$8000
x		res	1
y		res	1
' Bitmap
VAR
  long cog
  long stack[64]
PUB demo | base, linesize, x, y
  coginit(2, runline, @stack[0])
  coginit(0, @entry, 0)   '' FIXME: why must this be cog 0??
  repeat
PUB runline | base, linesize, x, y
  base := $8000		' screen memory
  linesize := 320
  x := 1
  repeat
    repeat y from 0 to 479
      byte[base + y * linesize + x] := $ff
      byte[base + y * linesize + x-1] := $0
    x++
    if x => 300
      x := 1
  • I've run into this issue before. I was told at the time that it's a limitation of the FPGA implementation, and the actual silicon chip won't have this problem. I had to do the same thing you're doing, and run the VGA driver on cog 0.
  • Dave Hein wrote: »
    Ah, bummer, Thanks for the info, Dave!
    Eric
  • RaymanRayman Posts: 15,435
    edited 2018-10-02 13:31
    I think the DAC is an external chip in FPGA boards.
    So, it's a bit of a hack...
    The P123 board has two VGA ports, so I bet one is wired to cog0 and the other to cog1...
    I need to read the docs again to refresh my memory, been a while...
  • The P123-A7 Video DACS are wired differently than the P123-A9 Video DACS.
    IIRC the A7 had separate load signals whereas the A9 had a single load signal that was inverted to the second DAC.
    This was because the A9 has more power pins than the A7 so some IO was sacrificed.
    AFAIK the second video DACS were never implemented.
    Yes, only cog zero has access to the DACs on the FPGA boards
  • Re yesterdays' forum change, I already miss the yellow background in code blocks and the new differently coloured text looks a mess in the top post. Code is not just one variety and should be free of any formatting, I think. Probably not the right place to post this but I don't know where is.
    TonyB_ wrote: »
    Yeah, we didn't vote for "change".
