New BASIC compiler for Prop1 and Prop2 - Page 3 — Parallax Forums
1356720
  • yetiyeti Posts: 819
    edited 2018-09-12 11:09
    Mickster wrote: »
    I would stick a Micromite on the front end.
    If you want open source, MMBASIC is a no go.
    From http://mmbasic.com/source.html:
    The source code to MMBasic is Copyright 2011 - 2018 Geoff Graham and may be used for an individual's personal use under the following terms:
    The files may not be distributed or made available to others without specific written permission.
    Object files (ie, .o, .exe, .hex files) generated using one or more of the source files (modified or not) are for personal use only and may not be distributed without written permission.
    The files are provided without any warranty; without even the implied warranty of merchantability or fitness for a particular purpose.
    The source is not open and (probably) MMBASIC is a one man show. Does that remind someone of BST?
    Otherwise it is a nice bag full of features.
  • Geoff Graham (OZ) and Pete Matherp (UK) are now the developers....and Pete, especially, seems to have a new development every day.
    I really have no interest in open source...it works or it doesn't. I care about shipping a product that works and rapid development is what I need.
    The guy who developed Bypic (Micromite on steroids) just retired but I have the hex file and a PICkit3....it works.
    Not a fan of Windows but it helps me get the job done and I get paid....can't make Linux work for me....which one is open source?
    I am astounded at the faith that my clients have in myself. I am now a one-man-band with a proprietary product. In many cases, if my product dies, there's a whole bunch of people stood on a factory floor with nothing to do.
    In my previous life I shipped enough product in to Big 3 auto that would shut down an entire car production line... We only ever negotiated price, never source code.
  • jmgjmg Posts: 15,193
    Mickster wrote: »
    Can you expand so readers know what offering(s) that refers to ?
    I see
    http://mmbasic.com/porting.html
    " Requirements
    MMBasic requires a CPU with 32 bit integers and pointers supported by an ANSI or C89 C compiler.
    In its minimal version MMBasic typically compiles to about 94K of flash and requires just over 5K of RAM plus a minimum of 4K for the stack (9K total).
    More memory is required to store programs, variables, etc so the interpreter will require at least 16K of RAM to run a small BASIC program.
    Generally 32K RAM or more is preferred as that will allow for larger programs and arrays.
    Keep in mind that adding extra functionality (SD card support, file I/O, etc) will add to these requirements.
    Customisation
    The language itself is hardware independent. Supporting the language are two main files that will need customisation to suit a particular platform:
    Main.c - This is the main entry point and is responsible for configuring the chip, basic character I/O and the main loop which inputs a line and dispatches it to the interpreter.
    Memory.c - This allocates RAM for the interpreter's use (program memory, variable memory and the heap).
    The configuration of this has been kept flexible so that the language can run on devices with unusual memory mapping.
    MMBasic has its own dynamic heap system which is also implemented in this file."
    Which all looks pretty nifty, and could even give a path for Parallax to offer module versions, once ported, so that could actually be a nice "Bridge Product"
    It's meaty, so be very interesting to see how that .c compiles into P2.
    If nothing else, it's a great test pattern for any P2 C Compilers !!!
    Ken should be all over this...
  • Armmite
    http://www.thebackshed.com/forum/forum_posts.asp?TID=10568&PN=2
    Picromite (RPi)
    http://www.thebackshed.com/forum/forum_posts.asp?TID=9823&KW=Picromite
    They also have bigger and faster PICs than the old MX170
    Lots more info on the forum and then there's Geoff's site: geoffg.net
    edited 2018-09-12 15:36
    Back to the main topic, this was offered as another alternative, in that question equivalent to : AVR C projects needs small interpreter for customer sand box use
    https://code.google.com/archive/p/python-on-a-chip/
    "Features of the PyMite VM:
    Requires roughly 55 KB program memory
    Initializes in 4KB RAM; print "hello world" needs 5KB; 8KB is the minimum recommended RAM.
    Supports integers, floats, tuples, lists, dicts, functions, modules, classes, generators, decorators and closures
    Supports 25 of 29 keywords and 89 of 112 bytecodes from Python 2.6
    Can run multiple stackless green threads (round-robin)
    Has a mark-sweep garbage collector
    Has a hosted interactive prompt for live coding
    Licensed under the GNU GPL ver. 2
    The PyMite VM DOES NOT HAVE:
    A built-in compiler
    Any of Python's libraries (no batteries included)
    A ready-to-go solution for the beginner (you need to know C and how to work with microcontrollers)
    FAQ:
    'How much RAM is necessary? A: At least 5 KB to initalize, 8 KB to do something small and more KB if your goals are lofty.
    I just built the latest release, why does it fail? A: Please use the latest code from the repository rather than the releases. The release is showing its age and many bugs have been fixed in the repository.
    Why does this simple for-loop fail ? for i in range(1, 10000): print i
    A: The range() function creates a List with the given number of integers inside it. That list and its contents are consuming all the available RAM. Use xrange() or while() with a counter instead.
    Another great C test pattern :)
    Whilst the MMBasic above is looking 'meaty' at ~94kF 5k+4k RAM, for a Basic, it's a natural growth point in MCU space
    The PyMite VM at 55kF,4kR starting, looks a nifty parsimonious Python Byte code starting point.
    Generic parts like
     NUC126   : 2656kF, 20kR, 72MHz.M0    48p7x7        64p7x7         100p14x14
     LPC51U68 : 2656kF, 96kR, 100MHz.M0   LQFP48_7x7    LQFP64_10x10
    line up nicely here, and that 96kRAM in the LPC51U68, looks good for this type of interpreter payload.
    One can look at those numbers, and then look at Chips' highly optimized ByteCode PASM backend in Spin2, a blender, and start to imagine a P2 C/PASM project, that could spit out
    a P2 image of a Python Interpreter....
    or, take
    https://github.com/adafruit/circuitpython/releases
    + highly optimized ByteCode PASM backend
    & optimize for speed, might even work..
    Dropping a Prop2 release into the https://github.com/adafruit/circuitpython pool would be fun to watch !
  • (c) guppy: short for "Grand Unified Propeller Programming sYstem". The dialects would be "Guppy BASIC", "Guppy Spin", etc. Seems a bit friendlier than "multiprop", but not as professional.
    I think that this name would be appropriate: guppy - BASIC like compiler. How professional sounding is Python or Perl, or...
    This is your creation, so the name is your creation, go for it.
    Ray
  • Any gluttons for punishment who want to try out the (unfinished, undocumented, unsupported) BASIC support in fastspin can grab the latest binary release from https://github.com/totalspectrum/spin2cpp/releases. Simple integer programs are working, and serial I/O to the default port works. Instead of floating point the "single" type is 16.16 fixed point (eventually this will be replaced by real IEEE float).
    Did you port Bean's Frequency Counters ok ? ( Simple & Reciprocal versions published - reciprocal gives 0.5Hz ~ 40MHz, at close to 8 digits/s precision )
    I'm porting your example from the other thread, to the FreeBASIC/PC
    FB gives this
    P2_Basic_Fibo_Test.bas(26) error 146: Default types or suffixes are only valid in -lang deprecated or fblite or qb, found ')' in ' function fibo(n)'
    P2_Basic_Fibo_Test.bas(27) error 31: Expected 'THEN', found 'return' in 'if (n < 2) return n'
    P2_Basic_Fibo_Test.bas(36) error 145: Only valid in -lang deprecated or fblite or qb, found 'let' in 'let start = getcnt()'
    P2_Basic_Fibo_Test.bas(38) error 41: Variable not declared, i in 'for i = 1 to 10'
    P2_Basic_Fibo_Test.bas(38) error 3: Expected End-of-Line, found ' i' in 'for i = 1 to 10'
    P2_Basic_Fibo_Test.bas(40) error 145: Only valid in -lang deprecated or fblite or qb, found 'let' in 'let x = fibo(i)'
    P2_Basic_Fibo_Test.bas(42) error 3: Expected End-of-Line, found ' i' in 'print "fibo "; i; " = "; x,'
    P2_Basic_Fibo_Test.bas(44) error 14: Expected identifier, found ' i' in 'next i'
    but no brickwalls, I'll post the PC results shortly...
    Here is the PC port from your P2 code.... - went quite smoothly, and hopefully, this code (with emulation bits trimmed) can eventually compile in your compiler fine ?
    ' P2_Basic_Fibo_Test.bas
    ' FreeBasic PC Port of code posted  http://forums.parallax.com/discussion/comment/1445698/#Comment_1445698
    ' Original Code posted : before porting snapshot
    '  function fibo(n)
    '    if (n < 2) return n
    '    return fibo(n-1) + fibo(n-2)
    '  end function
    '  dim as uinteger cycles
    '  waitcnt(getcnt() + 80_000_000)
    '  print "BASIC fibo demo"
    '  let start = getcnt()
    '  for i = 1 to 10
    '    cycles = getcnt()
    '    let x = fibo(i)
    '    cycles = getcnt() - cycles
    '    print "fibo "; i; " = "; x,
    '    print "took "; cycles, "cycles ("; cycles / 80.0; " us)"
    '  next i
    ' ~~~~~~~~~~~~~~~~~~~~~~~~~~ Emulation Lib ~~~~~~~~~~~~~~~~~~~~~~~~~
    Declare Function getcnt() As uinteger               '+ Drop in my P1 Emulate routines
    Declare Sub WAITCNT (WaitForwardValue As uinteger)  '+
    ' ~~~~~~~~~~~~~~~~ Code, as from WEB, # tags changes needed to FB compile ~~~~~~~~~~~~~~~~
    function fibo(n As uinteger)  As uinteger           '# fixed from  function fibo(n)
      if (n < 2) then return n                          '#   if (n < 2) return n  - original missed 'then'
    end function
    dim as uinteger cycles,  i                          '# needed to add i in FB
    waitcnt(getcnt() + 80000000)                        '# No 80_000_000 yet in FB
    print "BASIC fibo demo FreeBasic on PC Version"     'E print "BASIC fibo demo"
    Var start = getcnt()                                '#  let start = getcnt()
    for i = 1 to 25
      cycles = getcnt()
      Var x = fibo(i)                                   '#  let x = fibo(i)
    next i
    Sleep                                               '+  FB on PC waits for key here
    ' ~~~~~~~~~~~~~~~~~~~ Libray PC emulates Prop Timers ~~~~~~~~~~~~~~~~~~~~~~~~~
    ' FB Docs : If the processor has a precision timer (as the Performance Counter Pentium processors from Intel have) and the OS uses it,
    ' the precision is linked to the processor clock and microseconds can be expected.
    ' First we define some Prop SysCLK times
    Const As Double tP1_CLK = 1/80.0e6                ' Period of PropSysCLK
    Const As Uinteger t1ms = CUint(.001/(1/80.0e6))   ' Sysclks in 1ms
    Dim Shared As Double StartD,EndD                  ' Debug capture the fractional polling dT
    Dim Shared as uinteger PollCheck                  ' Debug var
    Const As Uinteger FREQ =  80000000
    Const As Uinteger ONESEC = FREQ + 4               ' Common Prop defines
      return CUint(Timer/tP1_CLK)
    end function
    ' Coded to do MOST of delay in sleep(), but that is coarse, and has poor jitter, so the final timeout uses a fast-poll of PCs
      VAR SleepRounded = ((WaitForwardValue-getcnt())/t1ms)-21   ' 20ms OK, Experimental trim-down, need finite loops 16,18ms fail 19ms is marginal, choose 21ms - test on other PC's ?
      if SleepRounded >= 0 then
        Sleep(SleepRounded)  'round down, so most of time is Sleep,
      end if
      Var AbsDiff = ABS(WaitForwardValue-getcnt() )     ' 99% of time this is small, but in rare cases, getcnt will be MAX, and WaitForwardValue will have wrapped
      PollCheck = 0
      StartD = Timer()
      While AbsDiff >= ABS(WaitForwardValue-getcnt() )  ' look for reversal of setpoint diff, diff decreases until it hits match, then starts to increase.
       PollCheck = PollCheck + 1
      wend
      EndD = Timer()
    end Sub
    '~~~~~~~~~~~~~~~~~~~~~~~~~ Original P2 reports ~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    ' Which produced this output:
    ' $ ./loadp2 fibo.binary -t
    ' [ Entering terminal mode.  Press ESC to exit. ]
    ' BASIC fibo demo
    ' fibo 1 = 1      took 147        cycles (1.8359 us)
    ' fibo 2 = 1      took 380        cycles (4.7500 us)
    ' fibo 3 = 2      took 600        cycles (7.5000 us)
    ' fibo 4 = 3      took 1048       cycles (13.0937 us)
    ' fibo 5 = 5      took 1732       cycles (21.6250 us)
    ' fibo 6 = 8      took 2876       cycles (35.9375 us)
    ' fibo 7 = 13     took 4708       cycles (58.7500 us)
    ' fibo 8 = 21     took 7656       cycles (95.6250 us)
    ' fibo 9 = 34     took 12380      cycles (154.7500 us)
    ' fibo 10 = 55    took 20060      cycles (250.5000 us)
    ' ~~~~~~~~~~~~~~~~~~~~~ PC reports ~~~~~~~~~~~~~~~~~~~~~~
    ' BASIC fibo demo FreeBasic on PC Version
    ' fibo 1 = 1    took 26       cycles ( 0.325 us)
    ' fibo 2 = 1    took 25       cycles ( 0.3125 us)
    ' fibo 3 = 2    took 26       cycles ( 0.325 us)
    ' fibo 4 = 3    took 26       cycles ( 0.325 us)
    ' fibo 5 = 5    took 51       cycles ( 0.6375 us)
    ' fibo 6 = 8    took 51       cycles ( 0.6375 us)
    ' fibo 7 = 13   took 77       cycles ( 0.9625 us)
    ' fibo 8 = 21   took 52       cycles ( 0.65 us)
    ' fibo 9 = 34   took 102      cycles ( 1.275 us)
    ' fibo 10 = 55  took 77       cycles ( 0.9625 us)
    ' larger run
    ' fibo 1 = 1    took 0        cycles ( 0 us)
    ' fibo 2 = 1    took 26       cycles ( 0.325 us)
    ' fibo 7 = 13   took 51       cycles ( 0.6375 us)
    ' fibo 8 = 21   took 77       cycles ( 0.9625 us)
    ' fibo 9 = 34   took 103      cycles ( 1.2875 us)
    ' fibo 10 = 55  took 153      cycles ( 1.9125 us)
    ' fibo 11 = 89  took 179      cycles ( 2.2375 us)
    ' fibo 12 = 144 took 256      cycles ( 3.2 us)
    ' fibo 13 = 233 took 410      cycles ( 5.125 us)
    ' fibo 14 = 377 took 770      cycles ( 9.625 us)
    ' fibo 15 = 610 took 1104     cycles ( 13.8 us)
    ' fibo 16 = 987 took 1719     cycles ( 21.4875 us)
    ' fibo 17 = 1597              took 2771     cycles ( 34.6375 us)
    ' fibo 18 = 2584              took 4413     cycles ( 55.1625 us)
    ' fibo 19 = 4181              took 7210     cycles ( 90.125 us)
    ' fibo 20 = 6765              took 7697     cycles ( 96.21250000000001 us)
    ' fibo 21 = 10946             took 12496    cycles ( 156.2 us)
    ' fibo 22 = 17711             took 20142    cycles ( 251.775 us)
    ' fibo 23 = 28657             took 32560    cycles ( 407 us)
    ' fibo 24 = 46368             took 53471    cycles ( 668.3875000000001 us)
    ' fibo 25 = 75025             took 85314    cycles ( 1066.425 us)
  • jmg wrote: »
    I looked briefly at the reciprocal version, and to get it to construct the ascii string I'll need to add character literals (or I guess we could use constants like &h20 for space, but that would be ugly; hmmm, come to think of it " "(1) would probably work too).
    I think the simple frequency counter should be a trivial port, you'll just need a subroutine to emulate COUNTERA, something like:
    sub countera(ctrmode, apin, bpin, freq, phs)
      ctra = (ctrmode<<23) or apin or (bpin<<9)
      frqa = freq
      phsa = phs
    end sub
    ersmith wrote: »
      frqa = freq
      phsa = phs
    end sub
    Yes, to give a something useful looking emulation result, I thought about
    value = phsa
    being actually
    value = phsa()
    and the phsa() function assumes some increment/seconds rate, & on each call it reads PC Timer and scales the dT.
    eg suppose we have an expected read rate of 100ms and 455kHz, that should increment 45,000 between calls, so we take the 0.100001234 type timer values,
    and multiply by 455k, with maybe some random element added if needed too.
  • Call it GLUE, or BLISS, or something else descriptive and suggestive.
    Then have fun.
  • potatohead wrote: »
    Then have fun.
    Thanks. So far it's still "fastspin BASIC"; I think for now I'll concentrate on the implementation rather than the name. Speaking of which I've uploaded a new version of fastspin with BASIC support (or you can use the [url="http://github.com/totalspectrum/spin2gui/releases]spin2gui[/url] GUI which contains fastspin). This has floating point support (library functions like sin and cos still need to be written, but the basic arithmetic and printing all work), some improved but still incomplete docs, and many improvements to the BASIC compiler, as well as some Spin bug fixes.
  • Is there a summary somewhere of the BASIC syntax that it accepts?
  • I've attached some new demos: a revised fibo() demo which can also compile under FreeBASIC, and a frequency counter demo based closely on Bean's Freq Counter3.pbas.
  • Is there a reason you coded fibo like this:
    function fibo(n as integer) as integer
      if (n < 2) then
        return n
      end if
    end function
    rather than this?
      if (n < 2) then
        return n
      else
      end if
    end function
  • David Betz wrote: »
    There's a basic.md in the fastspin docs/ folder, but it's incomplete.
      if (n < 2) then
        return n
      end if
    end function
    rather than this?
      if (n < 2) then
        return n
      else
      end if
    end function
    Either one would work. I think I originally wrote
    if (n < 2) return n
    which FreeBASIC didn't like, so I changed it to a multi-line if and didn't bother to put in the else.
    (I wanted both demos to compile with FreeBASIC, hence the #ifdefs and dummy stuff for PC support.)
  • ersmith wrote: »
    if (n < 2) return n
    I thought maybe you did it that way because it was slightly faster.
    No, both forms generate exactly the same code. There's a branch optimization that gets rid of the unnecessary branch for the "else".
  • ersmith wrote: »
    Do you do your optimizations on the parse tree or on the generated PASM code?
    Originally the optimizations were all on the PASM code, but I added some common sub-expression elimination and loop strength reduction on the parse tree, and I'm gradually trying to move some others up to the parse tree as well.
  • I just checked out the sources for spin2cpp and tried building them and got the following error. Any idea what's going wrong?
    Davids-Mac-mini:spin2cpp dbetz$ make
    mkdir -p ./build
    bison -t -b ./build/spin -d frontends/spin/spin.y
    frontends/spin/spin.y:7.9-18: syntax error, unexpected identifier, expecting string
    make: *** [build/spin.tab.h] Error 1
  • dgatelydgately Posts: 1,639
    edited 2018-09-22 12:49
    David Betz wrote: »
    mkdir -p ./build
    Building on a Mac :-)
    I had the same problem... Turns out that Bison 2.3 on macOS is an old version that does not like the line in spin.y:
    %define api.prefix {spinyy}
    I had to use homebrew to get a 3.0.4 version of Bison. Homebrew will place it at:
    /usr/local/Cellar/bison/3.0.4_1/bin/bison
    You'll then need to mod the Makefile to point to that bison version
    change: YACC = bison
    to: YACC = /usr/local/Cellar/bison/3.0.4_1/bin/bison
    dgately
    mkdir -p ./build
    It appears that they changed the behavior of %api.prefix between versions of bison. I hate that kind of thing :( and I should have avoided the bison specific stuff anyway. The code's updated now so it should work with all bison versions, as well as byacc (although the byacc error messages aren't as nice as bison's, so some of the tests for error messages will fail).
  • ersmith wrote: »
    Thanks, Eric!
  • I've updated the spin2cpp/fastspin binaries at https://github.com/totalspectrum/spin2cpp/releases to version 3.9.3. This version has a number of bug fixes (applicable both to Spin and to BASIC) and adds the garbage collecting memory manager. For now the heap is a fixed 256 bytes long, but that will become settable by the user soon. The garbage collector is used for string operations like string concatenation with +, left$, and right$. For example, even though the heap is only 256 bytes long, the following program can run to completion:
    function dec$(n as uinteger)
      dim digit
      if n < 10 then
        return chr$(asc("0") + n)
      else
        digit = n mod 10
        n = n / 10
        return dec$(n) + chr$(asc("0") + digit)
      end if
    end function
    function greet$(s$)
      return "hello, " + s$
    end function
    dim orig$
    dim n as uinteger
    orig$ = greet$("world")
    print orig$
    for n = 1 to 100
      print greet$(dec$(n))
    next
    print orig$
  • How do you handle the "main" program? It looks like it consists of anything outside of a function definition but does it have to be all together or can you have it interspersed between function definitions?
