Issues with Yaw control or Rudder power for Elev8-V3 Quadcopter
Hi,
I'm facing issues with Yaw control or Rudder power for Elev8-V3 Quadcopter.
Rudder power (Yaw) is not working properly, it is fluctuating i.e., it is yawing right and left continuously eventhough if I'm giving any one side rudder control in Spektrum DXe transmitter.
I've followed all the instructions in uploading firmware, gnd. stn. software and ESC calibration as given in the website.
Pitch and Roll controls are working fine, but Yaw control / rudder power continuously fluctuating from +ve to -ve value back and forth in gnd. stn. software.
Please give some solution to this issue.
Are you using the defaults for the transmitter?
What positions are the switches in?
Yes, i'm using defaults mode and switches allocation in the DXe transmitter.
As you mentioned,
Throttle, Aileron, Elevator and Rudder - channels 1-4
I've mapped Gear switch - ch5 (flight mode),
aux is not mapped,
kept in Hi mode as per the instruction in manual.
Can u guide me with the yaw control situation, because after all the calibration done its fluctuating from +ve to -ve by intervals of 1-2seconds, i dont know why!!
P.S.: I've not touched any gain settings so far.
What versions of firmware and ground control? This is through USB cable and not XBEE, correct?
Yes, it is from latest versions of firmware and ground station of parallax, not from XBEE.
Actually that Yaw power is still fluctuating from +ve to -ve values in gnd stn.
Later, with some guts we took it out for the test flight and surprisingly it flew properly.
I have been wondering what was set up for channel 6. I didn't think to try the bind button as I (naively) thought it was a radio-level control not bound to a TX/RX channel. Thanks for posting this, and I'm glad I found it.
Welcome to the forums!
I was quoting from the assembly manual, Step 21:
https://learn.parallax.com/print/book/export/html/1186
Myself, I would move Chan 6 to the two position Aux switch.
Looks like you purchased the full Elev-8 kit. If you have any questions with the build, we invite you to start a new thread in Robotics to help you along.
