SD Card HUB
AwesomeCronk
Hello, does anyone know where I can find something like this, only with about 5 SD card ports? I am wanting to upgrade my laptop's memory, but have found that my only option down that road is SD cards and flash drives, all devoted to ReadyBoost. Thanks in advance!
You can get 5TB laptop internal HDDs, isn't that better than an external thingy dangling around waiting to be knocked out in the middle of a copy?
Per Peter, speed is likely be an issue.
I have a drawerful of micro SD (TF) card adapters leftover from various camera drones. I wonder if you could use 5 of those with 5 uSD cards in a 5-port USB hub.
Adapter like: https://www.ebay.com/itm/253319609214 or https://www.ebay.com/itm/323213434470
Yes, some of the cards use wear leveling. But there's usually some critical regions on the card that end up being updated frequently.
And, is it worth it?
https://technet.microsoft.com/en-us/library/ff356869.aspx
https://directron.com/cr4sdhub.html?gsear=1&gclid=EAIaIQobChMI8LOuqcGP2wIVC77ACh0p2wkFEAQYAiABEgJeYfD_BwE
Might be worthwhile for storing data that is read often but rarely changes.
I have seen this before. I was thinking of buying it, but decided against SD cards.
Yes, that's their intended purpose. Camera pictures/video for example.
But as additional RAM (swap disk)? Not for me.
