New build guide for Micromite Companion v1.2
in Propeller 1
I put together an updated build guide for the MMC v1.2 (the previous one, by Jeff Ledger, is for v1.1a and is no longer available online).
http://fireheadfred.com/mmc_build_webpage/mmc_build_guide2.htm
Any feedback is greatly appreciated!
Cool that you keep this updated and alive, thank you
o It says 'resister' one place (about blue 1k resistors)
o Step 6, "well" instead of "we'll"
o Step 7: Likewise
o Step 8: Likewise
o Step 9 c: "isnt", "youll"
o Socket test: "theyre"
Btw, the reason > 2GB cards are so different is that they are SDHC cards, they are blocked differently and as you found, formatting them to 2GB doesn't help. These cards need a different driver.
o Paragraph before step 11: "its" should be "it's" (normally the problem is the other way around!
I skimmed it very quickly so it's possible I didn't find all typos.
Its something I was going to build but never got round to it. Then when the website disappeared I forgot about it.
There still remains....
http://www.instructables.com/member/Propellerpowered/instructables/
which contain some tutorials (instructables) on the companion and other stuff.
There seems to be no links attached to these items and I cant find a link to them.
There is also...
http://www.instructables.com/id/Building-your-own-Micromite-Companion-Minicomputer/
but I cannot find a source for the manuals or software.
Dave
Do you have Jeff's 1.1?
http://www.thebackshed.com/forum/forum_posts.asp?TID=4685&PN=1
The only thing that I did differently was to tin the pads on the PCB for the SD card socket. Go easy on the solder, and put the socket on the board and take you soldering iron and touch it to each pin while pushing gently on the socket (not too hard, you will bend the cover of the SD socket). Once I had it soldered down on the end, I touched up the solder on the two side mounted pads for a bit more strength.
The SRAM shares P0, P1, P2 with the SD card. Based on the v1.2 instructions, 'The "Companion Mode" firmware is updated from time to time. It is stored in the 32K, 8pin EEPROM on your board.'
Is this the only time the 23K256 SRAM is used?
Does this hardware change from v1.1 affect any of the programs written for the original Micromite Companion or users who added the 28 pin Micromite 32MX170F256 to a regular Propeller board to run MMC programs?
