BS2-SX PDB product documentation — Parallax Forums
I had acquired aboard through the generosity of our own Buck Rogers. But I cannot seem to find any information on it. Though I did come up with a schematic from an earlier version.
Power in looks to be 9 volts, if the silk screen is not covered up by a component. That just seemed a little unusual, since there is no range of voltage input.
I am not sure if this is the actual product#, and doc title: 28138-PDB-v2.0.pdf
The board is labeled Professional Development Board Rev C.
Thanks for any help in advance.
  • Got a picture?
    edited 2017-07-20 13:43
    My Rev E Board shows 6-12 volt input.
  • Thanks for the reply Jim.
    I looked over the revision D doc. And it looks like one of the big changes is with the power supply. Instead of a single fixed 9v input, there is a voltage range from 6-12v. Other than that, this will help a lot.
    Thanks again,
  • Here's a picture that got left out of the last post.
    BTW: sorry for the flipped Flip.
    2080 x 1168 - 480K
  • Just found my Rev B board, and it calls for 9 volt input, so power supply must have gotten upgraded.
    edited 2017-07-20 15:14
    Publison wrote: »
    Maybe something I can do with a regulator swap. My bench has a 12v barrel plug octopus, and I don't need any more clutter.
    EDIT: I'll have to come up with a 9v adapter.
    MikeDYur wrote: »
    Publison wrote: »
    That's a 5V linear regulator with a heat sink on your board so you should be ok with a 12V input unless the input capacitor rating is 12V or less or you are adding a lot of circuitry to draw more current.
    Your other option is to swap it for a 3 terminal switching regulator.
  • Don't forget VSS on that board is 5v not 3.3. The timer, the switches, RS232 level shifter all will make 5 v, need resistors to limit current when used as FLiP inputs.
    edited 2017-07-20 15:19
    kwinn wrote: »
    I'm guessing without looking at a schem, that the 9v supply is important to the microcontrollers.
  • The Rev E has the same regulator with the heatsink. Should be good at 12 volt.
    I had thought about that, but thanks for the reminder. I can't stand that sinking feeling when you make a mistake like that.
    Good call Tom.
  • MikeDYur wrote: »
    kwinn wrote: »
    No the regulator just makes 5 volts for everything on the board.
  • Publison wrote: »
    What was the idea of the specific 9v input?
  • @Publison, Looks like at least the audio amp has a 9v input, If this is the right document. ;)
  • The chip has a wide supply range: 4-12v, so it could be on the 5v bus.
    edited 2017-07-20 16:00
    MikeDYur wrote: »
    LM386 has a wide voltage input:
    http://www.ti.com/lit/ds/symlink/lm386.pdf
    So 12 volt input should be OK.
    The VCC on the LM386 takes it's voltage from the input voltage.
    edited 2017-07-20 22:25
    I'm thinking this is a somewhat a heavy duty board, five volts @ five amps, is no small potatoes. Just an awesome board anyway, not only because of the capability of different MCU's.
    Really happy to have one in the collective,
    thanks again Buck.
    BTW: this will be my high current, five volt source from now on.
    MikeDYur wrote: »
    thanks again Buck.
    Five amps out? Not likely with a 12V input. That would be 35W dissipation, which is way more than that tiny heat sink can dissipate.
    edited 2017-07-21 12:13
    kwinn wrote: »
    Datasheet for LM-1084 shows a current capability of 5A.
    Though the product doc for the board says 5V @ 1A. I really didn't think that TO-220 case and that heatsink were designed for high current on this board. But I'm am stumped on the choice of regulators. And I'm interested in finding the changes made from version C - D.
  • Even the documentation doesn't jive.
    Revision D documentation says 6-12v input, but the schematic says 9v in.
    Yes, the data sheet states 5A, but it also states that it is a "low drop out voltage" regulator, and the applications listed for it are either low current or uses where there is a relatively small difference between the input and output voltages. Fine for powering your board with a 12V input as long as you do not add some high current circuitry to the 5V output.
  • kwinn wrote: »
    I have the board hooked up to a 12 volt switching supply, and is doing fine. The Flip is controlling Emic2 which is conected to the PDB on-board amplifier.
    It must be me but, the amplification never seems to be enough these days. ;)
  • About the only thing I haven't found is what battery is used in the RTC. 3v Lithium, but the size will have to be measured, unless someone has it off the top of their head?
    Also I came across this great Nuts & Volts document on the BS2 PDB.
  • It's a CR2032 battery. Pretty common.
  • MikeDYur wrote: »
    That was written by our friend JonnyMac.
  • Publison wrote: »
    Thanks.
  • I robbed one out of something else, but it Is too big for the holder. Something else that has been changed?
    2080 x 1168 - 358K
