BS2-SX PDB product documentation
MikeDYur
in BASIC Stamp
I had acquired aboard through the generosity of our own Buck Rogers. But I cannot seem to find any information on it. Though I did come up with a schematic from an earlier version.
Power in looks to be 9 volts, if the silk screen is not covered up by a component. That just seemed a little unusual, since there is no range of voltage input.
I am not sure if this is the actual product#, and doc title: 28138-PDB-v2.0.pdf
The board is labeled Professional Development Board Rev C.
Thanks for any help in advance.
https://www.parallax.com/downloads/professional-development-board-schematic
I looked over the revision D doc. And it looks like one of the big changes is with the power supply. Instead of a single fixed 9v input, there is a voltage range from 6-12v. Other than that, this will help a lot.
Thanks again,
BTW: sorry for the flipped Flip.
Maybe something I can do with a regulator swap. My bench has a 12v barrel plug octopus, and I don't need any more clutter.
EDIT: I'll have to come up with a 9v adapter.
That's a 5V linear regulator with a heat sink on your board so you should be ok with a 12V input unless the input capacitor rating is 12V or less or you are adding a lot of circuitry to draw more current.
I'm guessing without looking at a schem, that the 9v supply is important to the microcontrollers.
I had thought about that, but thanks for the reminder. I can't stand that sinking feeling when you make a mistake like that.
Good call Tom.
No the regulator just makes 5 volts for everything on the board.
What was the idea of the specific 9v input?
LM386 has a wide voltage input:
http://www.ti.com/lit/ds/symlink/lm386.pdf
So 12 volt input should be OK.
The VCC on the LM386 takes it's voltage from the input voltage.
Really happy to have one in the collective,
thanks again Buck.
BTW: this will be my high current, five volt source from now on.
Five amps out? Not likely with a 12V input. That would be 35W dissipation, which is way more than that tiny heat sink can dissipate.
Datasheet for LM-1084 shows a current capability of 5A.
Though the product doc for the board says 5V @ 1A. I really didn't think that TO-220 case and that heatsink were designed for high current on this board. But I'm am stumped on the choice of regulators. And I'm interested in finding the changes made from version C - D.
Revision D documentation says 6-12v input, but the schematic says 9v in.
I have the board hooked up to a 12 volt switching supply, and is doing fine. The Flip is controlling Emic2 which is conected to the PDB on-board amplifier.
It must be me but, the amplification never seems to be enough these days.
Also I came across this great Nuts & Volts document on the BS2 PDB.
That was written by our friend JonnyMac.
Thanks.
