Directly driving Nema 8 stepper motor with the Propeller — Parallax Forums
TubularTubular Posts: 4,745
edited 2017-06-19 22:32 in Propeller 1
The recent cnc/gcode threads reminded me to try this, and once again the Propeller hasn't let me down. This is an 'educational' demo of a couple of H-bridges constructed from bare propeller io pins.
To get enough current to rotate the motor, two pins drive each leg of the bridge, so 8 pins for the 2-phase stepper. There is a 10 ohm resistor between them to limit the current slightly, should the pins not accidently be driven simultaneously (prop fet switch resistance is ~ 28 ohms, the two including 10 ohm make an approx 16 ohm switch).
As you'd expect, the torque produced isn't amazing, but you could use more io to strengthen, or find a stepper with higher coil resistance (this one is from pololu and has about 8 ohm phase resistance). However for demonstrating basic rotation and perhaps some concepts like micro stepping and loss of sync, its going to be good enough.
Hoping to run 3 demo axes from a single prop, we'll see.
Heres photos and a vid. Will post code shortly, want to double check currents so I don't blow up a whole lot of other peoples props.
  • TubularTubular Posts: 4,745
    edited 2017-06-19 23:11
  • Here's a photo. Nema 8 motor is connected to P0-7 of the Flip module.
    960 x 1280 - 253K
    edited 2017-06-19 23:23
    And here's the connection diagram
    368 x 410 - 12K
  • The propeller pins will not survive long with that arrangement, there simply isn't enough current drive and isolation from voltage spikes between the Stepper and the Propeller. You at least need a SN754410NE or similar... and to control current, PWM is usually used.... i.e. 12V across an 8 Ohm coil at 100% would be 1.5 Amps .... with a 66% Duty cycle the average current would be limited to just under an Amp (990mA)
    edited 2017-06-20 01:00
    Yeah I'm curious about how long it lasts too. Going strong so far though.
    When I was looking at propeller resistive DAC arrangements some time ago, I remember noting the max current with an external 1 ohm resistor (across 2 pins, 1 output high, 1 output low) was only just over the 40mA abs max, due to the N and P fet resistances ~28ohms, and lowering the rails slightly might be enough to get under that
    Agreed re spikes though. I'm going to look at some better diode options shortly
    edited 2017-06-20 01:41
    Beau is there some kind of current limiting on the P1 pin drivers? When I drive into a 7.5 ohm load, it pulls up short of 40mA. This is what I get, using the adjacent pins to measure rail sag
       outa[12]~     '                   measure 14mv rise off ground on this pin
       outa[13]~     ' 7.5 ohm resistor  measure 1.661v at this node
       outa[14]~~    '  between P13&P14  measure 1.960v at this node
       outa[15]~~    '                   measure 19mv droop from 3v3 on this node
                     'Calcs:-
                     ' Res current=(v14-v13)/7.5 ohms = 39.9mA
                     ' P fet resistance 1.297v/39.9mA = 32.5ohms
                     ' N fet resistance 1.661v/39.9mA = 41.7ohms
    My other question is, since all the voltage action is around that narrow central range (1.6~2v), couldn't I clamp the spikes to a different rail (eg an actively driven midrail, or blue led clamps down to Vss/up to Vdd). That would relieve the P1 ESD diodes, right?
  • jmgjmg Posts: 15,194
    Tubular wrote: »
    .... is there some kind of current limiting on the P1 pin drivers? When I drive into a 7.5 ohm load, it pulls up short of 40mA. This is what I get, using the adjacent pins to measure rail sag
    All MOSFETS look like resistors at saturation,and current sources/sinks, when well away from saturation.
    Most MCU data sheets give curves showing this.
    Tubular wrote: »
    You could use schottky diodes to clamp better, and could parallel more pins for higher drive, but the question remains.... Why ?
    The P1 has one of the highest cents-per-IO price of any MCU, so using the pins on a P1 to save a 3c mosfet seems illogical ?
  • Don't think cost jmg, think selling price
  • For high performance stepper driving a chopper driver like the DRV8825 will stomp all over
    this approach (*), and doesn't need 8 schottky diodes either!
    Direct drive for one of the 6mm sized steppers is more reasonable (they are typically used in
    auto-focus mecanisms etc, and cheap on eBay). Even those like 75mA or so which is well above
    a single pin drive, but are a good match for 3.3V
    (*) more torque, much higher top speed, allows microstepping...
  • Tubular wrote: »
    You want to sell this design?
  • When the Propeller was new, Beau ran some tests on the I/O pins. At room temperature (if I remember correctly) the I/O pins could withstand a short circuit to either ground or Vdd (3.3V) indefinitely (well, for a while at least) at around 30mA. That's not a guarantee (see the datasheet for that) but it does show that the I/O pin structures are fairly robust. On the other hand, don't try to drive a motor or other inductive load without the reverse connected diodes across the coils. Without them, you run the risk of destroying the whole chip.
