caskaz - I added a I2C clock delay feature to the kernel so I will check it out now and calibrate it for slow 100kHz devices, 400khz, and 1MHz. Check back in about 30 minutes.
caskaz - compile the latest kernel and EXTEND and you can select I2C bus speeds between 100kHz, 400kHz, or fast.
I happened to have a lot of these older SAA1064 LED driver chips that only work at 100kHz. Here you can see it being detected on the 100kHz setting but not at 400kHz.
After start-up Tachyon, I load i2c_charLCD.fth.
Executing demo, it operate well. WAVE takes 1.998sec.
Executing demo after I2C100, only WAVE operate(3.690sec).
Font-display don't oparete. BarGraph is strange.
@D.P - I finally just had a look at APPEND and it seemed to be working but there were two things I fixed:
1 - Change absolute SD memory address to relative FS address
2 - set file read pointer as well as file write pointer (APPEND is normally a write operation)
Now bear in mind that APPEND returns with the file read/write pointer which is a relative offset from the start of the file and so it is also the length of the text file itself.
( 0003 $44A2 ok ) FOPEN CHARLCD.FTH
...opened at 0000.4840 for 65536
( 0004 $44A2 ok ) 0 $40 FS DUMP
0000.0000: 54 41 43 48 59 4F 4E 20 56 34 0D 0D 49 46 44 45 TACHYON V4..IFDE
0000.0010: 46 20 43 48 41 52 4C 43 44 2E 66 74 68 0D 40 72 F CHARLCD.fth.@r
0000.0020: 65 73 74 09 6F 72 67 0D 46 4F 52 47 45 54 20 43 est.org.FORGET C
0000.0030: 48 41 52 4C 43 44 2E 66 74 68 0D 7D 0D 0D 70 75 HARLCD.fth.}..pu
( 0005 $44A2 ok ) 0 APPEND .
11010
( 0006 $44A2 ok ) -$100 fread +! (cat)
(HUBLCD) BEGIN lcdch W@ 0= UNTIL $100 OR lcdch W! ;
pub LCD lcdtask C@ IF ' (HUBLCD) ELSE ' LCDEMIT THEN uemit W! ;
pub LCD.TASK
!RP !SP
lcdtask C~~
BEGIN
lcdch W@ ?DUP IF LCDEMIT lcdch W~ THEN
AGAIN
END
?BACKUP
( 0007 $44A2 ok )
@Peter - as you maybe remember I'm working on Linux with a Makefile to build Tachyon. Therefore I appreciate that you "back"-moved the xxx-4r4.FTH naming convention to xxx.FTH and separate different versions into versioned folder names.
There are two more things which in your filename convention do "makefiling" harder than they have to:
1. remove whitespaces in filenames
2. move "Tachyon Vx.x.spin" to "tachyon.spin"
this would ease up things and reduce makefile complexity a lot.
Thanks in advance - proplem
Funny thing, just a few moments ago I was looking at FAT32 file directory structures and what are considered valid characters for 8.3 names and space is one of them, but not for lead or trailing characters. Anyway I prefer not to use them but some files still have them in long file names although they are being updated to conform to 8.3. Not that I'm a fan of such short file names but I abhor the kludge of a kludge, that abomination that is called LFN. I suppose I could change the kernel name to TACHYON.SPIN which unfortunately is not 8.3 and the whole reason I want 8.3 is for clean, quick and simple embedded use.
caskaz - most of your problems seem to be related to sloppy stack use. In this instance you have commented out KEY in a BEGIN UNTIL and it is probably reading garbage off the stack and exiting the routine. Of course you need a BEGIN AGAIN for the task or alternatively you could just as easily use a timer task with a 10ms timeout. Once you have a routine that is only called every 10ms or so then much of your debounce is taken care of and you don't have to keep track of the time either.
To use a timer task you must create a TIMER variable, have your routine reload that timer each time it is called, set an ALARM vector for that timer pointing to your routine, and finally you need to kick it off to get it started:
TIMER mytimer ( create a TIMER variable )
: MYROUTINE
YADA YADA
10 mytimer TIMEOUT ( reload the timer )
: MYINIT
YADA YADA BLAH BLAH ( do what you do )
' MYROUTINE mytimer ALARM ( point to your code )
10 mytimer TIMEOUT ( kick it off - plus this links the mytimer variable into the timer task list )
btw, a timer routine is called every time from the timer task so you don't need any BEGIN AGAIN plus it's also important that your routine execute and return in well under 1ms so that it doesn't block other timer functions.
Peter - thinking of Chuck Moore who had to reduce FOURTH to FORTH which has become a great name and according to the rule that (white) space is a delimiter between words i think of a file name as one word in forthish manner. Think also of "ifdef file name.FTH" - oops.
It lasted a bit until I acknowledged - ".SPIN" is not .3 . This is an issue. I saw you experimented already with .spn but one is not used to it. Ugly isn't it?
As long as we don't write a spin interpreter on top of tachyon which could load spin files from sdcard we can accept the .spin inconvenience - do we?
Thank you very much for applying this. As the new naming has settled I will refactor my Makefile and publish it.
I can't understand TIMER at all.
But I want to think about it lator.
I try to do code below.
\ Constants
#P2 == phaseA
TABLE encoder_tbl
0 , 1 , -1 , 0 ,
-1 , 0 , 0 , 1 ,
1 , 0 , 0 , -1 ,
0 , -1 , 1 , 0 ,
#800000 == 10msec
\ Variables
long lastDebounceTime
long pos
word prev
byte debounce
\ Main
\ Get current encoder status(b1:b0)
\ ( -- n1 ) n1:encoder status
: status INA COG@ phaseA SHR 3 AND ;
\ Get encorder's position
: count
0 lastDebounceTime !
0 debounce C!
0 pos !
0 prev W!
BEGIN
\ Eliminate chattering
status DUP ( 2bit 2bit )
prev W@ phaseA SHR <> ( 2bit 1/0 )
IF
\ If encoder is under debouncong
debounce C@ 0=
IF
CNT@ lastDebounceTime ! 1 debounce C!
ENDIF
ELSE
0 debounce C!
ENDIF
debounce C@ ( 2bit 1/0 )
IF
CNT@ lastDebounceTime @ - 10msec >
IF
DUP 1 ( 2bit 2bit 1 )
ELSE
DROP 0 ( 0 )
ENDIF
ELSE
DROP 0 ( 0 )
ENDIF
\ Update encoder position
IF
prev W@ OR 4 * encoder_tbl + @
pos @ + pos ! \ Update pos
phaseA SHL prev W!
ENDIF
0
\ pos @ . SPACE
\ KEY
UNTIL
: test
' count TASK? RUN \ Run countr on anothrt cog
#10 ms
BEGIN pos @ . SPACE #100 ms KEY UNTIL
There are 2 problem.
1. After executing it, count should be 0. But it is 3 or -2.
2. Executing it, sometimes [Error - cog out of range] occur.
But count-up/down operate when rotating encoder.
Stack should be no data . But there are data on stack.
Executing "demo", no operating and no error.
After 'I2C400', demo operate well.
After 'I2C100', only WAVE operate well.
Font and BarGrapf is NG. But no error.
\ Constants
#P2 == phaseA
TABLE encoder_tbl
0 , 1 , -1 , 0 ,
-1 , 0 , 0 , 1 ,
1 , 0 , 0 , -1 ,
0 , -1 , 1 , 0 ,
#800000 == 10msec
\ Variables
long pos
word prev
byte debounce
\ Main
: count
0 debounce C!
0 pos !
0 prev W!
BEGIN
IF
debounce C@ 0=
IF
ENDIF
ELSE
0 debounce C!
ENDIF
IF
IF
ELSE
DROP 0 ( 0 )
ENDIF
ELSE
DROP 0 ( 0 )
ENDIF
IF
phaseA SHL prev W!
ENDIF
0
\ pos @ . SPACE
\ KEY
UNTIL
: test
#10 ms
Fix this code up to suit your exact need. It currently compiles and returns 0 ever 10 ms, stops with pressing any key.
I don't have any hardware to attach so only 0s. This is timer based code as Peter suggested.
Remember to make your count word as fast as possible, < 1ms else you can hammer the other timers. Timers are very powerful in Tachyon and look how simple the code becomes, nice!
TACHYON V4
IFDEF encoder.fth
@rest org
FORGET encoder.fth
pub encoder ." encoder 2017/06/17 23:02:16 " ;
@org W@ == @rest --- remember
2017/06/17 23:00:17
Translated Wii_nunchuk to Tachyon
Inserted chattring-procedure
3V3
10kohm
| A -----------
P0 --------------| Rotary |
GND ----| Encorder |
P1 --------------| |
| B -----------
10kohm
3V3
prev current status
0 0 stop 0
0 1 CW 1
0 2 CCW -1
0 3 invalid(=stop) 0
4 0 CCW -1
4 1 stop 0
4 2 invalid(=stop) 0
4 3 CW 1
8 0 CW 1
8 1 invalid(=stop) 0
8 2 stop 0
8 3 CCW -1
C 0 invalid(=stop) 0
C 1 CCW -1
C 2 CW 1
C 3 stop 0
\ Constants
#P2 == phaseA
TABLE encoder_tbl
0 , 1 , -1 , 0 ,
-1 , 0 , 0 , 1 ,
1 , 0 , 0 , -1 ,
0 , -1 , 1 , 0 ,
#800000 == 10msec
\ Variables
long pos
word prev
TIMER enc_timer ( create a timer variable )
\ Main
: count
status pos !
0 prev W!
phaseA SHL prev W!
10 enc_timer TIMEOUT ( reload the timer to fire in 10 ms again )
: test
' count enc_timer ALARM ( point enc_timer to your code )
15 enc_timer TIMEOUT ( initial start up after 15 ms - links the enc_timer variable into the timer task list )
BEGIN pos @ . CR 100 ms KEY UNTIL
\ ?BACKUP
END
re @D.P - yes, I actually tidied up a version too, there were far too many IF ELSE THENs for my liking that only end up passing more flags rather than doing anything, all it needs is some actual logic and called every 10ms from the timer to handle the debounce easily. Here's one little thing I did in that you were using longs in the table to read out -1, 0, or 1 but you only need byte values 0,1,2 from which you subtract one.
Hi Peter,
I was able to repeat these results thanks. I tried to fix up V3 also but no joy, no worries. Gotta port to V4 at some point.
V4 EASYFILE has a lot of enhancements and there are more coming. I'm even looking at implementing features that enhance embedded FAT32 operation yet are not incompatible with FAT32 itself. For instance I like to preallocate clusters so even an 11k file might have 64KB or 1MB allocated since memory is so plentiful yet an APPEND on a text reveals that it is 11k but has plenty of room to grow. In fact the cluster size of 32k in FAT32 means that even a 0 byte file will take 32kB anyway, so that is a form of preallocation. But if I update the file size to 11k I still want to know what the maximum size of the file is without scanning the cluster chain so to this end I am retasking some of the directory entry fields to indicate the max size and then I am also grabbing the last sector of the last cluster of a file and using that simply for file properties. Anyway, there are quite a few things I'm looking at doing, maybe even using the SD card to augment VGA memory seeing that I could read in 16kB every frame.
BTW,
I cannot understand TIMER.
Although there is not BEGIN-UNTIL, pos update?
[#10 enc_timer TIMEOUT] update pos?
\ Constants
#P2 == phaseA
TABLE encoder_tbl
0 , 1 , -1 , 0 ,
-1 , 0 , 0 , 1 ,
1 , 0 , 0 , -1 ,
0 , -1 , 1 , 0 ,
TABLE encoder_tbl
1 | 2 | 0 | 1 |
0 | 1 | 1 | 2 |
2 | 1 | 1 | 0 |
1 | 0 | 2 | 1 |
#800000 == 10msec
\ Variables
long pos
word prev
byte debounce
TIMER enc_timer
\ Main
: count
status pos !
0 prev W!
status DUP
\ prev W@ OR 4 * encoder_tbl + @
prev W@ OR encoder_tbl + C@ 1-
phaseA SHL prev W!
: test
#15 enc_timer TIMEOUT
END
\ ?BACKUP
It's not that hard.
your count word is being called every 10 ms
inside of count this line resets the timer to fire again
in your test word the ALARM vector for this enc_timer is set to your count word
then the
starts the timer initially after 15 ms
Hey you are missing that ALARM line in your test word code, go paste it back in from my example else count will never be called
: test
Got it, keep moving forward, I will port stuff forward. Now about that upper lower case thing during compile?
@D.P - During interactive mode there is no need for fast searching so everything gets converted to uppercase for searching but during TACHYON block load it will search without any conversion. In any case just say ON ANYCASE or OFF ANYCASE if you still want it to be case sensitive during interactive use.
caskaz - IF ELSE THEN are good for deciding what to do rather than passing that decision on in the form of flags. The encoder can actually be reduced to a couple of lines or so of easy to read code if you think about how the encoder works. Translating from other languages or even other Forths is almost invariably inefficient and hard to read.
The TIMER task runs in its own cog and besides maintaining runtime and soft RTC always scans a linked list of user timers every 1ms. All you need to do is to create a timer variable, an optional do something vector on ALARM. If you want your code to run repeatedly then all you do is simply reload the timer.
Create a timer variable
TIMER mytimer
Load that timer with a large enough value
1000000 mytimer TIMEOUT
and you can watch it count down
mytimer @ .
When it counts down to zero it will stop but if an ALARM vector is set it will execute that. Also, when TIMEOUT is first executed the timer variable is added to the linked list so you can have as many timers as you like, even ones that count up etc. Have a look at that section in EXTEND.
Can anybody generally explain how error messages (generally or especially in v4r4) have to be understood?
When I paste EASYNET-4r4.FTH, I get:
( 0001 $4648 ok ) ( Please define +FTP to IFDEF compile FTP and HTTP servers )
( 0002 $4648 ok ) TACHYON V4
Propeller .:.:--TACHYON--:.:. Forth V4.4 DAWN 440170616.2330
( 0547 $4F46 ++ ) ??? in BLKSEND at >L
( 0548 $4F46 ?? ) ??? in BLKSEND at IX
( 0551 $4F46 ?? ) ??? in BLKSEND at IX
??? in BLKSEND at L>
( 1417 $5356 ok )
End of source code, 0004 errors found Load time = 1343124720 cycles at 96MHz = 13c
Code bytes used = 3342
CODE:$5356 =20822 bytes NAME:$686A =2966 bytes DATA:$79EA =986 bytes =5396 byt)
( 1418 $5356 ok )
( 1419 $5356 ok ) ' EASYNET +INIT
( 1420 $5356 ok )
( 1421 $5356 ok ) ?BACKUP
The first number in the prompt (for example)
isn't the line number where the error occurs. I tried removing all empty lines but that isn't getting better maybe also comment lines have to be removed?!?
edit: Maybe an explanation could be inserted into the google docs Tachyon + V4 "Dawn" ?
proplem - I have updated a version of EASYNET for V4r4.
In V4r4 the top of the loop stack is the index both for DOFOR and FOR so there is no longer any need for IX as I is the same for both as it is also for anything pushed onto the top of the stack too.
EDIT: I just realized that I removed >L and L> so I have made the change to EASYNET as well.
The trouble with line numbers is that they aren't counted during block comments so the error reports a different line number. If I can I will see if I can fix it.
caskaz - thanks for your persistence and demonstration of the practical applications of Tachyon.
If you use TASK? it will find the next cog that is free, however, if you the TASK? again for the same code it will find find the next cog that is free other than the one it is already running in. I normally just specify a cog to use.
Here is a list of ones that are used
0 = Tachyon console
1 = Console serial receive
2 = Tachyon TIMER task
3 = F32
4 = free
5 = free
6 = free
7 = free
F32 isn't really being used at the moment but it might be fully utilized in the near future and become an integral part of Tachyon.
When you get a free moment, try those simple things I last mentioned concerning timers. I'm sure you will see how they can be very useful. Even without ALARM vectors you can easily setup a timer for 10ms for instance and test for timeout like this:
TIMER mytimer
10 mytimer TIMEOUT
( snippet to test for timeout )
mytimer TIMEOUT? IF <do stuff> THEN
The timer task also maintains a soft RTC which can also be used with a hardware RTC for faster "cached" access to the current time rather than the delay required to read the real RTC.
I modified code.
Wave takes 1.805sec
I try to translate Wii-nunchuk to Tachyon.
Wii-nunchuk is for 100kHz.
This operate well on PropForth.
But Not operating on Tachyon.
Wii-nunchuk's slave-address had checked by lsi2c.
I attached PropForth-file and Tachyon's test code.
Please teach me wrong part in test code.
Now that is really handy, I'll APPEND my notes
I reloaded TachyonV4.4.spin and EXTEND.fth.
But it is strange.
There are WORD(I2C400 and I2C100).
It seems to not operate.
( 0003 $44A2 ok ) FOPEN CHARLCD.FTH ...opened at 0000.4840 for 65536 ( 0004 $44A2 ok ) 0 $40 FS DUMP 0000.0000: 54 41 43 48 59 4F 4E 20 56 34 0D 0D 49 46 44 45 TACHYON V4..IFDE 0000.0010: 46 20 43 48 41 52 4C 43 44 2E 66 74 68 0D 40 72 F CHARLCD.fth.@r 0000.0020: 65 73 74 09 6F 72 67 0D 46 4F 52 47 45 54 20 43 est.org.FORGET C 0000.0030: 48 41 52 4C 43 44 2E 66 74 68 0D 7D 0D 0D 70 75 HARLCD.fth.}..pu ( 0005 $44A2 ok ) 0 APPEND . 11010 ( 0006 $44A2 ok ) -$100 fread +! (cat) (HUBLCD) BEGIN lcdch W@ 0= UNTIL $100 OR lcdch W! ; pub LCD lcdtask C@ IF ' (HUBLCD) ELSE ' LCDEMIT THEN uemit W! ; pub LCD.TASK !RP !SP lcdtask C~~ BEGIN lcdch W@ ?DUP IF LCDEMIT lcdch W~ THEN AGAIN ; } END ?BACKUP ( 0007 $44A2 ok )There are two more things which in your filename convention do "makefiling" harder than they have to:
Translated encoder to Tachyon.
It need eliminate-chattering although not needing in PropForth.
count operate well.
But ' count TASK? RUN don't operate.
What is wrong?
TACHYON V4 IFDEF encoder.fth @rest org FORGET encoder.fth } pub encoder ." encoder 2017/06/17 23:02:16 " ; @org W@ == @rest --- remember { 2017/06/17 23:00:17 Translated Wii_nunchuk to Tachyon Inserted chattring-procedure 3V3 | 10kohm | A ----------- P0 --------------| Rotary | GND ----| Encorder | P1 --------------| | | B ----------- 10kohm | 3V3 prev current status 0 0 stop 0 0 1 CW 1 0 2 CCW -1 0 3 invalid(=stop) 0 4 0 CCW -1 4 1 stop 0 4 2 invalid(=stop) 0 4 3 CW 1 8 0 CW 1 8 1 invalid(=stop) 0 8 2 stop 0 8 3 CCW -1 C 0 invalid(=stop) 0 C 1 CCW -1 C 2 CW 1 C 3 stop 0 } \ =========================================================================== \ Constants \ =========================================================================== #P2 == phaseA TABLE encoder_tbl 0 , 1 , -1 , 0 , -1 , 0 , 0 , 1 , 1 , 0 , 0 , -1 , 0 , -1 , 1 , 0 , #800000 == 10msec \ =========================================================================== \ Variables \ =========================================================================== long lastDebounceTime long pos word prev byte debounce \ =========================================================================== \ Main \ =========================================================================== \ Get current encoder status(b1:b0) \ ( -- n1 ) n1:encoder status : status INA COG@ phaseA SHR 3 AND ; \ Get encorder's position \ ( -- ) : count 0 lastDebounceTime ! 0 debounce C! status pos ! 0 prev W! BEGIN \ Eliminate chattering BEGIN status DUP ( 2bit 2bit ) prev W@ phaseA SHR <> ( 2bit 1/0 ) IF \ If encoder is under debouncong debounce C@ 0= IF CNT@ lastDebounceTime ! 1 debounce C! ENDIF ELSE 0 debounce C! ENDIF debounce C@ ( 2bit 1/0 ) IF CNT@ lastDebounceTime @ - 10msec > IF \ Update current swState and lastswState DUP 1 ( 2bit 2bit 1 ) ELSE DROP 0 ( 0 ) ENDIF ELSE DROP 0 ( 0 ) ENDIF UNTIL \ Update encoder position prev W@ OR 4 * encoder_tbl + @ pos @ + pos ! \ Update pos phaseA SHL prev W! \ SPACE pos @ . CR \ KEY UNTIL ; : test ' count TASK? RUN BEGIN pos @ . CR KEY UNTIL ; ; END \ ?BACKUPTo use a timer task you must create a TIMER variable, have your routine reload that timer each time it is called, set an ALARM vector for that timer pointing to your routine, and finally you need to kick it off to get it started:
Best regards,
proplem
\ =========================================================================== \ Constants \ =========================================================================== #P2 == phaseA TABLE encoder_tbl 0 , 1 , -1 , 0 , -1 , 0 , 0 , 1 , 1 , 0 , 0 , -1 , 0 , -1 , 1 , 0 , #800000 == 10msec \ =========================================================================== \ Variables \ =========================================================================== long lastDebounceTime long pos word prev byte debounce \ =========================================================================== \ Main \ =========================================================================== \ Get current encoder status(b1:b0) \ ( -- n1 ) n1:encoder status : status INA COG@ phaseA SHR 3 AND ; \ Get encorder's position \ ( -- ) : count 0 lastDebounceTime ! 0 debounce C! 0 pos ! 0 prev W! BEGIN \ Eliminate chattering status DUP ( 2bit 2bit ) prev W@ phaseA SHR <> ( 2bit 1/0 ) IF \ If encoder is under debouncong debounce C@ 0= IF CNT@ lastDebounceTime ! 1 debounce C! ENDIF ELSE 0 debounce C! ENDIF debounce C@ ( 2bit 1/0 ) IF CNT@ lastDebounceTime @ - 10msec > IF DUP 1 ( 2bit 2bit 1 ) ELSE DROP 0 ( 0 ) ENDIF ELSE DROP 0 ( 0 ) ENDIF \ Update encoder position IF prev W@ OR 4 * encoder_tbl + @ pos @ + pos ! \ Update pos phaseA SHL prev W! ENDIF 0 \ pos @ . SPACE \ KEY UNTIL ; : test ' count TASK? RUN \ Run countr on anothrt cog #10 ms BEGIN pos @ . SPACE #100 ms KEY UNTIL ;There are 2 problem.
What is wrong?
This is abnormal?
Hi caskaz,
TACHYON V4 IFDEF encoder.fth @rest org FORGET encoder.fth } pub encoder ." encoder 2017/06/17 23:02:16 " ; @org W@ == @rest --- remember { 2017/06/17 23:00:17 Translated Wii_nunchuk to Tachyon Inserted chattring-procedure 3V3 | 10kohm | A ----------- P0 --------------| Rotary | GND ----| Encorder | P1 --------------| | | B ----------- 10kohm | 3V3 prev current status 0 0 stop 0 0 1 CW 1 0 2 CCW -1 0 3 invalid(=stop) 0 4 0 CCW -1 4 1 stop 0 4 2 invalid(=stop) 0 4 3 CW 1 8 0 CW 1 8 1 invalid(=stop) 0 8 2 stop 0 8 3 CCW -1 C 0 invalid(=stop) 0 C 1 CCW -1 C 2 CW 1 C 3 stop 0 } \ =========================================================================== \ Constants \ =========================================================================== #P2 == phaseA TABLE encoder_tbl 0 , 1 , -1 , 0 , -1 , 0 , 0 , 1 , 1 , 0 , 0 , -1 , 0 , -1 , 1 , 0 , #800000 == 10msec \ =========================================================================== \ Variables \ =========================================================================== long pos word prev TIMER enc_timer ( create a timer variable ) \ =========================================================================== \ Main \ =========================================================================== \ Get current encoder status(b1:b0) \ ( -- n1 ) n1:encoder status : status INA COG@ phaseA SHR 3 AND ; \ Get encorder's position \ ( -- ) : count status pos ! 0 prev W! status DUP ( 2bit 2bit ) prev W@ phaseA SHR <> ( 2bit 1/0 ) \ Update encoder position prev W@ OR 4 * encoder_tbl + @ pos @ + pos ! \ Update pos phaseA SHL prev W! 10 enc_timer TIMEOUT ( reload the timer to fire in 10 ms again ) ; : test ' count enc_timer ALARM ( point enc_timer to your code ) 15 enc_timer TIMEOUT ( initial start up after 15 ms - links the enc_timer variable into the timer task list ) BEGIN pos @ . CR 100 ms KEY UNTIL ; \ ?BACKUP ENDYour code then reads it very simply:
Hi Peter,
This don't operate . Encoder-count is still 0.
BTW,
\ =========================================================================== \ Constants \ =========================================================================== #P2 == phaseA { TABLE encoder_tbl 0 , 1 , -1 , 0 , -1 , 0 , 0 , 1 , 1 , 0 , 0 , -1 , 0 , -1 , 1 , 0 , } TABLE encoder_tbl 1 | 2 | 0 | 1 | 0 | 1 | 1 | 2 | 2 | 1 | 1 | 0 | 1 | 0 | 2 | 1 | #800000 == 10msec \ =========================================================================== \ Variables \ =========================================================================== long lastDebounceTime long pos word prev byte debounce TIMER enc_timer \ =========================================================================== \ Main \ =========================================================================== \ Get current encoder status(b1:b0) \ ( -- n1 ) n1:encoder status : status INA COG@ phaseA SHR 3 AND ; \ Get encorder's position \ ( -- ) : count status pos ! 0 prev W! status DUP prev W@ phaseA SHR <> \ prev W@ OR 4 * encoder_tbl + @ prev W@ OR encoder_tbl + C@ 1- pos @ + pos ! \ Update pos phaseA SHL prev W! #10 enc_timer TIMEOUT ; : test #15 enc_timer TIMEOUT BEGIN pos @ . SPACE #100 ms KEY UNTIL ; END \ ?BACKUPIt's not that hard.
inside of count this line resets the timer to fire again in your test word the ALARM vector for this enc_timer is set to your count word
then the starts the timer initially after 15 ms
I Sorry D.P.
I uinserted [' count enc_timer ALARM in test.
But not operated.
This is wrong? Original is D.P.
Although executing BLINKEM, LED not blinking.
How does LED operate?
TACHYON V4 IFDEF timer.fth @rest org FORGET encoder.fth } pub timer ." timer 2017/06/17 11:49:45 " ; @org W@ == @rest --- remember \ * SIMPLE ROUTINE TO EXERCISE ALL 8 LEDS WITH TACHYON TIMERS \ * AND ALARMS ON THE PROP QUICKSTART BOARD \ * \ * USE THE WORD "BLINKEM" TO START THE LIGHTS \ * AND "STOPEM" TO STOP THE LIGHTS 0 == #mt0 1 == #mt1 2 == #mt2 3 == #mt3 4 == #mt4 5 == #mt5 6 == #mt6 7 == #mt7 : blink0 #16 PIN@ IF #16 LOW #500 ELSE #16 HIGH #50 THEN #mt0 TIMEOUT ; : b0 ' blink0 #mt0 ALARM ; : blink1 #17 PIN@ IF #17 LOW #300 ELSE #17 HIGH #50 THEN #mt1 TIMEOUT ; : b1 ' blink1 #mt1 ALARM ; : blink2 #18 PIN@ IF #18 LOW #150 ELSE #18 HIGH #50 THEN #mt2 TIMEOUT ; : b2 ' blink2 #mt2 ALARM ; : blink3 #19 PIN@ IF #19 LOW #285 ELSE #19 HIGH #50 THEN #mt3 TIMEOUT ; : b3 ' blink3 #mt3 ALARM ; : blink4 #20 PIN@ IF #20 LOW #175 ELSE #20 HIGH #50 THEN #mt4 TIMEOUT ; : b4 ' blink4 #mt4 ALARM ; : blink5 #21 PIN@ IF #21 LOW #335 ELSE #21 HIGH #50 THEN #mt5 TIMEOUT ; : b5 ' blink5 #mt5 ALARM ; : blink6 #22 PIN@ IF #22 LOW #100 ELSE #22 HIGH #50 THEN #mt6 TIMEOUT ; : b6 ' blink6 #mt6 ALARM ; : blink7 #23 PIN@ IF #23 LOW #195 ELSE #23 HIGH #50 THEN #mt7 TIMEOUT ; : b7 ' blink7 #mt7 ALARM ; : clrpin $FF0000 OUTCLR ; : BLINKEM b0 b1 b2 b3 b4 b5 b6 b7 8 FOR #25 I * 1 + I TIMEOUT NEXT ; : STOPEM 8 FOR ' clrpin I ALARM NEXT ; END \ ?BACKUPThe TIMER task runs in its own cog and besides maintaining runtime and soft RTC always scans a linked list of user timers every 1ms. All you need to do is to create a timer variable, an optional do something vector on ALARM. If you want your code to run repeatedly then all you do is simply reload the timer.
Load that timer with a large enough value and you can watch it count down
There is a syntax issue with IX in BLKSEND maybe someone has some minutes to fix or explain what has to be done?
Thanks, proplem
( 0001 $4648 ok ) ( Please define +FTP to IFDEF compile FTP and HTTP servers ) ( 0002 $4648 ok ) TACHYON V4 Propeller .:.:--TACHYON--:.:. Forth V4.4 DAWN 440170616.2330 ( 0547 $4F46 ++ ) ??? in BLKSEND at >L ( 0548 $4F46 ?? ) ??? in BLKSEND at IX ( 0551 $4F46 ?? ) ??? in BLKSEND at IX ??? in BLKSEND at L> ( 1417 $5356 ok ) End of source code, 0004 errors found Load time = 1343124720 cycles at 96MHz = 13c Code bytes used = 3342 CODE:$5356 =20822 bytes NAME:$686A =2966 bytes DATA:$79EA =986 bytes =5396 byt) ( 1418 $5356 ok ) ( 1419 $5356 ok ) ' EASYNET +INIT ( 1420 $5356 ok ) ( 1421 $5356 ok ) ?BACKUPThe first number in the prompt (for example) isn't the line number where the error occurs. I tried removing all empty lines but that isn't getting better maybe also comment lines have to be removed?!?edit: Maybe an explanation could be inserted into the google docs Tachyon + V4 "Dawn" ?
This don't use TIMER because I don't understand it.
I try to re-write it after understanding TIMER.
Sometimes error occur(Error - cog out of range).
0 = Tachyon console
3 = F32
4 = free
5 = free
6 = free
7 = free
Code below don't operate.
What is wrong?
