Burnt Propeller Project Board USB - anyone?
Erlend
in Propeller 1
I just - for the first time in five years - produced smoke. I know I will never get around to replacing the burnt chip, so I'll put it in an envelope and post it to anyone who wants it. As you can see from the picture it is populated with headers and a led-in-a-row IC.
PM me if you want it.
Erlend
Erlend
Erlend
Think positive.
Erlend
Erlend
Erlend
Or venturing a bit too close to the anode of the CRT itself, the tube's internal capacitance packs a wallop!
Ahh, the bravery of youth, on old bomb sites ...
Those were the days having to discharge them with a long screwdriver jumpered to chassis ground. You don't forget to do that more than once.
I always heard that a break at the neck could cause the electron gun to shoot out of the screen. Never tried to prove that.
Having busted a few old TV tubes during my miss-spent youth I don't recall anything seriously bad or even exciting happening.
I never got zapped personally, my boss said it happened to him.
I was so careful, I used that same screwdriver to compress the anode clip to remove it. Worried about a residual charge.
As a kid, 8 to 13 years old or so, everything was tubes. Radios, TV's, scopes, etc.
As a kids of course we opened these things up and messed with them. And got zapped. It was annoying. Nobody ever told us it might be lethal!
Somehow though I had the idea that the back end of a TV tube might be a different kettle of fish. Even if I had no clear idea of what volts and amps were at the time.
Oh boy....I do have a few memories of those mechanical monstrosities.....but not because I'm that old, just because some of the equipment I worked on was well past the age where it should have been replaced. I replaced a lot of them with Okidata 82 printers.
My grandfather told me he got across the house mains once(240VAC). He said he was lucky to be able to pull away. I always had great respect for doing work on both sides of mains. Take no shortcuts, Power OFF.
Even though the project I'm working has its own safety cage area and a qualified person standing by with an LV rescue kit and warning strobes I find it all too easy to just forget all this and go to connect something inside the equipment even with its huge bus-bars snaking around the interior. That's because I've worked on it so many times unpowered except for the 24V supply to the circuit boards. I do avoid connecting serial USB directly from my laptop at these times though as I use serial Bluetooth instead.
I keep meaning to hook-up a speaker directly to one of the phases with a suitable R+C just to remind me with a loud hum, otherwise the machine is "dead" quiet. There are no RCD safety breakers on this beast to save me!
The fact that I'm still posting is a good indication I've been lucky so far....
The grandfather I mentioned worked electrical maintenance at B. F. Goodrich in Akron, OH. The large mills and other machines required higher voltages than what a residential home would have. Probably what you are dealing with is the same. You would definitely have to know what your doing when the factory has it's own electric substation.
The Flexiwriters of time were full of cams that constantly needed maintenance. Luckily I fixed computer boards, disc drives and videos, so my time was more valuable fixing them than Flexiwriters.
The drum printers that were replaced by some of the Centronics Band printers around the same time as the solids ta 82 were enormous and heavy. They used to lift them with a crane through the big windows (after removing the windows of course).
Got flung across the room twice when I tried to connect a neon light across bare leads plugged into the 240Vac. I was 9. Fortunately I never told my parents or I would most likely never have gone into electronics/computers!
Oh yah nine years old, a very inquisitive time in life. Young enough to take daring chances, but not old enough to know better.
The second time was because you were dazed and confused from the first time. We are all glad you didn't try for a third.
With that experience I already had a healthy respect for that mysterious electricity thing when I started pulling apart, and building, tube gear a few years later.
