Stamp Stack 2P Experimenter's Board
microcontrolleruser
Developers
How do you place this on breadboard?
If I put it on bottom right the 2 pair of 2pin headers on bottom seem to
be a grounding hazard.
It's a Parallax medium breadboard. 660 tie point as far as I can tell. Kind of an oddball size.
Thanks!
Thanks!
https://content.solarbotics.com/products/documentation/stamp stack 2p v2.3.pdf
Got a picture of what does not line up? Parallax only sold standard breadboards.
Look at this breadboard from SparkFun. It has the power bus, but only has 30 rows of contacts, enough to use with this board, but not too useful otherwise. Get a bigger breadboard or 2 or 3 of these.
https://sparkfun.com/products/12002
Publison, Mike
This breadboard.
https://www.parallax.com/product/700-00078
When you put power pins in side power rail the
pins end up in the IC 'ditch'.
When you hang it off side (signal pins in far right column) the
power pins are just out there.
You would have to connect 2 pin extension cable from bottom.
Thanks!
P24 does not line up on breadboard with power connectors
in power rail. Period.
Get it done solution is to use two breadboards.
One for I/O pins and one for power output.
Board can actually just be tested on top of anti-static bag.
I want to protect it though.
This is a great board!
Thanks!
I don't know if your saying connect power pins to
separete power rail breadboards.
Anyhow we're just going to power it up and
make sure Stamp Editor identifies it first.
Be fun selecting P24 micro and 2.5 language!
Thanks!
Picture is in manual that Publison posted above.
It's kind of beyond a module.
Guess the idea was popular for awhile and
now it isn't.
Guess they figure the technically savvy can just build the
whole thing from scratch on a breadboard.
I like my little 'PCB on a breadbord' p24.
Thanks!
Save yourself the grief and get one of Parallax's kits which have everything you need and are ready to use out of the box.
The BASIC Stamp Activity Kit is the best bang for the buck at $80.
https://www.parallax.com/product/90005
The BASIC Stamp Discovery Kit costs twice as much but it comes with the BASIC Stamp Manual and the Board of Education can also be powered from an AC adapter and the BS2 module can be changed.
https://www.parallax.com/product/27807
David,
The breadboard is $5.
This is totally different kind of board,
It doesn't come with training wheels.
It's for hard core techy's.
It's from back when Parallax catered to that crowd.
Mr Betz
This Stamp Stack is a very very old board.
Solarbotics got tired of looking at them on their shelf and clearanced them.
At one time HVW had a relationship with Parallax.
Kind of like the Neurve outfit.
By the way Neurve site has some interesting stuff on it.
Thanks!
Okay. Back to business.
Battery they included for on board clock has 3 volts.
This takes an old D type usb cable.
There is barrel jack power only, no battery.
It has a serial port, rj45 and provision for additional Ram.
512 memory can be added as is, if you want one megabyte you
have to break a soldering bridge.
Thanks!
Okay, thanks for clarifying. I guess this board has an actual Parallax chip on it. No cloning involved.
Looks like a BS2P24 Interpreter chip.
Just ordered a couple. Let's see if they are in stock. Not bad for the price.
David Publison
When I connected it it did a Windows 7 'installing drivers' popup window.
Long story short, did not identify in Stamp Editor.
Will contact HVW monday about location of drivers.
They've morphed into Avorobot.
Thanks!
https://www.parallax.com/downloads/parallax-usb-driver-installer
Reboot computer after installing.
Thought they were already on there.
Will double check with a regular stamp board.
Solarbotics p24 page has drivers down the bottom.
Board may take a driver too.
Hardware wise the green led lit up after plugging 12v power supply in.
Thanks!
The driver I linked on the Parallax site are the latest FTDI drivers. (FTDI USB is used on the Solarbotics board). The Solarbotics drivers are from 2004 and supported Win98 and Win2000. The Parallax drivers may be a better choice.
The only driver the board needs is the FTDI USB drivers.
Good point. Always uninstall FTDI drivers, even though you are installing the same. You just never know what's left over.
Thank you for tips!
Give it another shot tomorrow.
Thanks!
Developers
This board has an RJxx, serial and USB connector on it.
Can the RJxx and serial connectors be used for programming?
Thanks!
Chris
Can't find the little manual that came with it right now.
These two say 'Programming' in your pic there:
Serial
USB
The RJxx says 'I wire interface'.
Interface usually means communication so it
is not for programming?
Don't want to fry board.
Thanks!
P.S. - The manual was a Google Search away.
http://content.solarbotics.com/products/documentation/25055-manual_v21.pdf
Chris
PIC or AVR uses some kind of RJxx for programming but I think that's a
recent change.
Okay, got it.
Appreciate it.
Bob
The full manual in in post #2 of this thread.
Thanks for resurrecting this thread because I was wondering where my product was. Well, low and behold, it just put in my mail box!
I'll break it out tomorrow and see if I can answer some questions.
One Wire is for a class of peripherals:
https://www.maximintegrated.com/en/app-notes/index.mvp/id/1796
You can use a USB connection or Serial Connection to program the Basics Stamp, per the instructions. I will check both interfaces tomorrow.
Remember, this is not a Parallax product, so support is through forum members, if they can help .
