I've modified gfx2 in order to give WSVGA output (1024x600@72Hz)
See attached.
Mostly just multiplied things by 1024/800
But, output was jagged, looked like the XGA driver posted here.
Fixed that by changing a XCONT to XZERO.
There was also one hardcoded ##800 in there that had to change to w.
I remember we had to use that trick before to stabilize the display.
Zeros the phase for each line so that rollovers (if they occur) are at same place on every line.
This trick could probably also fix the XGA driver here.
Back to looking at the 1024x600 version of this...
Had to change all adra to PA and adrb to PB to compile with the V12 version of P2.
One nice thing about width=1024 is that could use shift instead of multiply in the set pixel routine:
'RJA: Note that nice thing about w=1024 is that multiply is just a shift, don't need this cordic
mov ptra,y1
qmul ptra,##w/2'RJA 800 / 2 '2 pixels per byte
getrnd ptra 'RJA: What does this do Stalling?
getqx ptra
I am curious why the "getrnd" statement is there for. Not even sure what it does, get round number? It would work the same without that statement, right?
Just substituted in Chip's line drawing routine from Graphics.spin:
' Plot line from px,py to dx,dy (from graphics.spin)
' RJA: Replaced line draw code with that of P1's graphics.spin
'plot line from x1,y1 to x2,y2 in current color
'one difference is that need to restore x1,y1 before exiting
plot_line
'First, form px,py and dx,dy
mov dx,x2
mov dy,y2
mov px,x1
mov py,y1
'cmps dx,x1 wc', wr 'get x difference
subs dx,x1 'P2 version of above
negc asx,#1 'set x direction
'cmps dy,y1 wc', wr 'get y difference
subs dy,y1 'P2 version of above
negc asy,#1 'set y direction
abs dx,dx 'make differences absolute
abs dy,dy
cmp dx,dy wc 'determine dominant axis
if_nc tjz dx,#.last 'if both differences 0, plot single pixel
if_nc mov count,dx 'set pixel count
if_c mov count,dy
mov ratio,count 'set initial ratio
shr ratio,#1
if_c jmp #.yloop 'x or y dominant?
.xloop call #set_pixel 'dominant x line
add x1,asx
sub ratio,dy wc
if_c add ratio,dx
if_c add y1,asy
djnz count,#.xloop
jmp #.last 'plot last pixel
.yloop call #set_pixel 'dominant y line
add y1,asy
sub ratio,dx wc
if_c add ratio,dy
if_c add x1,asx
djnz count,#.yloop
.last call #set_pixel 'plot last pixel
linepd_ret ret
'count long 0
ratio long 0
asx long 0
asy long 0
dx long 0
dy long 0
px long 0
py long 0
Haven't take the time to figure out exactly how it works, but seems very efficient...
Did have some trouble with "cmps" and it's "wr". Don't think "wr" exists on P2.
But, eventually figured out can just swap with "subs".
mov ptra,y1
getqx ptra
The GETRND instruction was put in between the CORDIC instructions simply to index the random number in the idle time waiting for the CORDIC result.
Ok thanks. That makes sense. There's a lot of time to wait with cordic.
I think you could have used the regular 16-bit MUL instruction there instead though, right?
This SVGA and WSVGA modes look very stable my home setup.
There is only one flaw that I see.
On the very bottom line, all the way on the right edge, there looks to be two pixels that are always white and one that flickers white.
It's very strange. I think it has to be the monitor because I don't see any way it could be the driver.
However, the 640x480 mode doesn't show this.
Anyway, I'll try it on a different monitor and see what's what...
Worst case, maybe it's possible to output the native resolution and do the scaling inside the P2.
Great, thanks. I'm still thinking this 4-bit color mode is going to be the best. All the nibble opcodes make it pretty efficient. Not quite as good as 8-bit, but plenty for simple text windows.
BTW: I'm not sure I'm sold on this cordic for multiply. 38 clocks right? Seems to me that simple rotate and add version should be 32 clocks. Maybe I'm missing something...
The beauty of the Cordic is you can have more than1 operation in the pipeline.
Time to do other stuff and/or service interrupts while calculations are in progress. Neat!
I had a quick look at coding a 32 * 32 multiply and arrived at 44 clocks.
Maybe some fresh minds/eyes could trim that down.
I guess I'd like to know more about the accuracy and precision of the cordic solver.
It's been a long while, but seem to recall that the precision depended on how many iterations were made. I think this was originally going to be user decided.
Anyway, if multiply and divide give exactly the same result as the long multiply and long division, like what ozpropdev just posted, then I guess it's perfect.
For the other cordic functions, I guess I'm not as concerned. Although, it would be nice to have a statement about precision in the docs...
This is all a bit off topic from this thread though...
Because it is pipelined, it always does the whole 32 iterations. It is as close to perfect as you can get with 32 bits.
Did you check other monitors ?
Are those pixels outside or inside the blanking rectangle ?
What happens if you vary the blanking edges, and total clocks per line, slightly ?
.... I'm still thinking this 4-bit color mode is going to be the best. All the nibble opcodes make it pretty efficient. Not quite as good as 8-bit, but plenty for simple text windows.
Is this 4b going via CLUT ? 4b via a table is probably just tolerable, as you could update the table every line, for blends, for example.
4 bit mode is a good happy medium that leaves you at least half of the available hub ram for code.
800 * 600 @ 8 bits = 480k , doesn't leave much room for code.
Of course, but 4 bits -> 8/16b CLUT -> DACs keeps the RAM cost the same, but gives more pastel colour choices which are trendier than the primary test pattern colours..
I can't take a picture of it tonight. But in 640x480 mode, roughly the top 1/3 of the image shows a horizontal displacement error... has an almost sinusoidal character. The upper right corner shows a "tear", where it appears that the horizontal reset hasn't been reached yet but no data is being sent. This all disappears in the lower portion of the screen... but in the lower right corner there are 4 spurious pixels at the end of the last line: two set, one empty and one set.
The distortion artifact does not occur in Chip's 8bit VGA sample.
I don't understand how a timing error can occur in the top 1/3 but not the bottom 2/3:)
... But in 640x480 mode, roughly the top 1/3 of the image shows a horizontal displacement error... has an almost sinusoidal character. ...
That sounds like a PLL effect, where the handling CPU is unsure about locking.
Check also for gaps or incorrect Line sync placement during vertical sync.
Do all your Monitors show the same artifact ?
I have only checked on one monitor... my bench is so full of jumpers and wires, I might have to call the
fire department for help.
Originally fpix = 25_175_000.0
I didn't systematically look for the range, but everything I tried (except 25_000_000.0 and 25_000_001.0) showed
the same type of distortion to varying degrees.
I tried changing the base value by numbers, which were multiples of 5 and 8.
This perked me up a bit.
I am all into imaging, and 8 bits is my default bit depth. I am happy at 640x480 VGA, BUT I always assumed
that I was going to be using off-chip memory to scroll data to the screen. If that isn't reasonable to assume, I need to rethink my parameters a bit.
I can do a lot with the HUBRAM, but if it isn't actually possible to scroll the screen from external memory, then I am really going to need more P2's and I should be spending time on that issue now.
It gets even better Rjo, if using the video buffer to initialise the cogs then re-use the space, the difference is 512k less 480,000 ie 44,288 bytes. And P2 code is significantly more dense than P1...
That locks up my screen:) (black screen... IR remote controller largely, but not completely ignored ... as though the monitor develops Parkinson's)
It is a new Vizio 1080p.
I really like 640x400 @70Hz. I get full screen no artifacts. Had to change fpix to fpix = 25_000_000.0, though.
I wonder if the fpix issue isn't because a relationship between fpix and xfrq. Note this line:
The std report is for 720 x 400 @ 70Hz , which is needed during PC Boot, so I doubt that is going away ever.
640x480 just might be different enough to have issues ?
Does the test display have non-black background, cleanly blanked ?
I've found the auto-scale engines in Monitors, to be a little fussy around those areas.
To decide on centre, and clocks, I think they use those image-edges in the decision process, whilst the ancient CRT could not care less....
See attached.
It seems to have fixed the XGA display "jagged edge issue" too.
Nice one!
'RJA: Note that nice thing about w=1024 is that multiply is just a shift, don't need this cordic mov ptra,y1 qmul ptra,##w/2'RJA 800 / 2 '2 pixels per byte getrnd ptra 'RJA: What does this do Stalling? getqx ptraI am curious why the "getrnd" statement is there for. Not even sure what it does, get round number? It would work the same without that statement, right?
' Plot line from px,py to dx,dy (from graphics.spin) ' RJA: Replaced line draw code with that of P1's graphics.spin 'plot line from x1,y1 to x2,y2 in current color 'one difference is that need to restore x1,y1 before exiting plot_line 'First, form px,py and dx,dy mov dx,x2 mov dy,y2 mov px,x1 mov py,y1 'cmps dx,x1 wc', wr 'get x difference subs dx,x1 'P2 version of above negc asx,#1 'set x direction 'cmps dy,y1 wc', wr 'get y difference subs dy,y1 'P2 version of above negc asy,#1 'set y direction abs dx,dx 'make differences absolute abs dy,dy cmp dx,dy wc 'determine dominant axis if_nc tjz dx,#.last 'if both differences 0, plot single pixel if_nc mov count,dx 'set pixel count if_c mov count,dy mov ratio,count 'set initial ratio shr ratio,#1 if_c jmp #.yloop 'x or y dominant? .xloop call #set_pixel 'dominant x line add x1,asx sub ratio,dy wc if_c add ratio,dx if_c add y1,asy djnz count,#.xloop jmp #.last 'plot last pixel .yloop call #set_pixel 'dominant y line add y1,asy sub ratio,dx wc if_c add ratio,dy if_c add x1,asx djnz count,#.yloop .last call #set_pixel 'plot last pixel linepd_ret ret 'count long 0 ratio long 0 asx long 0 asy long 0 dx long 0 dy long 0 px long 0 py long 0Haven't take the time to figure out exactly how it works, but seems very efficient...
Not sure why I used the Cordic there, must have been in spinning fozzie mode.
I've made that change and updated code to V12 FPGA image.
Maybe there is something strange going on with the driver...
I modified the demo to put a box around the visible pixels.
Came out pink this time.
Look in the corner for the white pixels:
So those should be pink, but instead are white ?
Does look like some issue within P2
But, for basic GUIs with controls and text, I think this is best.
You can make the 16-color palette with any colors you want...
fpix = 25_000_000.0
seems to fix it...
But I still don't get it:)
What was fpix before ?
If you vary it some more, what is the stable range ?
But yes I have no doubt you'll need more P2's
Try these settings for 640 * 480 @72Hz
Seems to work better for my monitor.
'640 x 480 72Hz mode '{ w = 640 h=480 fpix = 31_500_000.0 top_blanks = 9 sync_blanks = 2 bottom_blanks = 29 before_sync = 24 sync = 40 before_visible = 128 '}That locks up my screen:) (black screen... IR remote controller largely, but not completely ignored ... as though the monitor develops Parkinson's)
setxfrq ##round(fset)
I am building my tower as we speak:)
