Help with cable type — Parallax Forums
T ChapT Chap Posts: 4,247
edited 2016-10-11 03:46 in General Discussion
I used a 15pin DIN female on two boards. I bought an SVGA cable with 15pin male on each end, but some of the pins are shorted internally in the cable. It seems several SVGA's I have laying around are the same with the internally shorted pins. I was hoping to avoid making these up, is there a cable that is 15 pin DIN that is not internally shorted found at electronic stores? I see some at online stores like this that look like the right idea but I don't want to end up with more VGA type accidentally. Is there a specific name of cable that is straight through with no shorts?
