Help with cable type
I used a 15pin DIN female on two boards. I bought an SVGA cable with 15pin male on each end, but some of the pins are shorted internally in the cable. It seems several SVGA's I have laying around are the same with the internally shorted pins. I was hoping to avoid making these up, is there a cable that is 15 pin DIN that is not internally shorted found at electronic stores? I see some at online stores like this that look like the right idea but I don't want to end up with more VGA type accidentally. Is there a specific name of cable that is straight through with no shorts?
cablesondemand.com/images/diagrams/CS-DSDHD15MM0.pdf
I see lots of "hits" but I didn't see any answers to the original question.
I source my 44pin and 26pin HD cables from these guys.
Also http://www.winford.com/ have them along with a huge range of breakout boards.
Any cable with "VGA" as part of the name is unlikely to be 15 straight thru connections. The RGB connections typically use shielded coax cables with no insulation around the shield, so at least the 3 RGB ground pins will be shorted together.
