Lazer Bond — Parallax Forums
Lazer Bond
WhitWhit Posts: 4,194
edited 2016-06-05 02:35 in General Discussion
Anybody have any experience with this or similar products? Bet you a dollar erco has!
Here it is at Traget - Lazer Bond
Similar product at WalMart - 5 Second Fix
    edited 2016-06-05 02:38
    This looks a lot like Bondic. As with many glues, how well it works depends a lot on the application.
    Here's a video of someone giving Bondic a try.
    I don't think they used the cure light long enough. There is a comment from the manufacturer with information about how to get better bonds.
    I'm personally unimpressed with the stuff (I haven't tried it myself). I think there are a lot of better options available.
  • WhitWhit Posts: 4,194
    Thanks Duane!
  • 'Just paid $125 to have a filling replaced. 'Coulda done it myself with Lazer Bond!
  • Hi
    I've used that exact product a few times lately.
    On translucent PETG plastic it appears to work pretty good.
    I did not do a strength test on that, it was to seal against rain water on a crack.
    On paper it works pretty good, although quite expensive for gluing paper together.
    On PVC pipe, it does not work so good.
    I think the light cannot get past the joint, so the joint does not cure.
    I used it to seal a leak in a porous plastic water push on tube fitting.
    Seemed ok after sanding with 100 grit sandpaper.
    I think there are some applications that this product will work pretty good on,
    but I believe success will depend on each particular application.
    I shine the little blue light for about 30 seconds though, as I really think 3 to 5 seconds is not long enough.
    Just my 2 cents worth.
    @PhiPi - now there IS an idea!
    @garyg - thanks - good info - I think I'll get some and play around on otherwise lost causes or new and easy to replace applications.
  • rjo__rjo__ Posts: 2,114
    Yes but you need more than glue:) How do you know you did it right?
    ebay.com/itm/Gendex-Gxs-700-Digital-X-Ray-Sensor-Size-1-with-calibration-file-crisp-clear-/282054768445?hash=item41abc6373d:g:kN8AAOSwWntXMkzP
    This one is used, and has only a few bite marks... x-ray emitter would be an extra $500.
    Hurry before Erco beats you to it.
  • I wonder if this can be used on the Cricket Kit?
    I've never tried this stuff. I would click & order but my hands are superglued together right now.
