$25 Hexapod Chassis, One Only, Act Fast! - Page 3 — Parallax Forums
13»
    And don't forget the mighty Turbot.
  • WhitWhit Posts: 4,191
    Great music!
    Whit wrote: »
    Great music!
    This Turbot makes good headway in a lumpy sandbox.
    Music on no motor walker vid!
  • Just thought I'd make these stampbug files available on behalf of Milford Instruments which is closing down this summer.
    The history of the stampbug is as follows:
    The first stampbug (in 1994) was a development from the Hexwalker made in the US- this used perf board as the chassis and was very tricky to make so we replaced the perf board with a pcb board. The Stampbug used a discrete version of the the BS1- it was called the School Stamp.
    Next iteration was to replace the metal legs and plastic joints with pcb made legs- cheaper and easier to assemble.
    Next iteration was to upgrade the processor to the Stamp2 chip set and add a processor that just looked after the servos.
    I've attached the milford info on these two devices including the pcb ( in easy-pc format).
    There was a further development which never made production- this was the hextor by David Buckley. For info on this and his other robots, just google him. David was also the inspiration behind the Bigfoot walking robot that was later manufactured as the toddler by Parallax.
    Hope this is of use.
    Edward Buckley ( no relation to David)
  • sxman wrote: »
    That is great info. This means it will be preserved with data hoarders, like me, for future generations. :)
    edited 2016-06-09 19:09
    Thanks sxman! I have hoarded this info too. I loved the original Stampbug and declared my love on these forums long ago!
    http://forums.parallax.com/discussion/163253/stamp-bug-2-type-bot-3-servo-hex-crawler
    For other Bug items here on the Forums, see:
    http://forums.parallax.com/discussion/85370/need-help-with-stampbug-2-kit-5-953
    http://forums.parallax.com/discussion/117387/how-to-make-a-stamp-bug-stand-on-its-hind-legs
    Verified in this thread that Carol Lynn Hazlett has a Stamp Bug, this thread link had to be posted here (and on erco's toddler thread too)
    http://forums.parallax.com/discussion/149087/very-old-milinst-stambug/p2
    Thanks Edward! Sorry to hear that Milford Instruments is closing down. I'm hooked on these simple hexapods and now a Mil Inst StampBug is on my must-get list.
    It will be a year before I can show you guys what I'm building a pair of for a client, and it's killin' me. But it pays well and I'm livin' the dream.
    ...and I'm livin' the dream.
    Live it! We will be watching for post 20,001.
    My parts to build hexapod robots with my grandkids are arriving (rods, base plates, screws/nuts/washers, etc) :)
    Cluso99 wrote: »
    (erco biting tongue)
    edited 2016-06-17 23:31
    Sorry I forgot pic and doggonit, when I go back to edit it I don't see any way to add an attachment.
    You cant't edit with an attachment on the previous post. Stinks. :)
    Did you use a kicker on the CA? I was thinking about q-tipping the kicker in the groove and then apply thick CA to the piece to be inserted into the grove. On Depron, I normally don't care about the fog.
    I used Weld-On (solvent bond), not CA. But generally I use Great Planes thick CA and Zip Kicker. I think the fog is from the CA, so the quicker it cures, less fog. And keeping a fan blowing or sucking the fumes away reduces fogging from my experience.
    edited 2016-06-18 22:49
    Another hack-worthy hexapod is this $31 XL Hexbug Spider. Big and simple to hack, you just unscrew and remove the top section containing the RC section and trace 4 wires to the 2 motors. One motor is for walking forward/reverse and the other turns left & right. Easy peezy. These are often $40 or more, but not on today's erco show!
    BTW this is the XL version I'm recommending. There is a smaller version which is button-cell powered. Too small IMHO and nearly the same price.
    Also BTW, these are fine toys as-is. Derived from Jamie's famous Spider Tank. But we ARE hacker types. Who will make the first Prop Spider? Or Stamp Spider?
    $31, free ship http://www.ebay.com/itm/351749918107
    Or $32 from Walmart: http://www.walmart.com/ip/HEXBUG-Giant-XL-Spider-Colors-May-Vary/48081276
    This baby's got Duane, Jim & Martin written all over it. Maybe Whit can justify one. Maybe even Rick... if he ever finishes Treadnaught!
    This would be a great figure 8 bot. Nice & smooth.
    Jamie's original video that started it all:
  • Carol HazlettCarol Hazlett Posts: 312
    edited 2016-11-17 23:55
    I ran across this discussion while lurking the forum! I have one of the original Stampbugs and it still works great. I can program it using Parallax serial adapters stacked together and the current version of the Basic Stamp IDE. I am thinking of entering it in Erco's Figure Eight Challenge. Here are some pics of it. I noticed it looks different from the Stampbug in the pictures sxman posted. Is mine an earlier or later version of those? If I remember right I bought it somewhere around 1990. The only thing that is not original equipment is the battery holder. The original one cracked with age! I think it may be an older one because the BS1 circuitry is embedded on the board instead of on a daughter board. I still have the original documentation also. I should have changed the jumper for the video, it is high stepping for rug travel.
    922 x 692 - 255K
    922 x 692 - 238K
    922 x 692 - 228K
    edited 2016-11-18 01:28
    WANT. Mike Green gave me much of a kit to make a Stamp Bug. Must solder brass tubes for legs. Must find instructions too. No rush, long-term project.
  • Lately I feel annoyed by misnaming things.
    Something having 4 motors can be called a Quad-Copter. Having Eight of them is a Hex-Copter. So far so good.
    Allen wrenches (or Hex-Wrenches) have also 8 corners.
    But calling something with SIX legs a Hexapod is simply wrong.
    Enjoy!
    ??? Hex=6. Octo=8.
    Hex wrench has 6 sides.
    Hex copters have 6 props.
    Hexapods have 6 legs.
    Octopi have 8 legs.
    Octo-Dog is confusing, I'll agree. But I still want one.
  • Uups, I stand corrected here, sorry.
    I somehow thought Hex wrenches have 8 sides/corners, never counted them.
    my bad, sorry
