5200 mAh capacity Mobile Battery Pack, two for $5 at BestBuy - Page 2 — Parallax Forums
2»
  • zappmanzappman Posts: 418
    edited 2016-06-01 02:10
    OK, I bought two of them yesterday, and they were $9.98 for the pair.
    However, I left the first one charging overnight and it would NOT charge (as McCoy would say "It's dead Jim").
    Looks like I have to make a trip back to BestBuy.
    I plugged it the second one, and it seems to be charging. (Edit: yes it charged OK)
    Therefore, I suggest everyone checks out their units.
    Check your charger. One of my units took much longer to charge than the other, it wouldn't get the 4th LED on. I switched to a higher-current USB charger and it topped up in 5 minutes.
    tonyp12 wrote: »
    So should that mean we should expect ~
    5200 x 0.95 x 3.7 / 5.0= 3655 mAH from the 5V output for USB devices? This might be the right time to try out my schmancy USB charger doctor with cumulative power output display.
  • I got 2 for ten bucks which is still a good deal. Just need to go pick them up from the store tomorrow.
    edited 2016-06-01 02:08
    Exchanged the bad unit for another, it is plugged into my laptop, all the LEDs are flashing, so I think it is charging. I will see if it charges overnight.
  • The four units I picked up only flash one led at a time. As the charge progresses the first led flashes and then stays on, then the second led flashes, then on to the third and fourth. Mine never flashed all the leds together. I charge mine with a 2A external charger. Don't laptops limit USB output to 0.5 Amps?
  • i charged mine using a laptop. Took some time but it worked.
  • Hal Albach wrote: »
    Hal,
    I believe you are correct.
    Jim
  • it also depend if you press the button while charging or while being used.
    594 x 263 - 14K
  • zappman wrote: »
    Well, I still have one unit that will not charge.
    The bad unit I have now Blinks all 4 LEDs continuously as soon as it is pluged into any charger or laptop. Currently I am trying a 2 Amp charger.
    When I unplug the bad battery from the charger, the lights continue to all blink for a second or 2, then stop.
  • zappman wrote: »
    Looking over the data sheet for the charge controller chip that tonyp12 linked earlier, I do not find any information which would cause the unit to blink all 4 leds together. I am guessing that it is an error condition which is not covered in the datasheet. These units have a 1 Year Warranty, probably best to get it replaced.
