Activity Board - adapt breadboard to a soldered board
in Accessories
I've got a project working well on an Activity Board. The project must run in a rough environment however and would like to ditch the breadboard. I am using the XBee port and the ADC device, so it would seem that adapting the Activity Board would be easier than adapting the XBee and ADC to fit another board. I see the Proto Board Kit: https://www.parallax.com/product/40010. Should I just fit it into the Propeller inputs of the Activity Board and let it sit on top of the breadboard?
https://www.parallax.com/product/32999
If you really want to keep the breadboard, use short solid wires to make the connections. When it's finished and tested, use hot glue to permanently fasten the wires and parts in place.
Thanks for mentioning that Chris, I did not know that existed, but might be a good fit for 2 projects that I keep swapping between on my Activity board.
Hey, thanks Mike.
Both of those are good ideas and I see that I can readily source the Adafruit boards, here in the UK.
