Q to moderators — Parallax Forums
Q to moderators
Are moderators/admins able to read the replies to threads that I write, then come to my senses and never submit? I notice they're still there in the edit box when I come back to the thread later. :blush:
    edited 2016-02-26 16:51
    Of course this is all kept in the forum server. If an admin wants to they can read it they can.
    You are not connecting to the forum over HTTPS so anyone in the middle can read what you did not "post" as well. Like the NSA or whatever bad guys.
    Just one among many security holes in the forum.
  • I don't believe so. If you can PM me a certain thread, I will check.
  • Publison wrote: »
    That's good enough. I was mainly just curious.
  • With current permission settings, forum moderators cannot view your drafts. Content that has not been made public or directed at another user through PMs is currently not moderated.
    Administrators hold more extensive permissions than moderators, but they are not responsible for normal forum moderation tasks.
  • Are moderators/admins able to read the replies to threads that I write, then come to my senses and never submit?
    One wonders what sorts of things are ruminating in the recesses of your mind. Perhaps they hold the keys to a brighter future...
  • I guess you can always replace your misruminations with something more benign, then hit "Save Draft." In my case, I don't really care if admins can see my drafts. There's nothing there that's any worse than stuff I've already posted -- well, except possibly for some "senior moments" I've been able to censor preemptively. :)
    Relax, guys: Prop 2 knows your thoughts long before you do. Sleep tight, mates, in your quilted chambray nightshirts.
  • jmgjmg Posts: 15,200
    edited 2016-02-27 04:29
    ... I notice they're still there in the edit box when I come back to the thread later.
    I think a work-around for this forum bug of lack of explicit DELETE, is to delete the text, then hit Save Draft.
    That saves-over the last copy, and what it saves is empty (or just a .)
    Checked this, and it needs a non empty sheet, before Save confirm message pops up.
    it a single . is ok, or any other non-white space char.
  • jmg wrote: »
    That's exactly what I've been doing, yes.
    User Name wrote: »
    This only becomes an issue when Tony takes over. I don't like Tony.
    :crazy:
