propeller-load save to SD card
AS
                    Hello!
Is everything working fine, I install a SD card and I can do all the examples.
I want saving to the SD card because I have a large program.
I´m working with a Raspberry, I tested in two models.
I´m using CMake to creat the ".elf" files.
With the memory model "lmm" everything is working, I see the Hello World!
I wrote:
Now I change the memory model to
After:
but I can use:
Everything seems fine! No warnings No errors! BUT NO HELLO WORLD!?
And I have in the SD card the file AUTORUN.PEX
Now I can write:
Any sugestion for this issue?
I wrote:
make debugor
/opt/parallax/bin/propeller-load -b activityboard GettingStarted.elf -r -twith the file CMakeLists.txt:
cmake_minimum_required(VERSION 3.3)
find_package(PropWare REQUIRED)
project(GettingStarted)
set(MODEL lmm)
set_compile_flags()
create_simple_executable(${PROJECT_NAME} GettingStarted.cpp)
... set(MODEL xmmc) ...
After:
cmake .. makeI can´t do the
make debug
but I can use:
/opt/parallax/bin/propeller-load -b activityboard -l GettingStarted.elf -r -t
pi@raspberrypi:~/PropellerProjects/PropWare/Examples/GettingStarted/bin $ /opt/parallax/bin/propeller-load -b activityboard -l GettingStarted.elf -r -t Propeller Version 1 on /dev/ttyUSB0 Patching __cfg_txpin with 0000001e Patching __cfg_baudrate with 0001c200 Loading the serial helper to hub memory 10392 bytes sent Verifying RAM ... OK Loading 'GettingStarted.pex' to SD card 5100 bytes sent Loading sd_loader.elf to hub memory 16444 bytes sent Verifying RAM ... OK [ Entering terminal mode. Type ESC or Control-C to exit. ] Loading SD driver Loading cache driver Initializing SD card Mounting filesystem Opening 'autorun.pex' Starting kernel Loading flash/EEPROM at 0x30000000 Stopping the SD driver Starting program [BUT NO HELLO WORLD]
Now I can write:
/opt/parallax/bin/propeller-load -b activityboard -l -r -tEverything seems fine! No warnings No errors! BUT NO HELLO WORLD!?
pi@raspberrypi:~/PropellerProjects/PropWare/Examples/GettingStarted/bin $ /opt/parallax/bin/propeller-load -b activityboard -l -r -t Propeller Version 1 on /dev/ttyUSB0 Loading sd_loader.elf to hub memory 16444 bytes sent Verifying RAM ... OK [ Entering terminal mode. Type ESC or Control-C to exit. ] Loading SD driver Loading cache driver Initializing SD card Mounting filesystem Opening 'autorun.pex' Starting kernel Loading flash/EEPROM at 0x30000000 Stopping the SD driver Starting program [BUT NO HELLO WORLD]
I take a foto with my propeller kit with the SD, I just choose the activityboard because I think that is the same!
The file activityboard.cfg I don´t had change nothing:
# Propeller activity board configuration. # IDE:SDXMMC clkfreq: 80000000 clkmode: XTAL1+PLL16X baudrate: 115200 rxpin: 31 txpin: 30 cache-driver: eeprom_cache.dat cache-size: 8K cache-param1: 0 cache-param2: 0 eeprom-first: TRUE sd-driver: sd_driver.dat sdspi-do: 22 sdspi-clk: 23 sdspi-di: 24 sdspi-cs: 25About the "set_compile_flags()", Thanks!! (only for libraries :thumb: )
I already try without them and I get the same result.
I hope you can give any help.
Thanks for your help.
I send the file attached, I save it inside the rar because the forum don´t accept the .elf file.
OK! sorry!
I want use a large program directly from the SD card. In this case is not important the EEPROM if it is 32 or 64kb?
I read something about the driver to open the "autorun.pex" and I thought that the size of EEPROM could be important!
Thanks!
#include <PropWare/printer/printer.h> /** * @example GettingStarted.cpp * * Print some text to the terminal. A great place to start with PropWare to ensure your environment is functional! * * @include GettingStarted/CMakeLists.txt */ int main () { pwOut << "Hello, world!"; return 0; }in this case I type: and it works!
I attached a .zip (of a .elf file) with the same program compiled in lmm mode.
To save the "AUTORUN.PEX" to the SD card I should write: It´s necessary the "-l"? Right? To save the program to the SD card in the mode "xmmc"?
and I obtain the result:
At this moment I already have the "AUTORUN.PEX" file in the SD card.
I write:
and the result is similar, no "Hello World":
#include <stdio.h> int main(void) { printf("Hello, world!\n"); for (;;) ; return 0; }And it works fine with both the EEPROM cache driver and the C3 cache driver.The issue is when I compile in XMMC mode and try to upload to Propeller, using the SD Loader (-l) or SD CacheDriver (-z).
I already made several tests and the Propeller don´t run the program. I try the delay too, but nothing.
Really thanks!
but I can´t understand why
I should write in the code something like:
... for (;;) ; return 0; }with a "while(1)" I should write it in every cycle?
Ok I will test it!
thanks!
Is not easy to me really understand.
But I will test it.
I trying to understand how is the best way to deal with that.
But with this example I have the same issue:
#include "simpletools.h" int main(void) { int Led_Intensity=0; pwm_start (1000); while(1) // Endless loop { while (Led_Intensity<1000) { pwm_set (0,1,Led_Intensity); Led_Intensity ++; pause (1); } while (Led_Intensity>0) { pwm_set (0,1, Led_Intensity); Led_Intensity --; pause (1); } } }the led don´t react in XMMC mode.
with LMM everything ok, with XMMC don´t work.
