What happened to the "The New 16-Cog, 512KB, 64 analog I/O Propeller Chip" thread?
in Propeller 2
C.W.
http://webcache.googleusercontent.com/search?q=cache:a6WW-n0lt58J:forums.parallax.com/+&cd=2&hl=en&ct=clnk&gl=us
Various of the pages were also cached...
http://forums.parallax.com/search?Search=16-Cog
Post count > 255
I was going to point to "Tachyon OS furiously fast Forth" but it seems that too has gone *poof*, so some change they made, has clearly killed larger threads.
What is the largest surviving thread ? ( I see 17 pages thread in Robotics ?)
WTF is going on?
I've just checked thread contents using google cache, but it is limited to pages ranging from 1 thru 120, August 6.
Just do a Google search with the following terms inside the search box:
"http://forums.parallax.com/discussion/155132/the-new-16-cog-512kb-64-analog-i-o-propeller-chip/p1"
Thru
"http://forums.parallax.com/discussion/155132/the-new-16-cog-512kb-64-analog-i-o-propeller-chip/p120"
to get there.
I believe the other missing threads could be accessed using the same technic, but at what extent, I'm not sure.
Henrique
P.S. Don't forget to hit the down arrow (Cache) to get there.
P.S. II Don't try the above search thru the forum search box (custom search, powered by google), it will not work. Open a new window and do it using google web search instead.
Perhaps only a coincidence..
Maybe some hurricane class wind(ow) blew up all their clouds!
I hope we can get it back in the state it was last in before disappearing.
Computers surprise me every day. You never know what they are going to do, or not do.
In Brazil, we caught ourselves everyday surprised by what comes in the power cords, served by the mains, only to name the least worrying weird things.
Here, when computers fail, hardware architects are the least guilt ones.
When it comes to electricity in general, and electronics in particular, the devil, for sure, is in the tails!
For the first time since i began to follow the forums, there are a twelve minutes lag in the time tags of the posts.
This post, for example, must hit 05:03:00 GMT (02:03:00 here in Brazil)
P.S. Now the lag was seven minutes! Weird it is.
Edit: Ah, see what you mean. I hit POST on this at 8:16 and it got time stamped as 8:06.
Presumably their server is time travelling...
And it has been varying during the last two hours or so.
P.S. At 05:23:00 UTC/GMT
Would seem like it would be a good step to add to add the following to the Maint. process:
1. Start Maint window, disable new or reply posts
2. Do a capture on total number of posts/replies
3. Do forum maint.
4. Do another capture, and compare against #2
5. If that and other checks are good, enable normal operation
Not cool.
I do hope they have up to date backups.
Ok then. It's just work. Sorry it has to be done, but it's really important that it get done. We've got a product history, definition, and god knows what else in that thread.
Same for Tachyon.
>>>Sends positive energy to IT team<<<
