I wrote code for MLX90614ESF-BAA[supply volt typ=3V](IR Temp sensor).
This use SMBus.
SMBus is like i2c, not same.
MLX90614 don't operate by using i2c_utility.
RepetedStart(Sr) occure Timeout error on SMBus.
I modified Sr.
I will update i2c_utility to be able to use on i2c and SMBus.
Prop0 Cog6 ok
i2c_detect
0 1 2 3 4 5 6 7 8 9 A B C D E F
00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- 5A -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
i2c_device:2
[0 - 7] and [h78 - h7F] are reserve-address
Prop0 Cog6 ok
disp_eeprom
Address Contents Writable
00 9984 yes To_max
01 62E3 yes To_min
02 201 yes PWMCTRL
03 F71C yes Ta range
04 FFFF yes emissivity correction coefficient
05 1FB3 yes config register1
06 8864 no Melexis reserved
07 8864 no Melexis reserved
08 8A07 no Melexis reserved
09 8F0F no Melexis reserved
0A A13C no Melexis reserved
0B 0 no Melexis reserved
0C 8643 no Melexis reserved
0D A8 no Melexis reserved
0E 5A yes SMbus address (LSB only)
0F 0 yes Melexis reserved
10 0 no Melexis reserved
11 7E0F no Melexis reserved
12 0 no Melexis reserved
13 800A no Melexis reserved
14 0 no Melexis reserved
15 1C2C no Melexis reserved
16 90 no Melexis reserved
17 338C no Melexis reserved
18 0 no Melexis reserved
19 0 yes Melexis reserved
1A 244A no Melexis reserved
1B 60B6 no Melexis reserved
1C A no ID number
1D 74 no ID number
1E 24 no ID number
1F 82 no ID number
Prop0 Cog6 ok
Prop0 Cog6 ok
disp_RAM
Address Contents
00 Melexis reserved:2BE5
01 Melexis reserved:AF
02 Melexis reserved:45FA
03 Melexis reserved:19D8
04 Raw data IR ch 1:1
05 Raw data IR ch 2:0
06 Tambient (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):3ACA
07 Tobject1 (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):3ACE
08 Tobject2 (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):15CA
09 Melexis reserved:E4A
0A Melexis reserved, Ta1_PKI:3ACA
0B Melexis reserved, Ta2_PKI:3A6E
0C Melexis reserved:50F
0D Melexis reserved:0
0E Melexis reserved:45FB
0F Melexis reserved:461
10 Melexis reserved:CF
11 Melexis reserved:1
12 Melexis reserved:0
13 Melexis reserved, Scale_Alpha_Ratio:8
14 Melexis reserved, Scale_Alpha_Slope:C
15 Melexis reserved, IIR_Filter:4
16 Melexis reserved, Ta1_PKI_Fraction:23
17 Melexis reserved, Ta2_PKI_Fraction:0
18 Melexis reserved:0
19 Melexis reserved:3A
1A Melexis reserved:511
1B Melexis reserved, FIR_Filter:5
1C Melexis reserved:14
1D Melexis reserved:13A
1E Melexis reserved:557
1F Melexis reserved:1B0
Prop0 Cog6 ok
Prop0 Cog6 ok
h5C set_SA
Prop0 Cog6 ok
After power cycle
Prop0 Cog6 ok
i2c_detect
50: 50 -- -- -- -- -- -- -- -- -- -- -- 5C -- -- --
i2c_device:2
Prop0 Cog6 ok
disp_eeprom
00 9984 yes To_max
01 62E3 yes To_min
02 201 yes PWMCTRL
0E 5C yes SMbus address (LSB only) <--- Changing to h5C
1C A no ID number
1D 74 no ID number
1E 24 no ID number
1F 82 no ID number
Prop0 Cog6 ok
Sal reports all the Propforth 6.0 builds are now cleaned up and reliable on his windows machines.
This week week he plans to move the build process onto the Mac, and sent me a copy to run on Linux.
We will be creating the Propforth 6.0 physical prop 1 development kernels for this step.
After we get the build hardware ware set up, Sal will add the FPGA prop 1 build steps. The FPGA material will be optional, but will be available to anyone with the hardware as more steps in the same build process. The prop 1 FPGA will be one or more of: FPGA emulation of the full prop1; FPGA emulation of the prop 1 with the unused (by PropForth) resources removed; FPGA emulation of the prop1 optimized for propforth with increased cogs (CPU cores), increased cog memory (core private memory), and increased hub memory (shared by all cogs). Ideally we would all three of these, and instructions to change between one and the next, but we'll see how time and testing work out.
Sal has all his material in git, and plans to make it available to the public on github.
My task was to get propforth 5.5 on github, but I got stuck halfway through the Udacity course, and did not figure out how to do sub-directories in the git repository yet. Sal and I will walk through the git process in the next couple weeks, hopefully I can get straightened out enough to contribute.
So our development path looks like:
* post PropForth 5.5 on github
* Prop 1 build and test on Windows, Mac, and Linux
* post interim PropForth 6.0 on github
* FPGA prop build and test on all platforms
* post PropForth 6.0 on github
Someday, I wish this file can download as text-file not png-file.
Text.file can display.
But when downloading, it is another file-name.
This Forum is bad UI. Edit-date also don't be displayed. Posts still is 0. Abatar is small. etc,etc.
I think previous Forum is better than now.
I wish to back to previous Forum.
Hi.
I try to write code for WS2822.
I have a question about address.
There is table'set up address' in page6 on PDF.
(This table on PDF is alittle incorrect.)
WS2822 have 3072channel(LED:1024pcs) on PDF.
But there are 1784channnel(255 X 7 - 1) on table'set up address'.
What am I misunderstanding?
When there is attached files, comment don't posted.
Hi
Setting of addres is ok.
WS2822 also operate finely.
Value of 2nd ch(1+m) aand 3rd ch(2+m).
I refered Arduino code.
I back to value on PDF.
I try to test about more than 256channel.
[pre]
uuuuu
[/pre]
Text sometimes cannot copy/paste .
@caskaz - I don't think it's your browser. The same happens for me. The dowlink filename becomes different from what's shown when I hover the mouse over the attachment. It becomes some long hash string or something. Another forum issue to report..
This use SMBus.
I modified Sr.
Prop0 Cog6 ok i2c_detect 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 -- -- -- -- -- -- -- -- -- 5A -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- i2c_device:2 [0 - 7] and [h78 - h7F] are reserve-address Prop0 Cog6 ok disp_eeprom Address Contents Writable 00 9984 yes To_max 01 62E3 yes To_min 02 201 yes PWMCTRL 03 F71C yes Ta range 04 FFFF yes emissivity correction coefficient 05 1FB3 yes config register1 06 8864 no Melexis reserved 07 8864 no Melexis reserved 08 8A07 no Melexis reserved 09 8F0F no Melexis reserved 0A A13C no Melexis reserved 0B 0 no Melexis reserved 0C 8643 no Melexis reserved 0D A8 no Melexis reserved 0E 5A yes SMbus address (LSB only) 0F 0 yes Melexis reserved 10 0 no Melexis reserved 11 7E0F no Melexis reserved 12 0 no Melexis reserved 13 800A no Melexis reserved 14 0 no Melexis reserved 15 1C2C no Melexis reserved 16 90 no Melexis reserved 17 338C no Melexis reserved 18 0 no Melexis reserved 19 0 yes Melexis reserved 1A 244A no Melexis reserved 1B 60B6 no Melexis reserved 1C A no ID number 1D 74 no ID number 1E 24 no ID number 1F 82 no ID number Prop0 Cog6 ok Prop0 Cog6 ok disp_RAM Address Contents 00 Melexis reserved:2BE5 01 Melexis reserved:AF 02 Melexis reserved:45FA 03 Melexis reserved:19D8 04 Raw data IR ch 1:1 05 Raw data IR ch 2:0 06 Tambient (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):3ACA 07 Tobject1 (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):3ACE 08 Tobject2 (16bit format, $27AD=10_157=-70C to $7FFF=32_767=382C):15CA 09 Melexis reserved:E4A 0A Melexis reserved, Ta1_PKI:3ACA 0B Melexis reserved, Ta2_PKI:3A6E 0C Melexis reserved:50F 0D Melexis reserved:0 0E Melexis reserved:45FB 0F Melexis reserved:461 10 Melexis reserved:CF 11 Melexis reserved:1 12 Melexis reserved:0 13 Melexis reserved, Scale_Alpha_Ratio:8 14 Melexis reserved, Scale_Alpha_Slope:C 15 Melexis reserved, IIR_Filter:4 16 Melexis reserved, Ta1_PKI_Fraction:23 17 Melexis reserved, Ta2_PKI_Fraction:0 18 Melexis reserved:0 19 Melexis reserved:3A 1A Melexis reserved:511 1B Melexis reserved, FIR_Filter:5 1C Melexis reserved:14 1D Melexis reserved:13A 1E Melexis reserved:557 1F Melexis reserved:1B0 Prop0 Cog6 okProp0 Cog6 ok h5C set_SA Prop0 Cog6 ok After power cycle Prop0 Cog6 ok i2c_detect 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 -- -- -- -- -- -- -- -- -- -- -- 5C -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- i2c_device:2 [0 - 7] and [h78 - h7F] are reserve-address Prop0 Cog6 ok disp_eeprom Address Contents Writable 00 9984 yes To_max 01 62E3 yes To_min 02 201 yes PWMCTRL 03 F71C yes Ta range 04 FFFF yes emissivity correction coefficient 05 1FB3 yes config register1 06 8864 no Melexis reserved 07 8864 no Melexis reserved 08 8A07 no Melexis reserved 09 8F0F no Melexis reserved 0A A13C no Melexis reserved 0B 0 no Melexis reserved 0C 8643 no Melexis reserved 0D A8 no Melexis reserved 0E 5C yes SMbus address (LSB only) <--- Changing to h5C 0F 0 yes Melexis reserved 10 0 no Melexis reserved 11 7E0F no Melexis reserved 12 0 no Melexis reserved 13 800A no Melexis reserved 14 0 no Melexis reserved 15 1C2C no Melexis reserved 16 90 no Melexis reserved 17 338C no Melexis reserved 18 0 no Melexis reserved 19 0 yes Melexis reserved 1A 244A no Melexis reserved 1B 60B6 no Melexis reserved 1C A no ID number 1D 74 no ID number 1E 24 no ID number 1F 82 no ID number Prop0 Cog6 okdemo Raw degreeC Tamb= 15099 28.83degC Tobj1= 15103 28.91degC Tobj2= 5578 -161.59degC Tamb= 15098 28.81degC Tobj1= 15100 28.85degC Tobj2= 5578 -161.59degC Tamb= 15098 28.81degC Tobj1= 15102 28.89degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15298 32.81degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15298 32.81degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15322 33.29degC <---- Hand over sensor Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15324 33.33degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15317 33.19degC Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15302 32.89degC Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15278 32.41degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15289 32.63degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15289 32.63degC Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15285 32.55degC Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15284 32.53degC Tobj2= 5578 -161.59degC Tamb= 15100 28.85degC Tobj1= 15275 32.35degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15102 28.89degC Tobj2= 5578 -161.59degC Tamb= 15099 28.83degC Tobj1= 15103 28.91degC Tobj2= 5578 -161.59degC Tamb= 15102 28.89degC Tobj1= 14972 26.29degC Tobj2= 5578 -161.59degC Tamb= 15102 28.89degC Tobj1= 14941 25.67degC Tobj2= 5578 -161.59degC Tamb= 15102 28.89degC Tobj1= 14937 25.59degC Tobj2= 5578 -161.59degC Tamb= 15101 28.87degC Tobj1= 14859 24.03degC Tobj2= 5578 -161.59degC Tamb= 15101 28.87degC Tobj1= 14605 18.95degC <---- Ice over sensor Tobj2= 5578 -161.59degC Tamb= 15101 28.87degC Tobj1= 14605 18.95degC Tobj2= 5578 -161.59degC Prop0 Cog6 okAdding 'reset', 'sleep', 'wakeup', 'flag'
Updated i2c_utility.
Not yet checked it by using other i2c-device.
I cannot download all uploaded files at all.
Why?
I must be something setting on my PC?
Operated SinglePhaseStepperMOtor inside clock.
[http]
Or my PC is wrong?
fl
PropForth 5.5
2015/07/12 10:33:36
P0
220ohm -- SinglePhaseSteppMotor Coil -- P1
Constants
0 wconstant out1
1 wconstant out2
clkfreq constant 1second
d220 wconstant cw_pulse
Constants
variable flag
Main
lockdict create a_delay100us forthentry
$C_a_lxasm w, h11C h113 1- tuck - h9 lshift or here W@ alignl h10 lshift or l,
z1SyZKN l, z3[yPSJ l, z1SyLI[ l, z1SV01X l, z2WiP[R l, z20iPak l, z3ryPW0 l, z1SV000 l,
z1vi l,
freedict
Initial setting
: init
out1 pinout out2 pinout
-1 flag L!
Check flag
: check flag L@ invert flag L! flag L@ ;
Rotate to cw
: cw
check
if
out1 pinhi
d220 a_delay100us
out1 pinlo
else
out2 pinhi
d220 a_delay100us
out2 pinlo
then
Rotate to ccw
: ccw
check
if
out1 pinhi
d70 a_delay100us
out1 pinlo
out2 pinhi
d140 a_delay100us
out2 pinlo
else
out2 pinhi
d70 a_delay100us
out2 pinlo
out1 pinhi
d140 a_delay100us
out1 pinlo
then
Moving clock needle to cw/ccw
: demo
init
d60 0 do cw d200 delms loop
d60 0 do ccw d200 delms loop
d10 0 do cw d1000 i d100 * - delms loop
d10 0 do ccw d1000 i d100 * - delms loop
Delay word for unit 100usec
( n1 -- ) Delay time = n1 x 100usec
$C_stTOS:n1
$C_treg1:
fl
build_BootOpt :rasm
__1
jmpret __100usret , # __100us
djnz $C_stTOS , # __1
spop
jexit
__100us
mov $C_treg1 , __100usec
add $C_treg1 , cnt
waitcnt $C_treg1 , # 0
__100usret
ret
5+(7996-18)=7983
__100usec
d7983
;asm a_delay100us
[http]
https://twitter.com/caskazsan
Where is uploaded file?
Charactewrs below is not posted.
But it cannot set address.
GrayControl cannot also control well.
Anybody is successful to contril WS2822?
Always only file. Always only comments.
-Tor
[pre] [/pre]
I've cleaned up a few of the empty comments for you. Obviously you've had some issues posting, so I will notify the forum techs to check this thread.
I can't say when they will be available, as we are all in different timezones! In the meantime...... Please keep creating and posting!
Don't let a few empty text boxes get in the way of ws2822 success!!
All the best.
Hmm, maybe it is browser dependent ?I posted a Binary file, and a comment, with no special effort here, in Firefoxhttp://forums.parallax.com/discussion/comment/1338138/#Comment_1338138
My browser cause strange in this forum?
Filename is changed another when downloading file from forum.
This also is caused by browser?
-Tor
