Need help with ActivityBot - Page 2 — Parallax Forums
2»
  • Tony 4dTony 4d Posts: 45
    edited 2015-01-06 13:45
    Tony 4d wrote: »
    dgately wrote: »
    Same thing. Did you see the next image from the about this system. it shows a 64 bit.
    I'm sure the computer is running in 64 bit because if I get info on a program that I know is 64 bit, it gives me an option to run it in 32 bit mode. I don't get that option on Simple IDE though.
    edited 2015-01-07 07:41
    So then I guess there's no way this is running on 10.6.8 correct?
    edited 2015-01-07 19:04
    jazzed wrote: »
    Most likely.
    We are looking into it.
    Even if we create a compatible release, such a version will most likely never end up on the app store.
    Did you say you have 1.0.1 RC1 running on more recent Mac OS and hardware?
    --Steve
    Yes, I'm running it on a 12core 3.06 gig Mac Pro desktop running Yosemite. Runs fine. I would still rather run on the Mac that's on my electronics bench. If you do resolve this issue, would I be able to get a copy of the software?
    edited 2015-01-09 13:23
    jazzed wrote: »
    Most likely.
    --Steve
    Have you found anything out yet?
  • TmoneyTmoney Posts: 10
    edited 2015-01-15 08:45
    jazzed wrote: »
    I have a theory about why the program doesn't work on older OS versions, and am making a package for Parallax testing this weekend. Parallax will decide what to do about any package distributions.
    `thanks for all of the effort to sort this out. I have run the terminal code mentioned earlier and the results are EFI32, which I assume is 32bit mode. HOwever, like the other posts my About info is stating that I have a 64 bit intel. I have tried the "hold 6 and the 4 keys at boot but this did not change the EFI to 64. Core 2 duo 10.7 osx
    edited 2015-01-16 12:14
    No. Only tried installing 0-9-66. I did som research on the Kernel 64 result and I stumbled upon this link from apple support. They state that although you may have a 64 bit processor does not mean you have Kernel 64. IN the software tab under computer info that I do not have a 64 bot kernel so I guess I'm screwed if simpleIDE only works in 64.
    http://support.apple.com/en-gb/HT3770
    edited 2015-01-18 05:30
    Tmoney wrote: »
    So if I upgrade to Yosemiti ut should run fine so long as I have 64 bit Intel, right?
    edited 2015-01-28 04:13
    So will this newest version (1.0) actually run in 10.6.8?
  • Courtney JacobsCourtney Jacobs Posts: 903
    edited 2015-01-28 11:03
    SimpleIDE V1.0 RC2 can be downloaded from the Learn site: http://learn.parallax.com/mac
    edited 2015-01-28 11:08
    It works perfect! Thanks a lot!
    edited 2015-01-28 12:18
    hell yeah! thanks for the hard work put in to fix this!
  • Jeff MartinJeff Martin Posts: 762
    edited 2015-01-29 09:38
    Tmoney wrote: »
    We're so happy to hear that it works for you too!
    You're welcome; it was truly a team effort (Thank you guys!!!) with lots of testing, head scratching, research, re-testing, etc. I'm so happy we were able to make it work on 10.6 and 10.7!
