IR Receivers: Hoarding Time! - Page 2 — Parallax Forums
2
    edited 2014-08-08 19:59
    Sorry guys...
    Product Discontinued
    The following product has been discontinued:
    TSOP4038 Infrared Receiver
    Unfortunately, the manufacturer has discontinued this product and we are unable to obtain more. We have no choice but to cancel your order.
    We do apologize any inconvenience that this may cause to you. We do our very best to keep the status of all items on our website as up to date as is possible. We thank you for choosing Solarbotics Ltd and hope to see you again.
    If you have any questions or comments please contact us at:
    Email:
    Sales: <sales@solarbotics.com>
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-08-08 20:55
    Jim? Whit? Duane? Mike? Martin? Rich?
    Hmm, your best customer EVER is not mentioned!!! How many do you have left to unload?
    edited 2014-08-09 06:22
    Sorry twice, Andy. None. See my previous post. Solarbotics is out. These babies are rarer than hen's teeth.
    edited 2014-09-11 13:38
    edited 2014-09-11 14:30
    XLNT! Thanks for the update Ron, I will order some too.
    edited 2014-09-11 16:06
    These have been available for a while, but they are not the TSOP4038 that we wanted.
    Reading back in the thread, these may not be compatible in some situations. Has anyone actually tried them?
    edited 2014-09-11 16:43
    Publison wrote: »
    I am certainly not an expert at reading datasheets but they looked pretty similar to me.
    edited 2014-09-11 16:55
    TSOP4038
    TSSP4038
    FEATURES
    • Low supply current
    • Photo detector and preamplifier in one package
    • Internal filter for 38 kHz IR signals
    • Shielding against EMI
    • Supply voltage: 2.7 V to 5.5 V
    • Visible light is suppressed by IR filter
    • Insensitive to supply voltage ripple and noise
    • Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC
    FEATURES
    • Supply voltage: 2.5 V to 5.5 V
    DESCRIPTION
    The TSOP4038 is a compact IR receiver for sensorapplications. It has a high gain for IR signals at 38 kHz. Thedetection level does not change when ambient light or strongIR signals are applied. It can receive continuous 38 kHz signals or 38 kHz bursts.
    DESCRIPTION
    The TSSP4038 is a compact IR receiver for sensorapplications. It has a high gain for IR signals at 38 kHz. Thedetection level does not change when ambient light orstrong IR signals are applied. It can receive continuous38 kHz signals or 38 kHz bursts.This component has not been qualified according to automotive specifications.
    ABSOLUTE MAXIMUM RATINGS
    PARAMETER TEST CONDITION SYMBOL VALUE UNIT
    Supply voltage (pin 3) V
    S - 0.3 to + 6.0 V
    Supply current (pin 3) IS 5 mA
    Output voltage (pin 1) VO - 0.3 to 5.5 V
    Voltage at output to supply VS - VO - 0.3 to (VS + 0.3) V
    Output current (pin 1) IO 5 mA
    Junction temperature Tj 100 °C
    Storage temperature range Tstg - 25 to + 85 °C
    Operating temperature range Tamb - 25 to + 85 °C
    Power consumption Tamb ≤ 85 °C Ptot 10 mW
    S -0.3 to +6.0 V
    Output voltage (pin 1) VO -0.3 to 5.5 V
    Voltage at output to supply VS - VO -0.3 to (VS + 0.3) V
    Storage temperature range Tstg -25 to +85 °C
    Operating temperature range Tamb -25 to +85 °C
    edited 2014-09-11 19:16
    Good catch, Jim! I didn't see the TSSP vs TSOP at first glance. AFAIK they do look compatible from the data sheet, my main requirements being fixed gain and continuous signal compatible.
    Funny, the price has about doubled. The last TSOP4038's I ordered from Mouser in Sept '12 was 66 cents each.
    edited 2014-09-11 19:37
    Keep in mind that the reason I recommend these is strictly for simple IR beacon/homing apps as demonstrated below. For IR control and receiving Sony TV codes, you can use nearly any cheap 38 kHz receiver module. Here are 10 units for 99 cents (auction, easy win, no bids): http://www.ebay.com/itm/10pcs-HS0038B-HS0038-SIP3-TO-92-IC-PCM-Infrared-Receiver-IR-Receiver-/251625835321?
  • WhitWhit Posts: 4,194
    edited 2014-09-11 19:42
    Cool! Another great deal...
    edited 2014-09-11 20:16
    I wasn't trying to fool you erco! Posts 23 and 25 discuss the TSSP being a replacement for the TSOP
    edited 2014-09-13 17:00
    Publison wrote: »
    Jim -
    Well, I got my TSSP4308 sensors from DigiKey today and tested one with code I use in my VMusic2 MP3 Player (which uses a Sony CD player remote with 37 keys) and it works perfectly.
    I don't have anything to test continuous 38 kHz signals like erco uses in his beacon navigation robot but the spec sheet says it handles continuous signals.
    - Ron
    edited 2014-11-06 09:07
    My cherished supply of obsolete TSOP4038's is nearly gone, so I ordered (25) TSSP4038's from Mouser @ 68 cents each, but they are on backorder thru Dec 17, FYI. Will advise continuous signal compatability then, Merry Christmas.
    edited 2014-11-06 11:39
    You can still get the TSOP4038 version here http://www.taydaelectronics.com/ir-receiver-module-38-khz-tsop4838.html for $.66
    WRONG sensor!
    edited 2014-11-06 11:57
    Please advise it the will do continuous.
    edited 2014-11-06 11:58
    Just ordered 20.
    edited 2014-11-06 13:28
    Sorry, that's the 4838. Not continuous, I tested them.
    edited 2014-11-06 13:38
    Darn! I din't look closely at the number. :(
    Anybody need 10 for cheap? :)
    edited 2014-11-06 13:42
    No sir, I'm well stocked in units that are not continuous.
    And many of those were dirt cheap, like 10 for 99 cents, free ship! http://www.ebay.com/itm/10pcs-HS0038.../251625835321?
    Once again, the 4838 is fine for many applications like reading Sony TV remote control codes, or replacing BoeBot IR sensors. It just can't track a continuous (unmodulated) 38 kHz signal such as a simple LM555 emits.
    edited 2014-11-06 14:50
    Publison wrote: »
    Just ordered 20.
    Damn! Maybe you can cancel your order.
    Really sorry Jim!!
    I had ordered some once not knowing they did not work in a continuous manner.
    edited 2014-11-06 15:39
    Not to worry Ron,
    They will be put to good use and I will have some left over to send for free for the school newbies on a budget.
    edited 2014-11-22 08:12
    I received my receivers (!) and tested them to confirm the TSSP4038 is continuous signal compatible, a worthy replacement for the discontinued TSOP4038. I had to accomplish SOMETHING during the Great Forums Blackout of Twenty and Fourteen.
    edited 2014-11-22 08:24
    Good to know. Get 'em while they are hot. Only 4,000 left!
    http://www.mouser.com/ProductDetail/Vishay/TSSP4038/?qs=lgjwDzixuo3Ja5hn%252bEmOdw%3d%3d&gclid=CjwKEAiAhcGjBRDot_fjjtPKrgsSJACNYh76MRLHt1NcZfmK07itxRx7fz4naZ_H3E5QenuL4gcZ0BoCQDnw_wcB
    If anyone knows of some students that need some 4838's, I have 10 I will ship for free.
    edited 2015-01-06 06:56
    These TSSP4038's MUST be hot items! Mouser and Digikey zero stock. Mouser to receive ~6,000 Feb 2nd. I can wait another month.
    edited 2015-01-06 10:52
    Publison wrote: »
    XLNT, maybe I can scalp a few to the Arduino crowd!
    edited 2015-01-16 20:48
    NOT continuous signal compatible, but perhaps the cheapest IR receivers you will find. If you need 120 for $10. At just 8.3 cents each, this hoarder's mouse finger is getting itchy!
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G16737A
  • piguy101piguy101 Posts: 248
    edited 2015-01-20 19:15
    I'm just curious, why are the majority of IR receivers not continuous?
    edited 2015-01-20 19:56
    Excellent question, piguy101! My hunch is that the range and sensitivity of the receivers can be higher if they are not continuous. Any Waitrony catalog has dozens of different sensors with different specs and features, some are more tolerant of sunlight, some are long range, some high gain, some variable gain, some are better at rejecting certain types of competing signals, some have metal cases. The 4038 sensors have fixed gain, which is unusual AFAIK.
    edited 2015-03-30 07:00
    Just a note, Mouser has over 9,000 TSSP4038's in stock at 66 cents each:
    http://www.mouser.com/ProductDetail/Vishay-Semiconductors/TSSP4038/?qs=lgjwDzixuo3Ja5hn%252bEmOdw%3D%3D
