How to "hack" a CRC?
ManAtWork
I'm just about to find out how to talk to an encoder of a Misubishi servo motor with a propeller. This is an optical absolute encoder with 17 bits resolution (single turn) and an RS485 interafce. If I send a command byte of $02 to it it answers with a sequence of 9 bytes. Each byte starts with a start bit of 0 and a stop bit of 1. Lowest significant bit is transmited first. A data frame looks like this:
Here is a list of some data frame samples:
- Byte #1: always $02
- Byte #2: always $31
- Byte #3: position bits 0..7
- Byte #4: position bits 8..15
- Byte #5: position bit 16
- Byte #6: always $C0
- Byte #7: always $00
- Byte #8: always $C0
- Byte #9: CRC
- CRC polynomial, Wiki lists only 5 possibilies of common CRC-8 polynomials
- different starting values ($00 or $FF are common)
- data is inverted or not (I can't tell because I don't know the sign/direction of rotation)
Data: 02 31 57 8F 01 C0 00 C0 EA Data: 02 31 8F 97 01 C0 00 C0 2A Data: 02 31 35 A5 01 C0 00 C0 A2 Data: 02 31 0D AC 01 C0 00 C0 93 Data: 02 31 1A B3 01 C0 00 C0 9B Data: 02 31 6A B7 01 C0 00 C0 EF Data: 02 31 C8 C7 01 C0 00 C0 3D Data: 02 31 97 CD 01 C0 00 C0 68 Data: 02 31 96 D7 01 C0 00 C0 73 Data: 02 31 44 CE 01 C0 00 C0 B8 Data: 02 31 C9 CD 01 C0 00 C0 36 Data: 02 31 E2 D0 01 C0 00 C0 00 Data: 02 31 EC E5 01 C0 00 C0 3B Data: 02 31 22 EB 01 C0 00 C0 FB Data: 02 31 EE EE 01 C0 00 C0 32 Data: 02 31 51 F3 01 C0 00 C0 90 Data: 02 31 79 FD 01 C0 00 C0 B6 Data: 02 31 79 0A 00 C0 00 C0 40 Data: 02 31 6F 18 00 C0 00 C0 44 Data: 02 31 B0 28 00 C0 00 C0 AB Data: 02 31 C4 31 00 C0 00 C0 C6 Data: 02 31 71 46 00 C0 00 C0 04 Data: 02 31 35 55 00 C0 00 C0 53 Data: 02 31 F8 6C 00 C0 00 C0 A7 Data: 02 31 E3 78 00 C0 00 C0 A8 Data: 02 31 5F 8D 00 C0 00 C0 E1 Data: 02 31 0F 90 00 C0 00 C0 AC Data: 02 31 67 8D 00 C0 00 C0 D9 Data: 02 31 81 8D 00 C0 00 C0 3FHas anybody done this before or can give me some hints?
So what about a simple sum of all the bytes?
Sure enough the first example is 0x02 + 0x31 + 0x57 + 0x8F + 0x01 + 0xC0 + 0x00 + 0xC0 + 0xea = 0x384
Throw away the overflow out of 8 bits and you have 00.
So the you have it. Adding up all the bytes of the message including the check sum byte must give zero to be a correct message.
Edit: Opps. Not so fast that sum is wrong. Changed it now in red.
EDIT: Heater, I get 0x384 when I add up the bytes. How did you get 0x900?
-Tor
0x02 ^ 0x31 ^ 0x57 ^ 0x8F ^ 0x01 ^ 0xC0 ^ 0x00 ^ 0xC0 ^ 0xEA = 0x00
and
0x02 ^ 0x31 ^ 0x22 ^ 0xEB ^ 0x01 ^ 0xC0 ^ 0x00 ^ 0xC0 ^ 0xFB = 0x00
Yes I notice the error in my arithmetic and then corrected.
